Power Loss
Dane123UK
PostPosted: 09:09 - 09 Dec 2011    Post subject: Power Loss Reply with quote
Hello,
i have a Yamaha Aerox 100cc, it was standard apart from upjetted, and a sports exhaust it went pretty much 60-65mph.
eventually it lost power and now hardley does 50mph.
i've tried swapping rollers see if that helps and does'nt, lighter rollers just make it vibrate but reaches 50 quicker.
current rollers, standard 9grams, older lighter 8grams.
could this be the piston rings?, belt? can anyone help me out?
PostPosted: 10:43 - 09 Dec 2011    Post subject: Reply with quote
Have you done a compression check or checked the belt for wear?
hazza
PostPosted: 11:31 - 09 Dec 2011    Post subject: Reply with quote
change the plug before you panic.
Dane123UK
PostPosted: 12:43 - 09 Dec 2011    Post subject: Reply with quote
how do i do all this? never done a compression check before
Dane123UK
PostPosted: 15:19 - 09 Dec 2011    Post subject: Reply with quote
Vincent wrote:
You need a compression guage like this:-
https://i77.photobucket.com/albums/j71/Drewskovitch/imagesqtbnANd9GcQyBNv3lLtoJ_IAXkKXf.jpg
take the spark plug out, screw the guage in, kick the bike over and check the compression. If the rings are worn badly, you get "blow by" and the compression will drop causing the bike to lose power.
thankyou, is it wise to get a new spark plug as it looks pretty black and on top of the piston is black aswell?
hazza
PostPosted: 15:23 - 09 Dec 2011    Post subject: Reply with quote
id buy a new plug before you buy the comp tester. I had the same symptom years back on my old rxs 100. Performance diminishes on 2 strokes when the plug wears out, which happens a lot faster than it does on a 4 stroke. If money isnt an object, id get the comp tester too. It will always be a handy tool to have if you decide to continue having bikes.
Noxious89123
PostPosted: 20:54 - 09 Dec 2011    Post subject: Reply with quote
My gf's 2 stroke used to bloody EAT plugs! Always keep a spare.
The last post was made 14 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 61.08 Kb
