ELECTRICS
shuggler
PostPosted: 20:07 - 12 Dec 2011    Post subject: ELECTRICS Reply with quote
i have a malaguti xtm 50! trouble is i have a back light and front light but horn dont work,indicators dont work and brake light.The digital dash was tempramental but now that gone on blink.
Fuse ok,new battery and earth seems ok! Just dont know what to do now Evil or Very Mad
shuggler
PostPosted: 21:07 - 12 Dec 2011    Post subject: Reply with quote
yeah battery is brand new because i thought old battery was causing some problems! just seems a big coincidence that all them components should stop working all at once.
shuggler
PostPosted: 21:13 - 12 Dec 2011    Post subject: Reply with quote
I've checked the fuse cos its only got one and replaced the rear bulb too and still the same.
shuggler
PostPosted: 21:35 - 12 Dec 2011    Post subject: Reply with quote
seems to be ok.gave bike to friend who knows a bit about bikes.Could a faulty ignition switch cause all these problems?
shuggler
PostPosted: 21:59 - 12 Dec 2011    Post subject: Reply with quote
God i hate electrics! Evil or Very Mad
at106
PostPosted: 22:14 - 12 Dec 2011    Post subject: Reply with quote
You say the battery is ok but is it fully charged? Is the fuse pushed in correctly, and are any of the wires damaged?
All the parts which arnt working are powered straight from the battery, so the problem is either the battery, fuse or some damaged wiring.
Also if the bike has electric start does that work and do the horn, indicators and brake light work when the engine is running?
shuggler
PostPosted: 22:22 - 12 Dec 2011    Post subject: Reply with quote
fuse is properly pushed in.With engine running only thing that works is rear light and front light! No electric start just kick start! Battery is giving good voltage.
at106
PostPosted: 22:28 - 12 Dec 2011    Post subject: Reply with quote
It's probably damaged wiring. If your mate thinks its the ignition switch i would check that first, you can use a multimeter. If you have a wiring diagram it'll be a lot easier.
shuggler
PostPosted: 22:36 - 12 Dec 2011    Post subject: Reply with quote
its only got a kickstart! Its an imported italian bike no got no manuals or diagrams which is a nightmare!
The last post was made 14 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 84.07 Kb
