Storing bike for winter?
EazyDuz
PostPosted: 14:47 - 08 Dec 2011    Post subject: Storing bike for winter? Reply with quote
So my bike is kept garaged, and is covered in ACF50.
It will be used maybe once or twice a fortnight just to keep it 'alive', so i was wondering is there anything i need to do to keep it all working correctly, so when i start using it regularly again next year i wont have seized brakes, rust or an engine that wont start?
Some say drain the carb to stop gunk building up, others say dont drain the carb as it dries out the rubbers.
Thanks
alun111
PostPosted: 14:51 - 08 Dec 2011    Post subject: Reply with quote
If you're going to be using it every couple of weeks, then really, nothing!
Maybe keep the battery on an optimate, and try and go on fairly long rides when you do.
Rinse the bike off after use to get rid of salt etc.. paying close attention to the brakes.
If it was going to be sat til spring then it would be a different story, but as you're going to be using it, just less often, there shouldn't be a problem.
PostPosted: 14:59 - 08 Dec 2011    Post subject: Reply with quote
If you are using it every week/2 weeks, personally I'd just keep an eye on the battery.
I've left a bike for a few weeks... probably 5 or 6, started it and had no problems at all. Thumbs Up That wasn't covered up or in a garage either.
t121anf
PostPosted: 17:50 - 08 Dec 2011    Post subject: Reply with quote
fill petrol tank, ride into garage, place cover over bike.
come summer time (well spring), remove cover, ride bike out of garage, enjoy
EazyDuz
PostPosted: 12:37 - 09 Dec 2011    Post subject: Reply with quote
Fair enough, someone said its worse to ride the bike every now and again through winter so wasnt sure
PostPosted: 12:53 - 09 Dec 2011    Post subject: Reply with quote
Short journeys possibly as condensation builds up and oil can go manky, but do an oil change come spring and voila Thumbs Up
cb1rocket
PostPosted: 14:46 - 09 Dec 2011    Post subject: Reply with quote
if your going to use it, once or twice or so, then make sure there long rides. Not 1 mile trips, more like 15 miles or so, otherwise the engine is just going to wear out quicker due to heat cycling.
The last post was made 14 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 50.52 Kb
