Ideal tyres for greasy/icy/snowy conditions?
Flemy
PostPosted: 18:00 - 15 Dec 2011    Post subject: Ideal tyres for greasy/icy/snowy conditions? Reply with quote
Well, finally decided to stop lurking the forum and to make my own account as I need a bit of advice on which tyres are right for this kind of weather.
I've got a piece of crap xr125-L which comes as standard with knobbly tyres which don't seem to be great in these sort of conditions, the amount of times the back end has locked up with the smallest amount of breaking and the front end has slipped with the smallest amount of turning is unreal. I was just wondering if it was worth changing the tyres or if I even can with the xr? As I can't find any online! Or, shall I just ride it out, save spending any money on a bike that's going to be burned when I pas my DAS in may? Just don't really fancy dying before I get to may...
Advice would be appreciated
Prev- Pug speedfight 2 50cc x3 (Write off, blown engine and stolen), Honda Xr 125-L (Nail), Suzuki GSX-R 600(stolen). Current- Kwak ninja 300
PostPosted: 18:14 - 15 Dec 2011    Post subject: Reply with quote
No bike tyres are right for snow or ice.
In the cold and wet you need good quality road tyres, not chinese triangles or goodrides or Wanli or whatever.
You want whatever Pirelli, Dunlop, Michelin, Bridgestone or Mezeler can do for your rim sizes. If it has to be crossplies I'd reccomend Bridgestone BT45, but it is possible they don't do the right size for your rims.
Flemy
PostPosted: 18:22 - 15 Dec 2011    Post subject: Reply with quote
Guess I'll just leave it then, I'll ride up till it snows or I come off.
Thanks though.
Ariel Badger
PostPosted: 18:36 - 15 Dec 2011    Post subject: Reply with quote
Car tyres.
PostPosted: 18:46 - 15 Dec 2011    Post subject: Reply with quote
https://www.snowmobiletrails.com/moto/index.html
Do this Laughing
HD
PostPosted: 19:38 - 17 Dec 2011    Post subject: Reply with quote
It sounds as though you may need to adjust your riding technique. By no means am I a great rider but many new riders don't realise how to ride in bad conditions or with knobbly tires. You need to do all of you braking and accelerating on the straight, then cruise around corners at neutral throttle.
It is imperative in snow and ice that you don't accelerate or brake while turning. Also, when going around corners you need to go stupidly slow and turn the bars instead of leaning. Hanging off the bike may help too.
Even in the dry, you shouldn't really accelerate til you get off the apex of the corner and don't give it a decent chunk of throttle til your upright. Knobblies aren't ideal and I have come off twice through leaning too far/going to fast with knobblies on road. They aren't too bad in fresh snow though.
So look at riding technique then see what tyres you can get as Marjay said.
Safe riding and HTH Thumbs Up
Also, it may be better to get a bus pass for a while as its gonna cost a lot more than a bus pass to fix the bike (or yourself) if you do come off bad.
Ingah
PostPosted: 22:33 - 17 Dec 2011    Post subject: Reply with quote
I think you're expecting too much. Bikes really aren't compatible with ice and snow - Whilst yes, it can be done, your tyres will want to slide and you will probably come off (maybe even more than once) and may hurt yourself quite seriously.
There are solutions but they are largely too extreme for the UK (as your journey won't be 100% snowed up roads) - snow chains, snow claws, and studded tyres. There are also sprays that may help a little. Reducing tyre pressures a little will also help, but to reduce them considerably will require rim locks. Riding style/technique is massively important.
And yes, make sure you're not running cheap and nasty tyres that would struggle even in just the rain.
Honestly though, just get the bus/a lift on those few days/weeks.
-- Ingah
c-m
PostPosted: 12:36 - 18 Dec 2011    Post subject: Reply with quote
##Paddy## wrote:
Thought would be abysmal in greasy conditions.
Only good for heavy compact snow, compact ice,or mud.
A pair of road legal wets would do you well due to the amount of heat they generate and their tread.
Avon do some. While the front will last a while in the dry, the rear would be lucky to see 500-1000miles in the dry.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
The Artist
PostPosted: 12:49 - 18 Dec 2011    Post subject: Re: Ideal tyres for greasy/icy/snowy conditions? Reply with quote
4
kawakid
PostPosted: 22:32 - 18 Dec 2011    Post subject: Reply with quote
Don't try riding on snow and ice, i've been lucky past years. Been there done it, dropped it. No point.
I've a twin and a 4.
Skudd
PostPosted: 10:02 - 19 Dec 2011    Post subject: Reply with quote
Before my ex was my ex she had a XR125. Great little bike for all weathers and snow. It will slip and slide, but that low speed stuff now will help you in years to come. Thumbs Up
PostPosted: 13:08 - 19 Dec 2011    Post subject: Re: Ideal tyres for greasy/icy/snowy conditions? Reply with quote
If you've got dirt tyres, you want to run them at as low pressure as you dare in my experience - this will help on the snow at least.
Studs in the tyres make a big difference on ice and these ones are fine on dry roads too.
https://gees.zenfolio.com/img/s2/v1/p12305489-4.jpg
The last post was made 14 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 75.49 Kb
