| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 13:38 - 15 Sep 2004 Post subject: Stoppies advice-- calling Jon etc.... |
What's the "best" way to keep a stoppy rolling??
I can get the wheel relatively high according to Hustler, but I can only roll for about a meter or so... The R6 does it nice and smoothly and quite easy, just not very far. The WR is kind of difficult due to spongy brakes, but furthest I've managed is a couple of meters!
Anyone got any tips to keep the wheel up? I do it from varying speeds but still struggle, Are you meant to feather the brake off once the wheel is up or do you have to do it quicker and let the speed your traveling at keep the wheel off the ground? ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| Korn |
 Korn Admin
 Posted: 13:44 - 15 Sep 2004 Post subject: |
You should first give it a good firm squeeze to get the back up in a quick movement, then let off a bit of pressure once it's high enough to balance and roll along, adjusting the lever pressure if the back starts to drop/rise.
If you just keep the brakes pressed on, you'll stop. That's what they're there for  ____________________ 3516 Miles, 11 Countries |
| Ste |
 Ste Not Work Safe
 Posted: 13:48 - 15 Sep 2004 Post subject: |
It really is just a case of practising and finding the amount of pressure you need to keep on the lever, to little and it comes down, too much and you stop or flip over the front. As Korn said, the pressure needed to keep the rear up is less then is needed to get it high initally, just experiment carefully.  |
| Sparks! |
| G |
 G The Voice of Reason
| Jon |
 Jon Anyone for donuts?
| G |
 Posted: 14:48 - 15 Sep 2004 Post subject: Re: Stoppies advice-- calling Jon etc.... |
Yea, , was gonna mention the speed.
Once you are confident, build your speed up and it aint too much of a problem to do them from 90-100. Get plenty of distance even on low ones then. |
| Sparks! |
 Posted: 14:53 - 15 Sep 2004 Post subject: Re: Stoppies advice-- calling Jon etc.... |
| Smoto Bob |
 Smoto Bob World Chat Champion
| Sparks! |
| Jon |
| Smoto Bob |
The last post was made 22 years, 49 days ago. Instead of replying here, would creating a new thread be more useful? |
