Contour hd 1080p is shockingly shite!
mrtEE
PostPosted: 13:17 - 07 Dec 2011    Post subject: Reply with quote
Buy a bigger memory card and use it on high quality?
PostPosted: 13:40 - 07 Dec 2011    Post subject: Reply with quote
You're the same guy who was talking about pawning stuff off to afford a £600 bike, right? Confused
No particular point, it's just for our records.
PostPosted: 13:42 - 07 Dec 2011    Post subject: Re: Contour hd 1080p is shockingly shite! Reply with quote
Indeed - big memory cards are cheap these days.
Personally I don't think the quality of the gopro is that great anyway, suffering from general wobbly landscape syndrome too often.
b0ss
PostPosted: 14:22 - 07 Dec 2011    Post subject: Reply with quote
£120 delivered on Amazon you got ripped off.
https://www.amazon.co.uk/VholdR-ContourHD-1080P-Helmet-Camera/dp/B002QGSYZ4/ref=sr_1_2?s=electronics&ie=UTF8&qid=1323264106&sr=1-2
PostPosted: 14:23 - 07 Dec 2011    Post subject: Reply with quote
Let me mount it on my bike.... i'll check the quality Wink
LordShaftesbu...
PostPosted: 17:29 - 07 Dec 2011    Post subject: Reply with quote
Odd that it lags more on low quality than on high quality.
PostPosted: 18:04 - 07 Dec 2011    Post subject: Re: Contour hd 1080p is shockingly shite! Reply with quote
hahadumball wrote:
£200 worth of camera thats useless i regret buying the gopro
Would seem you didn't buy the Go Pro, you bought the Contour HD.
Confused
Jamey
PostPosted: 19:09 - 07 Dec 2011    Post subject: Reply with quote
Firstly, I have a ContourHD 1080p and I used it to make evey single one of these videos:
https://www.youtube.com/user/JameyCam
Even though Youtube have recompressed those vides (so you're not seeing the original, higher-quality version) I think you can see it produces decent quality results in both daytime and night time if you know what you're doing.
Secondly, when you say it lags I assume you mean that playback is jerky on your computer (since there is no screen on the device, so there is no other way to play back the vids)
This will be a problem with your computer. You can try installing VLC (but I found it wasn't much better) or the Community Codec Pack (which helped me a lot) or you can get a Mac instead of a PC (which completely cures the problem).
Thirdly, on the subject of sound quality you are largely correct. When in motion (even at low speeds) you can pretty much forget about having any meaningful audio. It only works properly when stationary. If this is a deal breaker for you then yes, buy a different camera.
iooi
PostPosted: 20:13 - 07 Dec 2011    Post subject: Reply with quote
You will be lucky to find any camera that has decent sound of the std mic.
You need a seperate mic mounted out of the wind.
A quick fix is to put some tape over the mic hole. Can ease wind noise.
mrtEE
PostPosted: 10:49 - 08 Dec 2011    Post subject: Reply with quote
I concur that tape over the mic helps, and that all cameras suffer this issue.
So in conclusion, there is nothing wrong with the camera, its the user Razz
Im-a-Ridah
PostPosted: 18:45 - 08 Dec 2011    Post subject: Reply with quote
Common problem, sounds like it's warped Wink
Jamey
PostPosted: 00:38 - 09 Dec 2011    Post subject: Reply with quote
I don't change the settings - I use the same ones for night time and daylight.
If you have the settings wrong in the daytime it can make a difference to the image in that you can end up with it too white or too dark. But in low light the problem is completely different and has nothing to do with settings.
At night time the problem is fundamentally that there isn't enough light, end of.
Unless you're filming at 60fps there's nothing on the camera you can benefit from changing. Just film what you film and then increase the brightness when you edit the clip afterwards. It's not perfect but you might be surprised how much information is actually recorded in the lower colour values that can be brought back with some tweaking of the gamma.
So just set your settings for the daytime and leave them the same for low light. I think I went out on a cloudy day and played with settings to get mine right. I probably err more on the side of brightness but it's personal preference really.
The last post was made 14 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 83.67 Kb
