| MattJ |
 MattJ World Chat Champion
| andys675 |
 andys675 World Chat Champion
| Kickstart |
 Kickstart The Oracle
| MattJ |
| molex |
 molex Renault 5 Driver
| Ariel Badger |
 Ariel Badger Super Spammer
| P. |
 P. Red Rocket
 Posted: 10:52 - 28 Dec 2011 Post subject: |
You can just use the Thundercat ones.
Even if it was slightly over, your bike will have lost a few ponies by now.
Is your bike absolutely standard. Flatmate has a 1992 GSXR750, gets big headed as it has a dyno print showing 126hp. Had his 33hp washers installed, still dynos around 36, thats from FI. Its down to the K&N, full D&D system and rejet.
My bikes were never 33hp... only had the restriction for a year anyway as was running around on a 125. But I had an accident when I was on my restriction and they didn't check then. I rode without them after regardless. Just don't be a dick, don't crash and don't do wheelies and they have minimal reason to pull you over.  |
| Kickstart |
| molex |
 Posted: 12:39 - 28 Dec 2011 Post subject: |
| Kickstart |
 Posted: 13:06 - 28 Dec 2011 Post subject: |
That is a specific model and fuel injected.
With a carbed engine if you restrict the air flow before the carb you will likely land up with a large intake vacuum drawing a lot of fuel from the carbs. Probably run very rich and badly, in much the same way it would if the air filter was very dirty.
If you try and stop the slide on a CV carb lifting then you will restrict the fuel more than the air. As such as high throttle / revs you strand a fair chance of running lean, which could easily hole a piston.
The washers after the carbs restrict the airflow, but being after the carbs they work in the same way as not opening the throttle fully. The carb will do its job normally and the mixture should be OK.
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| molex |
| Kickstart |
 Posted: 14:18 - 28 Dec 2011 Post subject: |
Those are not restricting or derestricting the bike. They are kits to adjust the fueling, normally to improve it. The gains are fairly small.
If you restricted the bike by stopping the slide from lifting you would need to develop a similar type of kit to the Dynojet one (but with different profile needles and main jet) for the fueling to be OK. The Dynojet kit itself would be pretty useless for this.
For someone in the UK on a restricted licence they need the bike to produce under 25kW (about 33hp) at the crank for it to be legal for them to ride. That is a very large amount of power to lose given that an early FZR is going to be over 80hp at the back wheel (if in good condition) with an FZR600R being probably 10hp up on that.
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 15:25 - 28 Dec 2011 Post subject: |
Buy the thundercat restrictors.
Fit them. Thunder cat uses 42mm carbs, hope the FZR has the same.
Then not worry about the rest. If you're really bothered get the bike dynoed and see what it comes out as and use this as proof the bike is restricted if stopped.
Washers make the bike run like shit regardless. They send the fuelling all over the place. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| MattJ |
| molex |
| P. |
 P. Red Rocket
 Posted: 20:00 - 28 Dec 2011 Post subject: |
You ride it as per normal.
Forget they are in there... just ride and forget about it  |
| Kickstart |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 20:40 - 28 Dec 2011 Post subject: |
| molex wrote: | Please download this two document read (kit. D |
Please stop posting misleading, illinformed information, & irrelevant external links; that prove only your own ignorance.
Please take note of Badger & Keith's comments, 'correcting' the potentially dangerous advice you have offered, and instead of asking US to read stuff, try reading up yourself on different types of fuel metering, engine design, and power theory! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Kickstart |
| MattJ |
 Posted: 22:51 - 28 Dec 2011 Post subject: |
Thanks for the very helpful replies. Shows how little I know about anything really.
I sent him an email a few weeks ago Keith, I think only a couple of days after I bought the bike which was the very beginning of December, but because I've not been in a rush I haven't sent another message yet. Thanks for messaging him on the Bandit forum.  |
| molex |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
 Posted: 07:06 - 29 Dec 2011 Post subject: |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 09:59 - 29 Dec 2011 Post subject: |
| molex wrote: | Mr. Teflon-Mike
“Misleading, information” are come from UK this company.
If you have any question please inform them how to operate thank you very much. |
FFS!
1/ You are NOT adding anything to the topic of value. We could all google restriction kits for ourselves IF we were interested.
2/ FI International have built thier business on 'snake oil' type dis-information; providing enough 'scientific reason' to sell thier products and make people BELIEVE they need them, without ACTUALLY telling the whole story, and DELIBERATELY mystifying the subject in order to HIDE the fact that ALL they are actually selling are over-priced penny washers.
They probably know more about power theory and fuel metering than I do, and I'm a fucking engineer, whose run test engines in the lab! They have NO interest in listening to me, even LESS changing thier sales blurb!
Meanwhile; YOU are providing DANGEROUSE suggestions, that could ruin some-one's engine!
TAKE NOTE: your HELP could 'help' some one get prosecuted for riding a bike they have no licence for; or 'help' them ruin the engine in thier 'pride & joy'.
Is this really a good idea?
You obviousely have enough knowledge to be dangerouse, but not enough wisdom to apply it safely.
HENCE: Consider Badger & Keith's comments; you do not have the expertise to be answering the OP's question; I suggest you try remidying THAT, rather than continuing to disseminate FI Internationals 'sales propaganda', to support your own, off the wall suggestions, to restrict a bike for UK Licence requirements with Blue-Peter sticky tape and glue! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Kickstart |
 Posted: 11:37 - 29 Dec 2011 Post subject: |
Not sure what a Japanese market 250 Bandit has to do with things, but if you read those you will see how the CV carbs work. The slide rises with the air flow (pressure of the air in the carb compared to atmospheric pressure moves the slide), and this lifts the needle. The slide shouldn't be limiting the air flow, that is the job of the throttle. So if you limit the amount the slide can lift you limit the needle, hence it cannot supply the fuel required when full throttle is being used.
When setting up carbs quite a few things can be changed, and Dynojet type kits do supply the bits to do this for an engine in a reasonable level of tune. With these kits the needle might change, the spring above the slide might change and the air hole into the slide might change. The needle directly changes the mixture, the spring controls how far the slide moves for a certain difference in pressures while the hole in the slide controls how quickly the slide moves. Dynojet spend quite a bit of time and effort on each individual model of bike experimenting to find out what works. Just bodging up one of these areas (such as just limiting the slides movement) is unlikely to work well and can easily result in the engine running dangerously lean in certain situations.
As to FI kits, virtually none of there kits do work by limiting the movement of the slide and entirely possible that of the few that do they also supply a different needle for some of them. Either way I would be pretty certain that they have done testing on that particular model on a dyno to check that not only is it producing 25kW but that the mixture is safe.
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 21:31 - 29 Dec 2011 Post subject: |
FI International restrictors for my bike were a set of washers and some short sections of plastic tube to sit ontop of the diaphragms to stop them lifting all the way. No change of needle.
But still, I think molex is talking shit. It's just not as simple as slapping something together. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
The last post was made 14 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
