Just a few tips about cars and breaking down
Old Git Racing
PostPosted: 09:17 - 19 Dec 2011    Post subject: Just a few tips about cars and breaking down Reply with quote
Been working as a recovery driver/home start driver for the last few weeks and it's been a real eye opener. Thought I'd pass on a bit of my experiences to those with cars. I know blokes car aren't affected (yeah right) but it might be worth checking the missus's.
How's your battery, been to loadsa 05/06 cars with the oem battery on which is f***ed.
Is your spare wheel good, or is there even one in there.
Are you able to seperate the wheels from the hubs after taking the bolts out. Every wheel change I've been on so far is for this, wheel stuck to hub with corrosion.
Are your locking wheel nut bits in the car.
Is the car handbook in the car.
Do you have a warm coat in the boot for when you break down on the motorway and the Highways guys make you stand behind the barrier in -2c while I turn up. ( Please do get out and do this, following a Stobart artic that drove halfway on the hard shoulder for about 500 yards yesterday).
Do you know where the screw in tow eye is if your car has one, beemers etc. If not you get charged for sending something else that can load it.
Has your car really really got anti freeze in.
Do you even have breakdown cover? Break down on a motorway or a trunk road and the Highways will charge you up to £150 just to get you taken to the nearest safe place, and you don't get a choice. (this goes for bikes as well).
Don't try and drive with a flat thinking you can make it to the next junction. The tyre partially comes off the rim, goes hard when it cools and your wheel and bodywork then get damaged recovering it.
All seems a bit obvious I know, but all the above are happening and I've been flat out with stuff like this for weeks.
OGR
Skudd
PostPosted: 10:54 - 19 Dec 2011    Post subject: Reply with quote
Winterised my car about a month ago even have a jump pack even after getting a new battery. All has been ready, nice shovel and a flask ready for hot water. Tow ropes, carpet for getting out of the snow, Coat, water, deicer, screen wash, Torch ( wind up) new tyres, jump leads, RAC cover.
Then the bloody radiator burst. Have had to use the bike in all the ice and snow.
PostPosted: 13:02 - 19 Dec 2011    Post subject: Re: Just a few tips about cars and breaking down Reply with quote
Yet knowing this, people still carry on with the recovery and damage the wheel and bodywork when they could have either changed the wheel or put it on one of those little dollies until they could change it?
Doesn't that seem a tiny bit negligent?
The battery thing annoys me because a car battery should last longer than that. They still fit loads of cars with non-sealed lead acid batteries and they NEVER check the bloody electrolyte level at a service. You land up running about with a dry cell then your battery lets go the following winter.
I recently replaced the battery on my wee Suzuki Jimny. Original battery the car came with, ten years old, 120k miles. 95% of which has been short journeys within 15 miles of my house. It lasted this long because I check the electrolyte after every service, I've found cells below minimum in it even after a dealer service when it was still under warranty.
Walloper
PostPosted: 13:34 - 19 Dec 2011    Post subject: Reply with quote
I would honestly only expect an OEM battery to last 3 years.
It may still operate OK but in extremes it will more than likely fail.
i.e. they will pass a start test but probably fail repeated hammerings.
A newer battery will or should have more reserve.
New Shop Bought batteries should last 4-5 years but I would still not be surprised if they chucked it after 3-4yrs.
Batteries are one of the most overloaded parts of the car.
People neglect them or even forget they are there.
They only need a minimum of maintenance too.
Just wiping the top clean and ensuring the leads and clamps are in good order will help.
A blanket or good wind/waterproof coat is a great thing to carry in the car through winter. and always have at least half a tank of fuel too.
Consider that when the roads are bad more folk will breakdown so the services may take longer to reach you too.
I have NO mercy for people who get stuck coz their battery has been abused or is geriatric. Obviously they pay no heed to service so deserve to pay in kind.
The only exception to my rule is 'if she is fit'. (of course) Shifty
PostPosted: 13:45 - 19 Dec 2011    Post subject: Reply with quote
You can check the electrolyte specific gravity in a battery which will give you a good indication of it's state of repair.
It takes seconds, every garage has the tool to do it with and none of them ever use it, despite "Check battery electrolyte" being in the list of things to do at a service and having been ticked on the tick-sheet.
I check mine regularly and they last a LONG time. I expect five years out of a motorbike battery. Longer if it's a sealed one.
Skudd
PostPosted: 13:55 - 19 Dec 2011    Post subject: Reply with quote
take your spare wheel and use it as a hammer, stand back to the car and swing it backwards between your legs against one side of the stuck wheel.
hasn't failed me yet.
After all these years I have never thought of that and it is so simple. Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Bendy
Mrs Sensible
PostPosted: 17:34 - 19 Dec 2011    Post subject: Re: Just a few tips about cars and breaking down Reply with quote
Err, yeah. Laughing
Its fine. And I've got a jumpstarter in the boot, after a fortnight of dealing with a recalcitrant landrover.
