Why are they?
kevotore75
PostPosted: 19:50 - 31 Dec 2011    Post subject: Why are they? Reply with quote
Why do some Cg125's have square headlights? and could i change it for a round one without having to piss around too much??
Thanks
salty21
PostPosted: 20:04 - 31 Dec 2011    Post subject: Reply with quote
shouldnt be hard at all, i'd imagine just buy a round one at the right diameter and swap em over. Youd have to repack the loom in there though which can be a bit of a squeeze if you dont get the connectors packed in well. Dont know why you'd bother though, the square one suits it better IMO
Teflon-Mike
tl;dr
PostPosted: 02:37 - 01 Jan 2012    Post subject: Reply with quote
As far as I know, the ONLY 'genuine' CG125 to have a square headlamp is the Japanese Home Market 'Nostalgia' model.
The square headlamp is kind of a defining feature of the model, that got a number of other detail changes, like a rev-counter, not normally found on the serial production CG's.
The CG was designed to be made in the Brazilian Satalite plant; and was never in serial production in Japan; as far as I know, they merely did the 'early build' there to stabilise the production process before moving it to Brazil, then copying it to other satalites around the world to meet production demand.
The Japanese 'Nostalgia' model was then built IN Japan, for the domestic market only; hence any that are in captivity here in the UK are 'Grey-Imports', and will probably have a big difference between date of manufacture/first use, and date of UK Registration, on the V5/Log-Book.
This does effect insurance; becouse you have to declare that its NOT a UK model, not that it should make huge difference.
Reccompense is that CG afficionado's reckon that they have the best build quality, and may be a tincy-wincy bit faster.... though if that really mattered you wouldn't be buying a CG!
Personally, If I was buying a CG, wouldn't make an iota of difference to me, whether it was a Japanese Nostalgia model or a contemprary plastic body BRazilian 'Duel-Start' or whatever....
What would matter was price and condition.
They have a tendancy to become victims of thier own reputation; ridden into the ground in the belief that they really ARE indestrictable, and 'low-maintenence' means NO maintenence.
As for the headlamp; the illumination from a low wattage bulb, powered by a low out-put generator on a typical lightweight is RARELY going to be 'wonderful'.... and the shape makes bog all odds to that!
And experience tells me that swapping a good 'stanley' lense for a round generic aftermarket one, is likely to be a retrograde 'improvement'..... so I would leave the thing as is!
PostPosted: 02:53 - 01 Jan 2012    Post subject: Re: Why are they? Reply with quote
Pretty sure I mentioned this in chat; thought it was you asking?
There was a batch of cheap import bikes from some asian market which were slower, had 4 not 5 speeds and the square head light.
This was before chinese bikes were big; they were doing the rounds been sold at various cheapish 'bargain' prices, usually not disclosing they were lower spec.
johnsmith222
PostPosted: 03:42 - 01 Jan 2012    Post subject: Reply with quote
Not too sure what you mean by genuine, but the CG125W 1998 to 2000 brazillian model definately had a "square" headlamp oem.
Whoreage:
https://i14.photobucket.com/albums/a324/david_m213/CG125W.jpg?t=1317853796
BTW, square headlights are cooler.
tomh
PostPosted: 06:55 - 01 Jan 2012    Post subject: Reply with quote
The CG125W (98-00) and M1 (01-03) models all had the rectangle headlight when production moved to Turkey.
I personally prefer the look of the round headlight and would be interested if anyone knows if I can just buy the round light for the other CG's and it will just fit in the same mounting brackets?
PostPosted: 06:56 - 01 Jan 2012    Post subject: Reply with quote
Whoreage:
But came without an engine Shocked . I think I'd rather the round headlight with engine model Razz
multijoy
PostPosted: 19:02 - 01 Jan 2012    Post subject: Reply with quote
I was sitting looking at that picture trying to work out what was a bit odd. Moral of the story, don't take me to look at bikes if you want a runner!
The last post was made 14 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 60.47 Kb
