| gray84 |
 gray84 World Chat Champion
 Posted: 20:14 - 02 Jan 2012 Post subject: 2stroke head problem??? |
Hey everyone need a bit of help please..
My step dad has bought a 2001 cr125 to come out with me and we bought it knowing the head was on its way out..
When we got it and ran it it all runs fine but on the ns head gasket it had 1 specific area where a droplet of coolant would trickle out of very slowly.
We took the head and cylinder off and had it skimmed also had new piston ect while it was off.
Anyway we put it all back together using a non genuine Honda gasket and it's the same still a tiny trickle in the same place.
Went and got new studs/nuts and genuine Honda gasket and just put it back together and it's the fucking same lol..
Now it seems to seep from the top part of the gasket as you can see in the pic and video so I'm thinking a pores/cracked head? You can't see any mark AT ALL.
What do you think?
https://i61.photobucket.com/albums/h62/graygti/e62fd5ba.jpg
https://i61.photobucket.com/albums/h62/graygti/th_ee892e65.jpg ____________________ Road bike - 2002 YAMAHA R6(SOLD) 2008 YAMAHA R1(SOLD) 2007 APRILIA SXV 550(SOLD) 2007 SUZUKI GSXR 600
Dirt bike - 1989 HONDA CR80sw(SOLD) 1996 YAMAHA YZ125(SOLD) 2006 yamaha yz250(SOLD) |
| gray84 |
| orac |
 orac World Chat Champion
| Mikey CB500 |
 Mikey CB500 Scooby Slapper
| gray84 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 22:57 - 02 Jan 2012 Post subject: |
| gray84 wrote: | Checked everything is clean so it all mates together nice. |
But if its leaking, it obviously isn't, 'mating' properly, is it?
Has head been skimmed?
Has the liner been been 'decked' to the barel?
If you have a leak, something isn't sealing; you have gone round the loop, of what could cause it, so if all has been 'done', then it's either hasn't been done right, or you are fighting black magic!
Has the engine been run since top end rebuild? If so, then could it be that you have tackled a symptom rather than a cause, and the head's been warped again, or the liner dropped or 'something'? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| gray84 |
| jimmyRS |
 jimmyRS Scooby Slapper
| gray84 |
| jimmyRS |
| gray84 |
| Ichy |
 Ichy World Chat Champion
 Posted: 14:34 - 03 Jan 2012 Post subject: |
They way the bead is forming suggests that there is some porosity in the head. It looks like the water is moving upwards because you are assuming that it's coming from the gasket area. To test it you can just try a small amount of exopy resin, or even tape, on the head just above the joint. If there is still water pooling then it's the gasket area if not then its the head. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| gray84 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:34 - 03 Jan 2012 Post subject: |
I'm with Marki; gravity defying droplets do suggests pourocity.
'the Black Magic'.... if all else is definitely eliminated.
Was the head vapour-blasted or chemically cleaned when it was skimmed by any chance?
If the metal is pourus, it tends not to just 'happen', its a casting flaw and will have been there since it was made, thouigh a fizure may have opened up through cyclic thermal fatigue.... expanding & contracting getting hot & cooling.
If you clean area with solvent and dry thoroughly and give it a wipe of epoxy of chemical metal, it might seal.
If it does though, it will be a semi-temperary fix. Better brazed, possibly with lumiweld or similar. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| gray84 |
| gray84 |
| kestrel |
 kestrel Nearly there...
| Ichy |
 Posted: 18:08 - 03 Jan 2012 Post subject: |
Just noticed you've listed your location as Staffordshire. If you fancy a trip to Crewe or Biddulph I have dye penetration that we can test your head with. I might even have a can of dye you can have.
A less accurate, and certainly not 100% reliable, homebrew detection is to spray the head with wd40 in the area you think it might be cracked. leave it for a few minutes and then give it a quick wipe with some solvent. when that's dry puff some talc onto the head. The wd40 that has got throught the leak should discolour the talc. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| jjdugen |
 jjdugen World Chat Champion
| gray84 |
| st3v3 |
 st3v3 Super Spammer
| jimspeed |
 jimspeed World Chat Champion
| gray84 |
| st3v3 |
 st3v3 Super Spammer
| Ichy |
The last post was made 14 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
