multimetre help
hadden
PostPosted: 19:47 - 26 Dec 2011    Post subject: multimetre help Reply with quote
hi all.just bought this off flee bay as alot of people on here advise to get one.the only thing is how the bloody hell do you use em??if someone could just tell me what setting it needs to be on for 12v and what to expect from certain wires?
https://www.ebay.co.uk/itm/160665640289?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_2467wt_764
that is all Smile
red bull gives you wing sting!!!
current:aprilia rs 125
previous:honda c90,honda cm 125,yamaha xt 550,2004 suzuki drz 400.(all used for off road back in the day)and a piagio zip 50cc..oooossssshhhh
Ichy
PostPosted: 19:54 - 26 Dec 2011    Post subject: Reply with quote
All comes down to what your checking for. For voltage you need to turn to the 20v bit, third one turning the dial counter clockwise or about 10 o'clock.
The other useful one is the red bit at roughly 5 o'clock on the dial,looks like a speaker?, that's continuity, it's useful for checking for breaks in the wire.
Finally, the green bit between 6 and 9 o'clock is resistance, useful for checking coils and plug leads.
hadden
PostPosted: 21:31 - 26 Dec 2011    Post subject: Reply with quote
right ok mate. thats all i needed to know.thanks for that
Ariel Badger
PostPosted: 22:25 - 26 Dec 2011    Post subject: Reply with quote
You need the black lead in the socket marked com and the red in the one marked v (ohm sign) mamp for most work.
Bezzer
PostPosted: 23:45 - 26 Dec 2011    Post subject: Re: multimetre help Reply with quote
Read the instructions it says it comes with before you try to use it. It's not marked/set out very good, as said DC voltage is the white area 10 o'clock ish that you use for any voltage checks from the reg/rec- battery onwards but you do use AC voltage as well to get the output from the alternator/stator to the reg/rec that is the white area at 1 o'clock, you want the 200v setting for that.
Walloper
PostPosted: 16:56 - 27 Dec 2011    Post subject: Reply with quote
RTFB
Read the Fcuking Book.
Have fun.
The last post was made 14 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 48.04 Kb
