peugeot speedfight 100 does not like rain
banditride
PostPosted: 23:54 - 02 Jan 2012    Post subject: peugeot speedfight 100 does not like rain Reply with quote
my speedfight does not like heavy rain for some reason il be riding along wont get 1/4 of a mile before it bogs down and cuts out then is a bitch to start again will run at idle but no throttle leave it for a few minutes and its fine then ride off again and same thing happens. i havent got the pipe that goes from the airbox to under the fairing engine but i made a cardbourd tube clingfilm varient it helps but still does it i think its a carb problen my dad thinks its the throttle cable were clueless can anyone help.. does anyone know the default carb settings?
jimmyRS
PostPosted: 00:05 - 03 Jan 2012    Post subject: Re: peugeot speedfight 100 does not like rain Reply with quote
A friend on his speedfight 50 lacks a gasket for the tranny housing and he says water gets in and makes it a bitch to start/ride.
The pipe running to the airbox would be a big problem if your using this cardboard bodge. If any water gets into the mixture its really gonna mess up and give the symptoms youve described. Get a proper covered airbox and piping to feed to the carb. I had a foam filter on my RS50 and in the wet it gave similar symptoms except it would only stall on idle, but then again the positioning of the airbox on yours in the wet is far worse than the RS.
In short, get a proper feed to go from the airbox to the carb.
banditride
PostPosted: 00:12 - 03 Jan 2012    Post subject: Re: peugeot speedfight 100 does not like rain Reply with quote
i have the airbox fine there a pip that goes from the airbox to some random ass spot under the fairing next to the engine its obiously somethign to due wiht the rain but i honestly am clueless
jimmyRS
PostPosted: 00:15 - 03 Jan 2012    Post subject: Reply with quote
yeah airbox > carb > manifold > bottom end
Solution is still to replace that piping with the proper tubing Razz
Wouldn't be carb issues as you said it only happens when it rains Razz
they shouldn't be much to pick up, speedfights are common as anything so ring up some breakers or check on ebay Smile
banditride
PostPosted: 00:18 - 03 Jan 2012    Post subject: Reply with quote
but even with this carbourd bodge there was NOOOO way water was getting into the airbox i also forgot to mention it backfires when it cuts out. .. water getting onto electrics? as seen in pic missing tube from airbox to under fairing
jimmyRS
PostPosted: 00:21 - 03 Jan 2012    Post subject: Reply with quote
oh thats your problem, its a flourescent green monster rep! Wink
jokes aside, its not water getting into your air filter, its water getting into your carb. That would cause it to splutter/bog/backfire and would explain how its fine for the first 5 minutes, give or take, then cuts out.
if you wanna keep the cardboard bodge be my guest jus dont ask for a solution to a problem when you've already been told the answer
banditride
PostPosted: 00:55 - 03 Jan 2012    Post subject: Reply with quote
if you wanna keep the cardboard bodge be my guest jus dont ask for a solution to a problem already solved
the seal around the carb to the airfilter is pretty much fine
jimmyRS
PostPosted: 01:15 - 03 Jan 2012    Post subject: Reply with quote
the seal might be fine but what about the cardboard tubing?
n if you still really beleive that the bodge job isnt the problem, check n fit a new gasket to the tranny.
at106
PostPosted: 11:50 - 03 Jan 2012    Post subject: Reply with quote
The carb bodge may be the problem but it's unlikely, if it is the problem when you remove the air filter it will be damp.
The problem is most likely to be the spark plug getting wet, as it's directly infront of the rear wheel. From new they come with a plastic cover but this often falls out. You need to make some sort of rear mudguard to protect the spark plug from water. I used bike innertubes, but you could use lexan sheeting etc.
andys675
PostPosted: 14:15 - 03 Jan 2012    Post subject: Reply with quote
have you lost the flap that fits in front of the back wheel that stops water going over the top end?
banditride
PostPosted: 19:33 - 03 Jan 2012    Post subject: Reply with quote
the bodge isnt the problem its a short term solution it goes from the airbox to under the fairing its only use is to stop rain getting into the hole were the air goes into the air filter ill have a look witht he spark plug when i can it seems possible but i dont see how this would cause the bike to bog and die
at106
PostPosted: 20:00 - 03 Jan 2012    Post subject: Reply with quote
It's a common problem on peugeot scooters i beleive the water stops the spark so there's more fuel to burn.
duzzer
PostPosted: 20:23 - 03 Jan 2012    Post subject: Reply with quote
it is a common problem with the speedfights yes, most of the time it is the spark plug getting wet as it sits on top of the cil-head facing the wheel or its the wires under the fly wheel on the right side of the engine getting wet from the spray
but if theres no flap to protect the sparky from water you can make a flap from a old welly boot, and screw it on the end of the under tray between the sparky n wheel
for the electrics, use some vaseline or pertroliom jelly on every electrical conections you can see and get to
The last post was made 14 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 2.62 - MySQL Queries: 13 - Page Size: 80.73 Kb
