Battery charging options without a garage?
c-m
PostPosted: 21:51 - 25 Dec 2011    Post subject: Battery charging options without a garage? Reply with quote
A number of bikes have costly issues with damaged sprag clutches if started when the battery is low. Most notably the Sprint ST 955
Obviously that not an issue if you have a garage or private storage for your bike where you can hook up a charger or an optimate, but what are the options if your bike lives out on the street?
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
Moo.
PostPosted: 21:57 - 25 Dec 2011    Post subject: Reply with quote
I just had to deal with this, i took the battery out and its currently inside my utility room charging.
Alternatively, if you buy the current classic motorcycle mechanics mag, theres an article on solar power charging your bike. It said they could use a solar power panel (On offer £10 from maplins) to supply a charge to their bike. Said it charged even when the sun wasnt out.
https://www.maplin.co.uk/12v-2w-solar-briefcase-348075
This is the one they show in the mag
Hth Very Happy
A2 Passed 18/6/10
c-m
PostPosted: 22:03 - 25 Dec 2011    Post subject: Reply with quote
I did think about creating a solar array. Al the ones i've seen use hard panels though. something flexible that could sit behind screen would be better.
I haven't seen anything like it though. How would you go about leaving a hard solar panel on a bike parked in the street?
PostPosted: 22:32 - 25 Dec 2011    Post subject: Re: Battery charging options without a garage? Reply with quote
Take the battery inside to charge it?
Shouldn't be an issue with a decent condition bike/battery however.
c-m
PostPosted: 22:40 - 25 Dec 2011    Post subject: Re: Battery charging options without a garage? Reply with quote
It shouldn't but from reading around it is an issue. One can't take the battery out every day or after every ride, that's crazy.
PostPosted: 22:51 - 25 Dec 2011    Post subject: Re: Battery charging options without a garage? Reply with quote
If the battery is going low between rides, surely it'd be better to address that issue it's self, rather than trying to use the sticking-plaster of keeping it on charge?
A decent nick battery shouldn't lose any significant amount of charge really, I'd have thought.
c-m
PostPosted: 23:22 - 25 Dec 2011    Post subject: Re: Battery charging options without a garage? Reply with quote
Take the Aprilia SL1000 Falco - it produces less than 13v at idle and even less at 4k - that can't be good on the battery for everyday riding.
A decent charging system would be producing over 14v
Chris750
PostPosted: 00:35 - 26 Dec 2011    Post subject: Reply with quote
There are solar chargers out on the market for bikes.
We do this one
https://www.amazon.co.uk/OXFORD-SOLARISER-SOLAR-BATTERY-CHARGER/dp/B000R593JW
For the price you could probably rig your own one up using bits from Maplins and such.
We have done them for some time and we sell a few of them so they must be popular for people in similar circumstances.
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
andys675
PostPosted: 00:44 - 26 Dec 2011    Post subject: Reply with quote
buy a few 2.5m optimate extension cables and keep the optimate inside, I've found I can run the extension cable out the window and still close the window as the cable is flat Thumbs Up
PostPosted: 00:48 - 26 Dec 2011    Post subject: Re: Battery charging options without a garage? Reply with quote
And thus people often sort out the wiring to do the job it should, which to me seems to be a much more sensible proposition:
https://apriliafalco.hadeler.net/index.php/falco/article/rewiring_the_falco_for_improved_charging/
Walloper
PostPosted: 02:09 - 26 Dec 2011    Post subject: Reply with quote
I didn't know the Sprag Clutch on ST955 failed if the battery was flat.
My bike had two clutches fitted but never a fault with the battery. 1y old and 18 months.
It's not the battery it's the shit quality of some bits on the Triumph.
I can testify to this as I had two one after the other and would never go near another.
I had a solar charger on my car as I never used it very often.
The charger fooked the battery.
I don't know why but I think due to the constant dribble it sulphated.
Perhaps I needed to load the battery more often.
Solar chargers don't stop charging I think they just drop off to very very very low output.
And due to light levels voltage would vary too I guess.
I use for my phone when camping but not for my car or bikes now.
Crying or Very sad
c-m
PostPosted: 09:55 - 26 Dec 2011    Post subject: Re: Battery charging options without a garage? Reply with quote
Excellent link.
You're right of course. There seems to be one for the Sprint ST too.
That's fine i guess if you're running a an alarm. That Oxford one looks nice and compact.
PostPosted: 10:49 - 26 Dec 2011    Post subject: Reply with quote
If you're going to use a solar charger, I'd suggest disconnecting the battery +ve lead if the bike has any electronics in it. I had one hooked up to my car while it was sitting up for a few months, and on starting it up, the central locking electronics were spazzed. I can't prove causation, but I wouldn't take the gamble again.
The last post was made 14 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 81.34 Kb
