Is riding with one front disk legal?
Tristan.
PostPosted: 02:05 - 11 Dec 2011    Post subject: Is riding with one front disk legal? Reply with quote
Assuming the bike is intended to have two obviously.
Something peculiar happened to my VFR a month or so ago, the front wheel partially seized on the M5, I limped into Bristol with a fuckload of clutch slip and burnouts. When I got there I expected a seized calliper but after meticulously cleaning both at the side of the road the wheel was still seized. It turned out that the left hand disk had warped a barely percievable amount, but the clearence is so tiny that it was rubbing on the fork leg.
Anyway I took the disk off, shimmed that calliper and have been riding it like that ever since, complete with a rag tied around the calliper to stop the shim falling out, a more long term soluton would be to swap to a single line and remove the left caliper altogether, and preferably put on a more suitable m/c, but I have new disks anyway.
Braking performance has been entirely managable for these conditions, and I'm quite sure it's better than some older bikes which I've ridden from a passed MOT.
The thought crossed my mind though where do I stand legally?
Incedentally my 700 quid VFR has been fantastic other than that. I've done 10k on it so far with no other problems, in fact it hasn't even needed it's chain adjusting Confused
Dazbo666
PostPosted: 02:21 - 11 Dec 2011    Post subject: Reply with quote
If you got stopped by plod I'd guess it could be classed as being unroadworthy (considering the bike was designed withtwin disks etc), in which case could potentially void your insurance.
In my experience plod no longer overlooks old school bodge jobs in the same way as they did years ago...
Obviously you make your own decisions, but I personally wouldn't risk riding the bike in that condition - brakes and tyres are a particularly important consideration in my eyes Thumbs Up
Word of the day : DILLIGAF
PostPosted: 02:39 - 11 Dec 2011    Post subject: Reply with quote
Some bikes came from the factory with one disc on a wheel made for two.
It was reasonably common at one point where different models shared the same parts. The sportier model would have twin discs and the detuned model a single disc.
I can't remember which ones though. BMW R80 was one of them.
https://www.realclassic.co.uk/bikepix/bmw11040101.jpg
Frost
PostPosted: 02:41 - 11 Dec 2011    Post subject: Reply with quote
I've been stopped on a bike that was only running one of the discs. It had the second disc on the wheel but the caliper had the pistons right in, the pads right back and no line connected to it. The copper didn't seem to notice or care.
bootsbiker
PostPosted: 02:55 - 11 Dec 2011    Post subject: Reply with quote
I had a Divi that had 1 disc, the year after there started putting 2 discs on the Divi...
really bad breaking... I have a courier friend that says he only uses his front brake...
https://justfuckinggoogleit.com/
Teflon-Mike
tl;dr
PostPosted: 06:43 - 11 Dec 2011    Post subject: Reply with quote
Call your insurance company, and enquire thier opinion of the increased policy loading, IF you permenantly modified the bike, HALVING the braking capability on the front wheel, of a 150mph machine.....
Compare price to that of a new or second hand disc!
Under current C&U regs, I dont think you have a problem LEGALLY in this country, though you might if you were somehwere like germally where I believe they dont even like tyres that aren't on the TUV approved fitment list for your bike...
But here, I think requriements are merely it must have front brake, and that it must meet MOT efficiency rating, and you can, modify almost all of a bike, provided that you dont breach points threshold for re-registration demanding VOSA inspection... which you probably cant on a bike without fitting non standard engine, suspension, brakes and possibly using an alternative steering mechanism....
Bought new front disc for the CB a year or two back, pretty sure its the same disc as a VFR750, think it was about £80 for genuine EBC.... Lad got apair of wavy's of e-bay for his RF9 lasy year, think he paid that for the pair... is it really worth the hassle for that sort of money? Even on an old budget bike?
sickpup
Old Timer
PostPosted: 10:11 - 11 Dec 2011    Post subject: Re: Is riding with one front disk legal? Reply with quote
Bent over the counter springs to mind.
CU10 Using a vehicle with defective brakes.
yen_powell
PostPosted: 10:18 - 11 Dec 2011    Post subject: Reply with quote
https://i19.photobucket.com/albums/b165/yen_powell/DSCF0759.jpg
This is my mate's Africa Twin with caliper invisibly removed. He had bent the disc so badly that it was eating into the alloy of his caliper.
He rode about 2,000 miles like this until he got back to civilisation, well Yorkshire anyway. (no Honda bike dealers in Morocco at the time)
He did it when he hit the rock at speed shown below. The previous larger rock behind ripped his left hand metal pannier off and flattened it. I'm holding it's remains in the bottom picture.
https://i19.photobucket.com/albums/b165/yen_powell/tonysacc1.jpg
https://i19.photobucket.com/albums/b165/yen_powell/touratech1sm.jpg
XT1200Z and a DR350 in bits
defblade
PostPosted: 10:39 - 11 Dec 2011    Post subject: Re: Is riding with one front disk legal? Reply with quote
Shirely the more long term solution would simply be to put a new disc on?? And if it's a problem with the hub rather than the disc, get a new (ebay) wheel?
Or am I missing something here?
sickpup
Old Timer
PostPosted: 11:26 - 11 Dec 2011    Post subject: Reply with quote
You are incorrect.
