GSXR 1000 K2 Service
TERRYREBEL
PostPosted: 00:53 - 22 Dec 2011    Post subject: GSXR 1000 K2 Service Reply with quote
Hello all got a GSXR1000 2002 model with 17k miles and ive been quoted 400 quid for a service and i think thats a bit much any ideas if im getting mugged off
Did have a Bandit 600 now i have another 1 lol i love the bandit
bunglebubs
PostPosted: 01:31 - 22 Dec 2011    Post subject: Reply with quote
I got quoted £169 for the service on my GSXR '08 750 from the Suzuki dealership so I would say yeah you are being mugged off as you put it.
Unless they are going to do some major inspection on valves rockers etc Wink
899 Panigale, K7 GSXR 750
UrbanRacer
PostPosted: 01:53 - 22 Dec 2011    Post subject: Re: GSXR 1000 K2 Service Reply with quote
It is expensive, what's in the service? i assume valve clearances will be getting done at that price. for a major service your looking at 300-350
PostPosted: 10:57 - 22 Dec 2011    Post subject: Reply with quote
Every 16k is valve inspection and adjustment.
Thats where your price is coming from. I've got the Haynes for this so can let you know what else is done if you need.
evoboy
PostPosted: 12:31 - 22 Dec 2011    Post subject: Reply with quote
£300 -£400 sounds about right for a major service.
£169 sounds like a rip for a minor service considering its just a general look and lube and an oil and filter change. 1.5hrs MAX.
APT Motorcycles
TERRYREBEL
PostPosted: 12:42 - 22 Dec 2011    Post subject: hi Reply with quote
yer its the main valve service i want them done for piece of mind but another garage said thy wont need doing and will charge 250
PostPosted: 12:48 - 22 Dec 2011    Post subject: Re: hi Reply with quote
You'll know if they will need doing. Mine haven't been done and its at 36k. Should have been done around 30-32. Little tappy on cold start but when warm is quiet as a mouse.
Basic service is oil and filter, coolant, general check and lube. Can DIY for about £40.
evoboy
PostPosted: 15:02 - 22 Dec 2011    Post subject: Reply with quote
bucket and shim engines normally get quieter/tighter as they wear to the point they burn the valves out.
Screw and locknut engines normally get louder and looser as they wear.
Most modern sportsbikes will be bucket and shim.
APT Motorcycles
PostPosted: 15:16 - 22 Dec 2011    Post subject: Reply with quote
GSXRs are buckets, definitely.
Mine is pretty noisy when cold...so I'll just leave it how it is Laughing
DrDonnyBrago
PostPosted: 18:04 - 22 Dec 2011    Post subject: Reply with quote
Valve clearances on shim under bucket is a pain in the cock. Takes lots of time as the tank, airbox, probably fairings, rocker cover, probably throttle bodies etc etc needs to come off just to check. Time = labour = money.
If they need adjusting then it is cams out, buckets out, shims out then reinstall and recheck. Shims aren't cheap either, from a dealer £3-4 each at a minimum, if they are installing them for you then probably double that.
bunglebubs
PostPosted: 00:07 - 23 Dec 2011    Post subject: Reply with quote
That was them picking it up taking to their garage and bringing back again. Yes sure I could do it myself for cheaper but it won't keep the service history book stamped and the waranty though will it?
DrDonnyBrago
PostPosted: 00:13 - 23 Dec 2011    Post subject: Reply with quote
No, but after 10 years it becomes economically viable to service it yourself.
New sports bike retain more value with a FSH than it costs to service them, old ones cost considerably more to service than the FSH adds to the value.
It would make sense to do your servicing yourself by this point.
bunglebubs
PostPosted: 00:19 - 23 Dec 2011    Post subject: Reply with quote
Yeah thats why my '08 gets serviced at a garage and my '01 is done by myself
hornetmike
PostPosted: 00:49 - 23 Dec 2011    Post subject: Reply with quote
This is very true, I now know.
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
The last post was made 14 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 81.26 Kb
