De-rusting discs
Oldie
PostPosted: 21:35 - 09 Dec 2011    Post subject: De-rusting discs Reply with quote
My winter hack has cheapo aftermarket twin front discs which hate salt. They're relatively new, so dont need changing Sad Every day this week they've been gritting the roads hereabouts and even with hosing the bike down after every ride, the flippin discs are rusty as hell in the morning. Now, if only I could wipe them down with WD40 etc then I'm sure that life would be good - I just wouldn't stop at the first junction though Shocked
OEM's are a couple off hundred quid and I dont fancy spending that on a hack, but surely there's something I can do about the rust?
shereen
PostPosted: 21:40 - 09 Dec 2011    Post subject: Reply with quote
Would powdercoating them work? (not sure if you can do that to discs though Laughing )
mr jamez
PostPosted: 21:47 - 09 Dec 2011    Post subject: Reply with quote
Loosen a bolt on the front brake line, that way everytime you pull the the lever the discs get a nice squirt of oil Smile
Ichy
PostPosted: 21:49 - 09 Dec 2011    Post subject: Reply with quote
Doh!
How about making a nice sandwich while the men talk?
Quote Me Happy
PostPosted: 21:50 - 09 Dec 2011    Post subject: Reply with quote
If you're using it every day I'd just use them - it should only be minor surface rust anyway and will clear when you use them. Don't WD40 them Laughing
Ichy
PostPosted: 21:51 - 09 Dec 2011    Post subject: Reply with quote
Why are you bothered by the rust? In the time it has it can only be superficial, does it not come off with a bit of braking?
Raffles
PostPosted: 21:56 - 09 Dec 2011    Post subject: Reply with quote
A mate of mine, from Dublin, swears by using a thin smear of grease on his discs to prevent rusting. He says that you have to be carefull to use the high melting point stuff though as you wouldn't want it to melt under heavy braking.
shereen
PostPosted: 21:59 - 09 Dec 2011    Post subject: Reply with quote
Marki wrote:
Doh!
Seemed like a good idea. Why wouldnt it work??
Fisty
Just rinse it down with cold water in the evening after use then use the thing the next day.
A thin coat of rust is bugger all overnight.
Fatter and faster than Fret
nowhere.elysium
The Pork Lord
PostPosted: 22:02 - 09 Dec 2011    Post subject: Reply with quote
Given that the pads are an abrasive surface, every time you brake, you're effectively sanding them. Where's the problem?
Oldie
PostPosted: 22:05 - 09 Dec 2011    Post subject: Reply with quote
Cheers mate.
Yeah, the contact area will clean itself if used regularly but the likelihhod of snow and ice means that I'm going to get out less over the next couple of months. Anyway, the section below the "contact" area looks like a mess and I just dont like any rust on my bikes at all. Wondered if applying brake cleaner and giving it a wipe down would help?
iooi
PostPosted: 22:06 - 09 Dec 2011    Post subject: Re: De-rusting discs Reply with quote
Stop hosing it down every day.....
Get some ACF50. Treat the bike and forget cleaning it over winter.....
The more crud, the greater the protection.
yambabe
PostPosted: 22:33 - 09 Dec 2011    Post subject: Reply with quote
Your choice. If the rust bothers you that much then as has alredy been suggested coat the entire bike with something like ACF50 and put it away from the winter.
If you wan to ride (even if only occasionally) then you just have to get over your cleaning OCD and accept that a bike used in winter cannot be kept pristine unless you polish it to death after every ride.
Oh and Shereen, think about what you just said again. Powder coating? What's going to happen to it as soon as it makes contact with the abrasive brake pad...... Wink
HD
PostPosted: 23:07 - 09 Dec 2011    Post subject: Reply with quote
Oldie wrote:
Winter Hack...
Confused
Frost
PostPosted: 23:35 - 09 Dec 2011    Post subject: Reply with quote
If you don't want rusty discs, buy some stainless ones. However i hope you're not a fan of being able to stop as they are absolute shite!
Discs get rusty when left wet for a few days. It cleans off as soon as you use the brakes firmly. If yours are always going rusty then you either need to use the front brake more often and more firmly. The disc carrier can can painted as can any part the brake pads don't need to touch.
evoboy
PostPosted: 02:01 - 10 Dec 2011    Post subject: Reply with quote
All my bikes do this.
Never bothered me or cause issues.
APT Motorcycles
Oldie
PostPosted: 09:44 - 10 Dec 2011    Post subject: Reply with quote
HD wrote:
Oldie wrote:
Winter Hack...
Confused
Sometimes it just isn't worth risking your life if the conditions are dangerous.
mrtEE
PostPosted: 11:42 - 10 Dec 2011    Post subject: Reply with quote
When I take my XR250 off road, it sometimes gets mud on the tyres, is there a way to prevent this?
Crying or Very sad
Ichy
PostPosted: 12:07 - 10 Dec 2011    Post subject: Reply with quote
clingfilm.
Quote Me Happy
PostPosted: 12:08 - 10 Dec 2011    Post subject: Reply with quote
Crying or Very sad
Have you thought of powder coating them?
shereen
PostPosted: 15:58 - 10 Dec 2011    Post subject: Reply with quote
Joe wrote:
Crying or Very sad
Ok ok!!!!!!
Enough said, I shall duly stfu and go make some sandwiches Razz
shereen
PostPosted: 19:23 - 10 Dec 2011    Post subject: Reply with quote
https://i959.photobucket.com/albums/ae74/Clearancelines/EggSaladSandwich1.jpg
HD
PostPosted: 19:47 - 10 Dec 2011    Post subject: Reply with quote
To be fair, that does look pretty good.
Noxious89123
PostPosted: 22:33 - 10 Dec 2011    Post subject: Reply with quote
I hope you're not serious... Shocked Neutral
Shaft
PostPosted: 04:07 - 11 Dec 2011    Post subject: Reply with quote
Egg, mayonnaise, black pepper Thumbs Up
Brown bread Thumbs Down
Back to the kitchen and try again, only sliced white shit for real men.
Jeez, first you can't crash a bike properly, now you can't even make a decent sandwich, don't you know anything Rolling Eyes
Laughing Laughing Laughing
The last post was made 14 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 131.35 Kb