ANY change that lowers braking efficency, perceived or otherwise from the standard achieved at homologation could be considered defective brakes.
The first person to be prosecuted by traffic light cameras was actually a driver that had disconnected the perfectly working ABS on his car for safety reasons but it was deemed a defective braking system by a court.
salty21
PostPosted: 11:58 - 11 Dec 2011    Post subject: Reply with quote
aslong as you completely remove the brake system from that side it's fine, as a brake thats not there cant be defective Laughing .
I removed one of the brakes from the front of the superfour 2 years ago as the disc was warped badly and it was far too sharp with 2 discs anyway and it's passed the last 2 m.o.t's like that with an advisory Very Happy .
https://www.bikechatforums.com/files/super4.jpg
https://www.bikechatforums.com/files/advisory.jpg
c-m
PostPosted: 12:11 - 11 Dec 2011    Post subject: Reply with quote
Lol what has 150mph got to do with the price of a hooker in Amsterdam? Since that speed is completely illegal on UK roads, it's neither here nor there. You were just trying to be sensationalist. Shame on you.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
SirToU
PostPosted: 13:52 - 11 Dec 2011    Post subject: Reply with quote
In my opinion, if this bike was involved in a fatal accident and the owner survived, I would through the book at the owner.
If your in morocco and it's a get me home, fine. But as a permanent fix, I would say the brakes are not in accordance with the certificate of conformity issued to the manufacturer, as even bikes that are designed with two but only have one fitted still are tested to comply by the manufacturer.
Hey, is your life really only worth £200 ish - the cost of replacement parts.
Unfortunately, The society we live in these days is no very tolerant.
Just my 2p worth.
Neil
Ride it like it was stolen.
2011 Motogymkhana UK Competition Winner
2012 Motogymkhana UK Series Champion
salty21
PostPosted: 14:49 - 11 Dec 2011    Post subject: Reply with quote
my bike was far more dangerous with 2 discs fitted, even with only one i can still lift the back wheel, why would i want more braking power than that?
daemonoid
PostPosted: 15:45 - 11 Dec 2011    Post subject: Reply with quote
I doubt you're halving the braking efficiency - you'll still be able to lockup the front. You'd have to have racing slicks and an ultra gripy road surface and even then I'd be surprised if the tyre / road interface wasn't the weak link in stopping quickly.
Double front discs are more of a stylistic addition rather than a necessity. Insurance companies will use anything to load your policy though...
current: ducati monster 750
sickpup
Old Timer
PostPosted: 16:03 - 11 Dec 2011    Post subject: Reply with quote
Bit more than styling, all to do with neutrality efficiency and I'll give you Karma if you can explain. If you can't please retract your statement above as it will have become completely worthless and regardless is rather dangerous. Thumbs Up
daemonoid
PostPosted: 16:04 - 11 Dec 2011    Post subject: Reply with quote
Kinda related*:
https://psyc.queensu.ca/target/chapter07.html
reduced breaking efficiency / safety does not increase accidents.
* I say kinda, because I'd still argue that the efficiency of the op coming to a stop has not changed.
salty21
PostPosted: 16:13 - 11 Dec 2011    Post subject: Reply with quote
daemonoid wrote:
Kinda related*:
Agreed , he will just have to squeeze harder
daemonoid
PostPosted: 16:36 - 11 Dec 2011    Post subject: Reply with quote
Never heard the term "neutrality efficiency", perhaps it has a more common name?
To clarify - the braking system as a whole should be thought of as a system that relies on its weakest link. The weakest link normally being the traction between tyre and road.
You could argue that the braking efficiency is reduced as salty points out because you have to put in more input pressure, but again the drivers hand is not the weakest point in the system.
A better argument would be that the brakes are more likely to overheat due to the increased input pressure - it'd have to be very spirited riding though.
Maybe your "efficiency neutrality" refers to the fact that the forces in the braking system are not aligned - ie. the actual stopping component (tyre/road) is not aligned with the disc/calliper. The one sidedness would create a turning force that affects the front axle and potentially microscopically warps the axle, discs or forks during braking? Although this would be possible, again it would require consistent spirited riding and a lot of time to have an effect - the discs would be worn before it really matters, the forks would likely be worse off after a couple of potholes...
salty21
PostPosted: 18:17 - 11 Dec 2011    Post subject: Reply with quote
pretty sure it doesnt half it and in this weather its a good thing IMO
Even with only one disc it brakes better than some bikes i have ridden.
Out of interest have you ever tried riding a bike with one disc removed? I think you would be suprised
c-m
PostPosted: 18:36 - 11 Dec 2011    Post subject: Reply with quote
BLUEX5 wrote:
Seriously, i cannot believe people are trying to find ways of justifying halving the stopping power of a 200kg, 150 mph behemoth.
It's just beyond retarded, even by BCF standards.
I can't believe that someone things removing a disc is halving the stopping power of the bike.
Again, the fact that it can go 150mph is of no consequence.
salty21
PostPosted: 18:38 - 11 Dec 2011    Post subject: Reply with quote
it was a response to you saying its retarded to remove a disc from a bike. I was pointing out you were wrong and giving you an example but you dont seem to take being wrong very well
The last post was made 14 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 144.84 Kb
