Back wheel removal - twist & go
Andy_Pagin
PostPosted: 14:52 - 26 Dec 2011    Post subject: Back wheel removal - twist & go Reply with quote
Back tyres punctured, how hard is it to get the back wheel off? It's a Yamaha Vity scooter.
at106
PostPosted: 20:41 - 26 Dec 2011    Post subject: Reply with quote
On most scooters there is a nut on the back wheel ( opposite side to transmission) which you undo, then the wheel will be removable. To get it completely off it's likely you'll have to remove the exhaust.
haroman666
PostPosted: 14:08 - 27 Dec 2011    Post subject: Reply with quote
^^^^ +1
Both my scooters were a case of removing exhaust and then a single nut in the centre of the wheel.
If you haven't got access to an air-line and impact gun, then just hold the back brake to crack off the nut.
Andy_Pagin
PostPosted: 15:30 - 27 Dec 2011    Post subject: Reply with quote
Thanks guys, all done and dead easy.
Not knowing how twist & go boxes work I was just worried that lots of little spring loaded thingies were going to sproing out when I pulled the wheel off. Confused
Marmalade
PostPosted: 16:04 - 27 Dec 2011    Post subject: Reply with quote
Think yourself it's not a Piaggio X9
Right hand panel off
Exhaust off
wheel nut undo
Brake caliper off
4 bolts/allen keys out
right hand bracket/plate thingy off
remove wheel
simples
Thumbs Down
The last post was made 14 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 44.33 Kb
