Very quick qustion about engine braking vs coasting
B10Hazard
PostPosted: 18:19 - 23 Dec 2011    Post subject: Very quick qustion about engine braking vs coasting Reply with quote
If were to be going down a 3 mile stretch of downhill road. What would be more fuel efficient, rolling with clutch in or rolling with engine braking.
I say this as i do a lot of down hill riding on the way to work and a thread on hear that iv just read got me thinking as i always coast with clutch in, and someone on hear ses its better to not coast for fuel economy ?
No longer any socks
wilz1234
PostPosted: 18:25 - 23 Dec 2011    Post subject: Reply with quote
If your bike is fuel injected then engine braking will give better efficiency as the ecu knows not to put fuel in.
However if it has carbs then when you lift off, itll still be sucking some air through the carbs and therefore using fuel.
wilz1234
PostPosted: 18:26 - 23 Dec 2011    Post subject: Reply with quote
And if its fuel injected, if you coast it has to put fuel in to keep the engine running
iooi
PostPosted: 19:05 - 23 Dec 2011    Post subject: Reply with quote
If having the clutch pulled in means you have use your brakes, then it will be costing more in brake pads/disks than it would in fuel.
PostPosted: 19:13 - 23 Dec 2011    Post subject: Re: Very quick qustion about engine braking vs coasting Reply with quote
As above - on an FI vehicle, go for top gear and throttle off if you can. No fuel will be used.
You can consider flicking the engine off with the clutch it, at which point you should also use no fuel.
B10Hazard
PostPosted: 19:15 - 23 Dec 2011    Post subject: Reply with quote
I get what your saying Thumbs Up
Looked how ecu's work for the past 45mins. My cbf 125 is the first fuel injected bike iv owned. Very good so far..
So basically on a all my down hill rides ( when im low on fuel or feeling economic ) its best to sit in 5th with the engine dragging going slightly slower than to roll with the clutch in braking at the bottom of this humungous hill i go down everyday ?
Rolling with the clutch in at 60 i will not be doing less than 50 at the bottom. In 5th doing 60 then revs off letting the engine drag i would be going very slowly by the bottom maybe having to even re aply the throttle Confused now i have explained the hill im sorta wondering how that would save fuel ?
EDIT: So is riding my bike with the engine dragging using less fuel to what my bike would be using sat still on idle ?
No longer any socks
iooi
PostPosted: 19:52 - 23 Dec 2011    Post subject: Reply with quote
Look at it this way. The diffrence between either way is going to be next to nothing on your 125.
You will save far more by smooth riding, reading the road ahead, so you don't have to use the brakes.
B10Hazard
PostPosted: 20:17 - 23 Dec 2011    Post subject: Reply with quote
I have one of the most economic bikes on the road anyway so im not to fust . Just asking because i seen a debate in a another thread and it got me thinking. How that shit works etc
My usual approach to this massive hill is flying down it as im always late
No longer any socks
Frost
PostPosted: 20:19 - 23 Dec 2011    Post subject: Reply with quote
Clutch in and roll. On a carbed bike it will continue to pull a little fuel through. If it's FI it won't but either will cause engine breaking and slow you down, but rolling will only have road friction and air resistance.
PostPosted: 23:24 - 23 Dec 2011    Post subject: Reply with quote
The gixxer K7 fuelmap says that it's just not the case that fuel is shut off on coast-down.
goto10
PostPosted: 14:04 - 24 Dec 2011    Post subject: Reply with quote
It probably varies between cars/bikes/manufacturers. I read that OBDI shuts fuel down on petrol cars when coasting but OBDII doesn't unless the cat is a certain temperature and the revs are above a certain point. I remember Clarkson doing a test on a diesel some time ago and he said then about the fuel shut-off when coasting (on that particular model), it was after that was on TV that I noticed everyone saying this was the case with every FI car/bike (I'm guessing it wasn't)
But either way, even some fuel is still being used, it won't be much different to idling so you'd be better off keeping it in gear rather than dipping clutch.
