new HT leads and plug caps
Chris750
PostPosted: 20:37 - 21 Dec 2011    Post subject: new HT leads and plug caps Reply with quote
The HT leads and spark plug caps for my bike a very old a could realy do with replacing.
The OEM HT lead come as part of the coil packs. But I do not want to have to buy two new coil packs, so am just going to replace the leads and caps.
I am a bit confused as to which caps to get as there are many options. With or without resistors for example.
Does anybody know what cap spec I need?
Also anyone recommend any particalar typre of HT lead?
The bike is a GSXR 750 ws using NGK CR9E plugs.
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
Chris750
PostPosted: 00:12 - 22 Dec 2011    Post subject: Reply with quote
Vincent wrote:
They're probably all the same but what year is the bike?
This is where I get my caps:-
https://www.wemoto.com/bikes/Suzuki/GSXR_750_G_H/86-87/
You can get HT lead connecters if you have to cut too much off the end of the lead. The ones I've used have been a bit bulky but do the job.
Wemoto should do the lead too.
Mines a 1995 WS.
For the year bike you have put in the link they do them (they even do the whole coil pack fairly cheaply).
But for my year they don't Rolling Eyes
I did try them initially.
Thanks for looking anyway
Fizzer Thou
PostPosted: 01:06 - 23 Dec 2011    Post subject: Reply with quote
I had to replace some ignition lead on some coils recently.The outer insulation had perished and looked tatty.So I bought some sewing needles that are about 35mm long and quite thick and cut two in half.These were then Araldited into the coils where the lead normally exits.Once half set I pushed on some new lead cable and Araldited this into place.Once set I pushed heat shrink onto the new lead and shrank this in place with a hairdrier borrowed for the occasion when the wifes back was turned.
I would suggest four NGK SD05FGA plug caps
https://www.ngkpartfinder.co.uk/files/NGK_Spark_Plug_Covers.pdf
Always have a 'Plan B'
The last post was made 14 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 41.02 Kb
