| Greg2457 |
 Greg2457 L Plate Warrior
 Posted: 14:02 - 10 Dec 2011 Post subject: Suzuki bandit Problem - totaly stuck, any help appreciated |
Ive owned my Suzuki bantit gsf600sy x reg (30,000 miles on clock) for a couple of years with no issues, although for 2 months now its been almost un-ridable. between 6-8k rmp the bike stutters and jumps for about 4 seconds then it will pull away. at the same time it will be backfiring. when you give it full throttle the same problem occurs, it feels as if your running out of fuel for a split second then getting it back again, Ive been to 3 different garages and had the following work done/or done myself:
New carbs (balanced, floats adjusted etc)
new fuel tap
new pulse generator coil
new ignition coils
new inline fuel tap
new spark plugs
air box and filter checked
battery checked - all OK
The last garage i went to said it was running rich, but why? can anyone give me any advice as to what else i could check or change? i look after the bike well and its in good condition, also it has a data tool Veto Evo alarm (could this have any effect?)
Any help would be much appreciated,
Cheers, Greg |
| Kickstart |
 Kickstart The Oracle
| defblade |
 defblade World Chat Champion
 Posted: 15:56 - 10 Dec 2011 Post subject: |
Petrol filter?
Carb icing?
Although it sounds like it's flooding when you open the throttle in mid-range. I'm not really up on the specifics of bandit carbs (yet!) but my general feeling would be either whichever jet kicks in around then is wrongly sized or needles are worn, or maybe if there's an accelerator pump, that is over-fuelling. ____________________ Honda Varadero 125cc => Suzuki Bandit 650 33bhp => 77bhp =>
BMW K1200R Sport 163bhp => Aprilia Shiver GT 750 95bhp |
| Greg2457 |
| MickC |
 MickC Spanner Monkey
 Posted: 16:32 - 10 Dec 2011 Post subject: |
Just as a thought have you checked the charging system?. When i first got my current Honda it would cut out around 5000rpm and under heavy acceleration. Like you i got replacement carbs (a lot cheaper though) and still had the same problem. It was only when i checked the reg/rec against manual specs that i found the problem (easiest check is put a meter across the battery and rev the engine to 3000rpm, you should get 14.4v, if its over or under you have a problem). ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| Bezzer |
 Bezzer World Chat Champion
| Kickstart |
 Posted: 16:49 - 10 Dec 2011 Post subject: |
Unlikely a 2nd set of carbs would give the same problem. With CV carbs the needle valve controls the fueling through most of the range. The needles can wear the atomiser tubes, but normally only a common issue with aftermarket jet kits.
The charging system alone I would doubt would cause this kind of problem (low charging would likely be noticeable in other way, such as the starter landing up very slow). However it is possible for the failed regulator to result in a high voltage which can fry delicate electronics (like the cdi unit).
I have had a similar problem many years ago with a dodgy ignition switch which shorted out as revs increased. However that was on a 125 with a cruder ignition system, and not certain with the Bandit off the top of my head how the kill switch / ignition switch off works. If it works by shorting the ignition to earth (unlikely) then it would be worth bypassing the ignition and kill switch to see if this fixes it.
On a similar point, check the side stand switch.
| Greg2457 |
| Kickstart |
| Greg2457 |
| Pete. |
 Pete. Super Spammer
 Posted: 18:50 - 10 Dec 2011 Post subject: |
Is the bike fitted with an alarm/immobilizer? If it is, find it, wrap it in foam or cloth for padding and go for a ride. ____________________ a.k.a 'Geri'
| Greg2457 |
| Kickstart |
| Greg2457 |
| Bezzer |
 Posted: 15:57 - 11 Dec 2011 Post subject: |
0.2 volts isn't anything to worry about and won't be related to your problem, the Mk2 1200 Bandits are rated up to 15 volt output with the same 550w output alternator as yours. Looks like you've got to carry on checking the other bits again  ____________________ I used to be indecisive but now I'm not quite so sure. |
The last post was made 14 years, 279 days ago. Instead of replying here, would creating a new thread be more useful? |
