Passing button stopped working.
kawakid
PostPosted: 19:52 - 21 Dec 2011    Post subject: Passing button stopped working. Reply with quote
Bit of a strange one really, but my passing button (that's what my manual calls it) has stopped working.
This is the little trigger that I can pull to temporarily put my full beam on, to thank drivers, warn others of my presence etc.
I've not taking my left controls apart yet, but anyone had this before?
I've a twin and a 4.
bwprice100
PostPosted: 19:57 - 21 Dec 2011    Post subject: Reply with quote
Have you checked the bulb
Brian
www.eBolt.co.uk www.ToolRoomChucks.co.uk
My bikes 1956 BMW R26 250cc, !981 BMW R80 (was a TIC ex plod), 1994 R100RT, sold my 1981 Yam XS 250
Dazbo666
PostPosted: 20:05 - 21 Dec 2011    Post subject: Reply with quote
check the bulb filament, connection(s), switch Thumbs Up
Word of the day : DILLIGAF
kawakid
PostPosted: 20:16 - 21 Dec 2011    Post subject: Reply with quote
No the bulbs fine, it comes on with the main switch.
I'll take it apart tomorrow and have a look, it does seem a bit strange, but I do use it a bit.
MickC
PostPosted: 20:21 - 21 Dec 2011    Post subject: Reply with quote
It sounds as though the switch contacts are dirty, you can get contact cleaner spray to remove the crud, alternatively you can dismantle the switch mechanism and clean all the metal parts with lemon juice, if you use that option make sure you take careful note of how all the bits fit together.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
herulach
PostPosted: 20:23 - 21 Dec 2011    Post subject: Reply with quote
Some kind of contact cleaner aimed at the switch while cycling it may sort it out without dissasembly.
YBR 125>FZS600
kawakid
PostPosted: 20:37 - 21 Dec 2011    Post subject: Reply with quote
Yeahh,
I've had a look at the service manual it looks like all it could be is a wire or the switch itself, there is no fuse.
https://i17.photobucket.com/albums/b82/mondeokid/passingswitch.jpg
Im-a-Ridah
PostPosted: 22:22 - 21 Dec 2011    Post subject: Reply with quote
Spray with WD40 then try other things.
kawakid
PostPosted: 23:57 - 24 Dec 2011    Post subject: Reply with quote
Cheers chaps. All fixed, had no wd40 so used chain lube.
The last post was made 14 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 58.68 Kb