Don't have a spare wheel, Mazda give you a can of foam and some unfollowable advice about swapping wheels round so the foamy one is at the front. Something you're meant to achieve with only one jack and no wheelbrace. Lets face it - foam is going in and limping will happen.
Yup, changed my summer wheels to my winter wheels a couple of weeks ago.
Yup.
No idea where that went. But I have actually read it, which seems to put me in a tiny minority. And there's always the internet.
Usually got something.
Yes, they're both in the boot.
It does. Super expensive magic anti freeze at that.
Yup.
I'd be on the hard shoulder swearing at my foam.
Tip from me - keep an eye on your screenwash at this time of year. Lob a spare bottle of it in the boot cos lemonade is not a suitable substitute.
-LG-
PostPosted: 17:38 - 19 Dec 2011    Post subject: Reply with quote
First time I needed to change a wheel was when I crashed into a curb and ripped the wheel apart. Put the spare one on and started driving...was dodgy as hell to drive, thought it was because the tracking was out or something...really hard to go in a straight line.
Get to the garage and notice that my spare wheel is a 15", while all my others are 14".
Snow rider wrote: I'm far to annoying to be near for long periods of time
andyscooter
PostPosted: 20:38 - 19 Dec 2011    Post subject: Reply with quote
my tip for this time of year is buy a 5 ltr concentrated screenwash and pour it straght in
takes a lot more to freeze then water Very Happy
the wifes car
our spare is ok the battery is from last year the towing eye is inside the spare with the jack and the wheelbrace and locking wheel nut tool
screen cover and scraper in the boot shovals at work at moment as bought a fold up one today and we have some matting designed for gripping on mud and snow so got that as well
my bike is all fine but the spark plug is fucked couldnt change it at work as my spark plug tool is in the garage as i took it out before leaving home this morning after checking the plug yesterday and thinking i need a new one of those must get one at the weekend Twisted Evil Twisted Evil
PostPosted: 20:45 - 19 Dec 2011    Post subject: Reply with quote
All fine with that. Pretty sure my towing eye is in the "frunk" with the spare tyre, do need to check though. Should really check the electrolyte levels on my battery. It's getting a touch sluggish on the colder days.
Shaft
PostPosted: 20:51 - 19 Dec 2011    Post subject: Reply with quote
Following on from the point about removing wheels, can you actually remove the nuts in the first place?
It never fails to amaze me, the number of cars we get through our place where even our impact guns struggle; if you were stuck by the road with the piddly little wrench the factory give you, you've got no chance.
Before it comes to that, whip each nut off in turn, then use some copper grease on the thread and put it on at the right torque.
If you can't be arsed to do that, at least get one of those telescopic wheel wrenches that every accessory shop sells for about a tenner.
haroman666
PostPosted: 20:54 - 19 Dec 2011    Post subject: Reply with quote
Garage I used to work in, we checked it every service, along with the coolant strength.
JonB
Afraid of Mileage
PostPosted: 21:21 - 19 Dec 2011    Post subject: Reply with quote
Just a couple of things that I think are helpful. It is strange that a lot of it isn't compulsory as a lot of the kit in my car is only there because France requires it by law, but when thinking about it is good advice.
First Aid Kit. A semi decent one, you may never use it, but it may come in handy. My one has a space blanket as well.
Warning triangle - Car broke down just past a blind bend? Stick your warning triangle before the bend to warn other road users.
Car light bulbs - OK, you can probably survive til the end of the journey, but if the weather is particularly bad you may want to pull into a garage and change a bulb - only takes 10 minutes tops.
A coat.
woll
PostPosted: 21:49 - 19 Dec 2011    Post subject: Reply with quote
Should of tried to get the wheels off my van. It wouldn't of worked. Took two of use beating them with sledge hammers n had people holding wood on the rim so we didnt fook it.
PostPosted: 21:58 - 19 Dec 2011    Post subject: Reply with quote
Battery life seems to be greatly down to how they are treated.
The original battery in our 156 lasted over a decade.
neil.
PostPosted: 22:12 - 19 Dec 2011    Post subject: Reply with quote
You forgot...
Did you accidentally put petrol in your diesel car/van/truck/thing or vice-versa?
Guy who recovered my crashed bike last Tuesday said he deals with a lot of those...
PostPosted: 22:22 - 19 Dec 2011    Post subject: Reply with quote
^^^I did that for the first time last year. Work hired a car for me, i did the old petrol into diesel thing. I have never felt so human in my life...after the decades of fuelling different types of machinery and no mishaps. Embarassed x 1000
To my credit i realised and didn't start the engine.
[edit] my g/f's car is 9years old and on it's original battery. Rover 25 piece of crap but it has outlived most of the cars in our street.
