CBR600 wont start after exhaust repair :(
kramdra
PostPosted: 22:21 - 02 Jan 2012    Post subject: CBR600 wont start after exhaust repair :( Reply with quote
Last week a 2" hole appeared in exhaust downpipes, Ive done a tempary repair on it.
It turns over fine, battery has been re-charged after many attempts it just wont fire.
Fuel pump runs, it turns an I cant understand why there might not be spark or compression ! can smell fuel after many attempts.
After I noticed the exhaust, I have only took fairings off, then put clay, fiberglass and a baked bean can around the broken exhaust.
I did start it a couple of times without letting it warm up. And its kept outside in the rain.
Ive had the plugs out, they are clean, not wet. did not try spak test
groovylee
PostPosted: 22:34 - 02 Jan 2012    Post subject: Reply with quote
could it be the 'clay' has fallen off, and is now blocking the exhaust??
just thinking out loud
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
Formerly known as
P.
PostPosted: 22:43 - 02 Jan 2012    Post subject: Reply with quote
Check its sparking first.
Whilst turning it over see if you can feel gases being pushed out the exhaust.
I haven't seen many issues with these although seen some CBR posts pop up in relation to a crank or cam position sensor? This could stop it from starting... unsure how your exhaust bodge would have done that though.
bombom
PostPosted: 22:47 - 02 Jan 2012    Post subject: Reply with quote
You put fibreglass on your exhaust? Surly that will give off a lovely smell when you eventually get it running.......
Current: 97 zx6r f3
Previous: suzuki gsf400 bandit
DrDonnyBrago
PostPosted: 18:40 - 03 Jan 2012    Post subject: Re: CBR600 wont start after exhaust repair :( Reply with quote
When you say fairings off, do you also mean the front cowl?
There is a bank angle sensor in the front cowl, by the headlight. If unplugged then it stops the bike from sparking. If the front cowl is off and the harness unplugged, plug it back in.
The last post was made 14 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 43.12 Kb
