Uncontrollable revs !
swampy
PostPosted: 16:34 - 16 Sep 2004    Post subject: Uncontrollable revs ! Reply with quote
Hey folks, I have a Nsr 125r, and it seems to be misbehaving. When I start it up the revs rise to over 5000 (no choke or throttle) they then die down a tad, however when I give it a rev once warmed up they stick at around 5000 again. I've checked the throttle slide, and that seems to be tickety boo. The only way I can control the revs is by applying the choke, which perversely drops the revs, however if I pull the choke out all the way, the bike stalls. I'm pretty sure the mixture/idle are set Ok. Having read other posts, i'm guessing it may be an air leak, but would appreciate some pointers. Thanks folks.
PostPosted: 17:01 - 16 Sep 2004    Post subject: Reply with quote
As long as you are happy with the throttle action then it is almost definatley an air leak rount the inlet manifold area somewhere. If the engine revs up when you spray WD40 on the outside of this area that confirms it. I'd imagine there are a few gaskets, o-rings and bits of rubber involved with an NSR inlet manifold, one of these would most likley be at fault.
mr jamez
PostPosted: 18:40 - 16 Sep 2004    Post subject: Reply with quote
There is a single paper gasket for the inlet manifold, so it shouldn't be too hard to find the leak Smile
PostPosted: 22:27 - 16 Sep 2004    Post subject: Reply with quote
The rubber manifold for the carb can crack which will lead to a major air leak.
Also the main bearing seals can fail resulting in this problem.
loply
PostPosted: 22:44 - 16 Sep 2004    Post subject: Reply with quote
Why would an air leak cause it to rev higher?
PostPosted: 22:52 - 16 Sep 2004    Post subject: Reply with quote
More air into the engine, just like when you open the throttle.
swampy
PostPosted: 00:22 - 17 Sep 2004    Post subject: Reply with quote
Cheers for the help so far guys, Ive checked over the manifold, and it looks ok. Keith where are the main bearings seals located ? Thanks... Very Happy
PostPosted: 00:31 - 17 Sep 2004    Post subject: Reply with quote
Around the ends of the crank. Not easy to see. On the o/s it will be under the clutch casing and obscured by the primary drive (although if this one goes the bike will use gearbox oil). The n/s one is under the ignition system.
swampy
PostPosted: 09:45 - 17 Sep 2004    Post subject: Reply with quote
Bugger, fair bit of stripping down involved then Crying or Very sad ! Better get me spanners out lol
PostPosted: 13:55 - 17 Sep 2004    Post subject: Reply with quote
Be very certain that you have eliminated all the other possible causes first before you go to the extent of replacing those seals.
If it is a crankshaft seal then it is most likely the one under the ignition, and that should be fairly easy to replace without dropping the engine.
ZRX61
Victor Meldrew
PostPosted: 17:18 - 17 Sep 2004    Post subject: Reply with quote
Sounds like the throttle cable isn't seated correctly in the carb.... no need to strip the engine as some people suggest just yet.... Rolling Eyes
& from the way you describe it, it sounds like you may be operating the choke backasswards....
swampy
PostPosted: 18:05 - 17 Sep 2004    Post subject: Reply with quote
Okey doke, I think the throttle cable is ok as I can see the slide going up and down in response to turning the grip, and I assume that applying the choke lifts a slide in the carb, at least thats whats happening in my case. I cant start the bloody thing now, so I haven't had a chance to test anything out. Theres compression, and a spark, and when I pull the plug out it appears to be wet with petrol/oil, anyone have any ideas why it might not be starting that might be related to my previous problem ?? Cheers for the help so far guys. Thumbs Up
ZRX61
Victor Meldrew
PostPosted: 20:22 - 17 Sep 2004    Post subject: Reply with quote
It's getting air from someplace.. the usual test is to spray WD40 around the carb boots & intake rubber manifold doohickies etc. If the revs increase you have a leak.. but you're already at 5000rpm...
alains
PostPosted: 23:09 - 17 Sep 2004    Post subject: Reply with quote
what says your petrol consumption ? i am thinking about the carb tank needle stocked or a bad level . also if do or undo the pilot screw , has this an effect ? set the pilot screw thight and undo 2 1/2 turns
PostPosted: 23:43 - 17 Sep 2004    Post subject: Reply with quote
Ok, a silly one but I have seen it done. You put the throttle slide back in the right way round? the cutout should face the air filter.
alains
PostPosted: 23:54 - 17 Sep 2004    Post subject: Reply with quote
good shot , i've forget this one !
swampy
PostPosted: 01:02 - 18 Sep 2004    Post subject: Reply with quote
Yeps the throttle slide is in the right way, there's a notch in it so it will only go one way round, will double check tomorrow though. Thanks for the thought though, I wouldn't be surprised if I've done something that stupid ! Thumbs Up
swampy
PostPosted: 18:03 - 18 Sep 2004    Post subject: Reply with quote
Ok, well the plot thickens.... I took the carb apart today and gave it a thorough blasting with an air gun. I then checked the plug again, it turns out that this wasn't working (it was arcing between the bottom electrode and the chassis) Stuck another plug in, and she fired up. I then had the original problem of over revving, so I took your advice and gave the intake manifold a go over with Wd40, and about two sec later she stalled. Cue trying to start, and it cutting out when I gave it any throttle. I then noticed that the tank was a little low, and switched to reserve. Now she is running OK with no over revving. I'm not moaning but does anyone have any ideas why this might have solved the problem for the moment ??
alains
PostPosted: 19:53 - 18 Sep 2004    Post subject: Reply with quote
you've certainly a dirty tank . make it empty , take off the tap , clean the filter . it happens also that water vapor condense in the tank or bad petrol services (when they got empty) . as water has more density than petrol it goes down in the bottom and more quickly in the carb . if you have filled it up , do this even it's bowring . in addition when it will be empty put a piece of clean clothe on an iron wire to clean all dusy & mud
alains
PostPosted: 19:54 - 18 Sep 2004    Post subject: Reply with quote
i forgot (if you have not already do that) you must open the carb and clean the tank of water & mud
The last post was made 21 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 107.42 Kb
