early Bandit 600 clocks
Mikey3
PostPosted: 17:38 - 08 Dec 2011    Post subject: early Bandit 600 clocks Reply with quote
Hullo!
Been looking for some clocks for my project, originally i wanted bandit 12 clocks (its a gixxer 1100m front end) until i began to swing towards the motoscope mini stuff and Vapors' range is quite nice too
The opportunity cropped up to get some old M reg bandit 6 clocks, i like analogue clocks and the styling on them is nice too.
Just wondering if the speedo drive from the gix would work on the clocks.
I don't know if speedo drives work on any speedo driven clock or adaptations have to be made, if its too much hassle i'll just get a digital one of the two above.
thanks.
mike.
Bezzer
PostPosted: 18:52 - 08 Dec 2011    Post subject: Reply with quote
The drives are similar looking on the Slingy and Bandit but they are different part numbers, dunno if there is some thickness difference to space the wheel or different spindle diameter Question Think you'll find the cable has the same drive either end though so you should be able to use the Slingy drive and cable and connect to the Bandit clocks. They do use the same internal gearing so they will be acurate(ish) as I've seen Slingy clocks used on a Bandit.
jimmyRS
PostPosted: 22:06 - 08 Dec 2011    Post subject: Reply with quote
worth a try
https://i.imgur.com/z3pvR.png
Mikey3
PostPosted: 22:38 - 08 Dec 2011    Post subject: Reply with quote
thanks bezzer and vincent, helps a lot. i'll do some research into wheel diameters and stuff Very Happy
jamie stop showing me that dog! haha!
The last post was made 14 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 43.7 Kb