EazyDuz
PostPosted: 14:37 - 24 Dec 2011    Post subject: Reply with quote
when i stop pressing the throttle in my FI car, my Torque app MPG in real time shoots up to something silly like 400 mpg, but i still believe if im going down a steep hill that neutral would wor out better for fuel economy.
bazablue
PostPosted: 20:12 - 24 Dec 2011    Post subject: Re: Very quick qustion about engine braking vs coasting Reply with quote
never coast ...you are not n control if you do and t wears yer clutch out pdq...uote="B10Hazard"]If were to be going down a 3 mile stretch of downhill road. What would be more fuel efficient, rolling with clutch in or rolling with engine braking.
I say this as i do a lot of down hill riding on the way to work and a thread on hear that iv just read got me thinking as i always coast with clutch in, and someone on hear ses its better to not coast for fuel economy ?[/quote]
early view
kestrel
PostPosted: 20:20 - 24 Dec 2011    Post subject: Reply with quote
Worth noting that long periods of engine braking on a two stroke that runs pre-mix can cause serious engine damage. With the throttle closed there is only a small amount of fuel/oil mix being drawn through the carb so engine lubrication is greatly reduced.
Isle of Man.........Road Racing Capital Of The World
EazyDuz
PostPosted: 22:07 - 24 Dec 2011    Post subject: Reply with quote
Is there anything good about 2 strokes? Because from everything ive read they are an expensive waste of time.
PostPosted: 22:18 - 24 Dec 2011    Post subject: Reply with quote
By what measure?
Is that a standard map N30?
I know for a fact that 2006 to current FZ1s give you no fuel on cost down.
PostPosted: 22:32 - 24 Dec 2011    Post subject: Reply with quote
Seen the mpg go to 999 or similar on plenty of fuel economy listings on various vehicles.
They are faster, lighter and more fun on average - having more power means that they can have more low down power in some situations too.
EazyDuz
PostPosted: 23:08 - 24 Dec 2011    Post subject: Reply with quote
Big_Ham wrote:
By what measure?
I dunno just an Astra G.
for example, there is a road i sometimes go down at 60mph, neutral it, and roll approx 1.5miles all the way to the bottom, the hill isnt steep at all, if i was engine braking i would roll maybe a quarter of the way, and use throttle for the rest of it, which is obviously going to use a lot more fuel than an idling engine which gets me all the way to the end.
PostPosted: 23:10 - 24 Dec 2011    Post subject: Reply with quote
six of one, half a dozen of the other.
To be fair doing either or probably has far less of an impact than your overall driving habits. Half a mile of coasting here and there clutch in or out probably has little effect.
EazyDuz
PostPosted: 23:22 - 24 Dec 2011    Post subject: Reply with quote
Not denying that just giving my experiences about the original question that was asked.
Noxious89123
PostPosted: 23:25 - 24 Dec 2011    Post subject: Reply with quote
They go like the clappers and smell gorgeous!
PostPosted: 12:00 - 25 Dec 2011    Post subject: Reply with quote
Yep, major down side to pre-mix.
In such a situation you would probably be better using a tiny bit of throttle an leaving it in gear with the clutch engaged.
EazyDuz
PostPosted: 17:33 - 25 Dec 2011    Post subject: Reply with quote
Doubt it. The hill at half way requires more than a little bit of throttle so it uses a lot more fuel than the momentum of a the car with no engine braking.
drzsta
PostPosted: 17:57 - 25 Dec 2011    Post subject: Reply with quote
The day I start worrying about coasting to save fuel will be the day I give up, not like you can get the front up with no throttle Twisted Evil
PostPosted: 18:04 - 25 Dec 2011    Post subject: Reply with quote
Maybe not, but always impressed by people that can keep it up 'coasting' Smile.
The last post was made 14 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 130.97 Kb