Old Git Racing
PostPosted: 22:56 - 19 Dec 2011    Post subject: Re: Just a few tips about cars and breaking down Reply with quote
Not if he didn't put it back in the car after the last time so nothing in the car, police wanting it off the motorway asap. Who's negligent there??
-LG-
PostPosted: 23:09 - 19 Dec 2011    Post subject: Reply with quote
neil. wrote:
You forgot...
I've done that...felt so silly I drove off xD. Luckily it was my mums car and not mine.
Luckily it was only £75 to get it sorted due to it being a motorbility car.
Wasn't allowed to fill it up for a while...not until I got a diesel myself lol.
stonesie
PostPosted: 23:16 - 19 Dec 2011    Post subject: Reply with quote
Yep its fine, doesnt go below 10.5v on start-up, I think its for the diesel version looking at the size of the thing, cars a 1.2 16v
Space saver, un-used, pumped upto 60PSI like it says on the sidewall
Yarp, refreshed all the brakes recently and copperslipped the faces.
In with the spare.
Nope but I know where all the fuses are and have spares ect.
I usually take one but dont leave it in the car.
In with the spare.
Its a FIAT so the head gasket was done recently, It's running a 50/50 mix.
Top level AA, one of the few good things about my Lloyds bank account.
crazymotorbik...
PostPosted: 23:44 - 19 Dec 2011    Post subject: Reply with quote
Hey,
It might be worth checking the missus's.
-If you mean car.....She hasn't got one. Just a taxi service. AKA me.
-Never had a problem with my battery. Its a sealed unit. Every weekend it gets a smear of vaseline if needed on its terminals.
-Still have the original which has its prx checked weekly.
-Use copper slip! Never had a seized wheel nut yet (and don't give me no b"llshit about that being dangerous because it isn't) Same for every other fasten on my car.
-Nope. No shiny alloys on my car.
-Yes and read it.
-Fluorescent wet weather jacket which is used for work.
-With the spare wheel. Never used by me yet *touch wood oooh errr*
-Yep. Changed yearly by me.
-Yes he's called dad and will tow me home from anywhere if asked.
Tip from me - Look after your car! Its not difficult. Half an hour on a Saturday afternoon will save you hours at the side of the road Thumbs Up
Cheers,
Shaun R.
PostPosted: 00:20 - 20 Dec 2011    Post subject: Reply with quote
If people bothered to maintained their cars, why would they put money in your pocket? Doing yourself out of a job there, aren't you? Neutral
st3v3
PostPosted: 00:37 - 20 Dec 2011    Post subject: Reply with quote
My battery died last week, second one in 2 month.
But since the clutch pressure plate has wound itself loose I haven't used it in 2 weeks now, would have been a good time to stick some Anti-Freeze in. Tomorrows job Thumbs Up
Tyres are good, wheels are good, towing eye is fixed(welded) in place and only used it last week Embarassed
Always got a hood and bike fleece in the boot, along with jump leads and a spare jerry can. Assortment of useful tools is a good idea, just a handful of commonly used ones.
binge
Emo Kiddy
PostPosted: 01:31 - 20 Dec 2011    Post subject: Re: Just a few tips about cars and breaking down Reply with quote
It entirely depends where you take your car for a service.
There is some excelent advice in this thread.
Where I currently work, part of the service schedule is to check the fluid levels, which are;
Antifreeze protection level
Battery electrolyte level, voltage, and alternator charging voltage
Washer fluid concentrate level
Brake fluid level and boiling point
Also remove all 4 wheels (And the spare), clean up the hub faces, grease where necessary, carry out a full brake inspection etc.
Main-dealers on the other hand. Dont even get me started about their bloody services.
Really f*cks me off with them!
As a service tech, looking for a job. To get a job in a Dealership, they all require previous "Main dealer" experience, as if it's some God-Given special power!
And also people buying cars, genuinely think they are buying a well looked after motor if it's got a full "main dealer" service history.
Providing the car has never had a puncture, or needed a tyre changing. If it's had Main-dealer servicing, you can GUARANTEE the wheels have never been off, causing the seizure of wheel to hub.
Another bit of advice is to make sure your phone has battery, or have an in-car charger!
In this day and age, you'll be surprised how long you will be sat at the side of the road before somebody stops to help. Rolling Eyes
Ben
Shaft
PostPosted: 02:51 - 20 Dec 2011    Post subject: Reply with quote
What's even stranger, is that the French require you to carry a spare bulb kit, then produce cars that have some of the hardest bulbs to change, anywhere in the motoring world.
There are some Renaults where you can't change a headlight bulb without removing the entire lamp, which in turn involves removing the wheelarch liners and bumper cover.
Others involve you working totally blind and having fingers as thin as lock picks and fitted with UJs.
It's as if they don't consider bulbs to be consumables, but they will fine you for not carrying a spare Rolling Eyes
The last post was made 14 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 146.48 Kb
