| _Troy_ |
 _Troy_ World Chat Champion
 Posted: 12:40 - 17 Dec 2011 Post subject: Bike wont start. GS500, please help! |
Well I had some issues previously, but they seemed to be solved. But no.
Right so the bike won't start at all. It's gotten to the point that the starter won't even turn over. Absolutely nothing happens when I press the starter button. The neutral light is on.
The lights also come on fine, but seem a tad dim. When I jump start the bike from a car it starts immediately. No hesitation, and the bike runs fine.
But, the battery is only a couple of months old. So if it is dead, there must be another reason behind it, surely? It does have a tiny bit of charge though, as you can see from the lights, so surely it would try to start, even just a little...
I've checked all wires and fuses, and they seem fine. I've had a look at the solenoid, but I'm not really surer what I'm looking for. It looks a bit corroded, but only to the extent of years of water damage. It's in a bit of an annoying place on the GS, so it's difficult to tell.
Is it worth sticking a new battery in, and just going from there. Or should i get someone to look at the solenoid?
This whole situation is really starting to annoy me. I only have the odd weekend to have a goat sorting this, so I've been off the bike for weeks with this issue. On that note, absolutely any useful information would be excellent, and I'll reward such stuff with Christmas cheer. ____________________ Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650 |
| demon9374 |
 demon9374 Spanner Monkey
 Posted: 13:00 - 17 Dec 2011 Post subject: |
I didn't try jumping it from a car (when I had my RS 125).. People said it was a duff battery, I got a charger, one of the maintainers that can recover them, waste of £30.. It wasn't to do with the battery. It was a brush inside the starter motor, it'd snapped in half, springs that keep it against the armiture had gone & the armiture needed a clean up, sorted all that out in 5 mins, bike started fine, as with brushes, if not touching properly, then there's a bad earth and nothing with get through to it from the starter relay.
All that said, it's gay, I swapped my RS for something reliable, a Honda.. Now I've had loads of hassle with that, newest one, not starting on the button. I'm going to hazzard a guess at the same situation as the RS, as I've charged this battery aswell, even though the battery was fully charged to begin with. Too cold to piss about with atm though.
Swapped an unreliable Aprilia for a Honda XR (CG Engine) after a week of having it, front sprocket fell off, puncture in back tyre, not electric starting lol
If it's easier than looking at the solenoid, try taking the starter motor off and inspecting the brushes. One thing ruled out then.. |
| mysterious_rider |
 mysterious_rider World Chat Champion
 Posted: 13:54 - 17 Dec 2011 Post subject: |
Sounds like the charger coil inside the statorplate has gone.
Funnily enough prev owner of my gs500 had to have the stator rewound in 2003. So could be a common problem. |
| _Troy_ |
 Posted: 14:00 - 17 Dec 2011 Post subject: |
Cheers for the help so far, have some Christmas cheer.
If it does turn out to be the starter, is it a good idea to replace it then?
Oh I should add that a couple of weeks ago it would attempt to start maybe once, and then nothing. Didn't sound like there was enough power, or that something wasn't kicking in. ____________________ Current bike: ZX6R J1
| mysterious_rider |
 Posted: 14:03 - 17 Dec 2011 Post subject: |
If you said it would start and run fine when using jump cables, then it's obviously either a dead battery (you've pretty much ruled that out though with replacing it already!!) or the statorplate not charging the battery while running. Obvs the battery will eventually go flat, hence your problems.
My money is on the statorplate needs new coils. You could always try a multimeter on the charging wires and read the OHMS that it gives off. Not sure what it should read though.
| _Troy_ |
| Robby |
 Robby Dirty Old Man
 Posted: 14:36 - 17 Dec 2011 Post subject: |
It started right off when you jumped it off a car, so there is nothing wrong with the starter motor or solenoid. Your problem is with the battery or charging system.
Is it a lead acid battery or a sealed one? Did you charge it for a good few hours when you first got it?
Anyway, charging system test. First, charge the battery overnight so that you can get vaguely reliable readings during the test.
Multimeter set to volts across the battery terminals. You are looking for the following readings:
1. Everything turned off, look for about 12V.
2. Engine idling, look for 12-13V
3. Engine at 4000 rm, look for 13-14.5V.
If the voltage stays at 12.5V or below during tests, it isn't charging. If it goes above 30V, your reg rec has failed.
Possible (likely) reason for not charging is rec/rec failure - they can fail so they overcharge the battery, or fail so they don't charge at all. Failure to charge can also be down to a knackered stator, but a reg/rec is cheaper and easier to change. Try and borrow one off someone else to test.
A healthy battery will let the bike run about an hour or two with the headlights on if it isn't charging.
Another possibility is corrosion somewhere, most likely on an earth point. |
| MickC |
 MickC Spanner Monkey
 Posted: 14:51 - 17 Dec 2011 Post subject: |
As Robby has already said check your charging system. ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| _Troy_ |
| orac |
 orac World Chat Champion
 Posted: 18:35 - 17 Dec 2011 Post subject: |
you can check you alternator too, disconect the three yellow wires that come from your engine to the reg/rec, set tyour multi meter to ac voltage. you should have at least 75v ac across all of them.
alos with the engine off, check that you have between 3 and 5 ohsm across the same wires. testing the voltage isnt always a fail safe, i had runner put out the correct voltage but wasnt charging due to no resistence on the coils.
another thing the haynes manual suggests is to put you multi meter between the positive terminal and the poistive wire, with the multi meter set to mA and the ignition off, the readin should not exceed 0.1 ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
"with nothing left to lose, there is everything to gain. It's not the size of the dog in the fight, it's the size of the fight in the dog" |
| Gothtec |
 Gothtec Renault 5 Driver
 Posted: 21:09 - 18 Dec 2011 Post subject: |
Agreed check the charging system
If a new battery solved the problem then its likely its your rectifier...If it is faulty it can kill the battery, even a new one! ____________________ ---------------------------------------------------------------------------------------------------------------
10% discount at www.globalbikeonline.com, use promo code gboaw10 at the checkout!
| _Troy_ |
 Posted: 15:05 - 26 Dec 2011 Post subject: |
Right guys, finally got the time to check all this today.
When I first tested the battery, it was putting out about 10.5V.
Jump started the bike, and when the engine had warmed up it was sat around 12.5, however when I revved the bike it dropped to about 10.5.
I then took the bike for a 10 minute blast up the dual carriageway. On return I immediately tested the battery again. It read around 12.5-13V, and when revved it jumped up slightly to around 14.V.
Upon trying to start the bike immediately after turning it off, nothing. No charge at all. I promptly jumped it again, went for a very long ride, and repeated the process. Again it didn't start once stopped.
Plugging another battery in started the bike instantly too, indicating that it is definitely the charging system, surely?
I haven't had the chance to check the other bits, but thought I'd report back in case this changes anything. As always any helped will be rewarded with hugs. ____________________ Current bike: ZX6R J1
| orac |
The last post was made 14 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
