Pressure washing bike engine
MarkJ
PostPosted: 22:39 - 02 Jan 2012    Post subject: Pressure washing bike engine Reply with quote
Evening all,
It seems at some point my RSV has either had an oil leak and been ridden near the sea side, or been crashed into a sand dune - the engine has always been caked in an oil/sand mixture all over it. It's not just a light sprinkling either, the front cylinder had a big pile of sand what must have been about 10mm deep near the spark plug cap!
I was originally going to drop the engine out to clean it all, but I can get my hand to most of the engine. As I've taken the radiators, oil cooler & tank, petrol tank and airbox & throttle bodies off I can see the parts I can't get my hands to. I was wondering if I could pressure wash the engine as I've seen many videos on youtube of people doing this to their car engine bays. I would obviously have to cover up the intake and any open hoses. If this is likely to mess up electrical connectors are there any other products I could use? It'd have to be a pretty decent degreaser.
The gap between the two cylinders:
https://i44.tinypic.com/fv94ap.jpg
Front spark plugs. It looks wet because it's covered in white spirit:
https://i43.tinypic.com/11jua12.jpg
Thanks Thumbs Up
1cyl
PostPosted: 23:29 - 02 Jan 2012    Post subject: Reply with quote
https://www.binbin.net/photos/unbranded/gun/gunk-733-gunk-automotive-brush-on-1-litre.jpg
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Pie-Roe
PostPosted: 23:32 - 02 Jan 2012    Post subject: Reply with quote
When I had 4 bikes at onces I used to wash them once a fortnight with cillit bang/commercial kitchen chemicals. I'd spray them with the stuff, and then pressure wash off, vaguely avoiding bearings and thats about it. Regrease chain, done.
Walloper
PostPosted: 23:40 - 02 Jan 2012    Post subject: Reply with quote
Engines get absolutely soaked in normal use. Heavy rain for hour after hour and puddles blasted into all places as you ply the road.
I am not one bit afraid to use a pressure washer on a well maintained engine.
I would not spend too much time directing the jet at sensitive areas though. i.e. Shaft seal areas and loom connectors/electric boxes etc.
Clean only the bits that are manky with full direct pressure.
I have used all cleaners and they are all shite at doing what they say on the tin/plastic container.
Petrol works but is a bit risky.
Gunk is good but if used and left to work then washed off you realkly need to let the parts dry before applying more Gunk again as it is water soluble and would be neutralised/less efficacious by any moisture.
Hein Gericke sell a gel that works as good as any of the others and I found it more effective as far as cost is concerned.
The Sand you have found is more than likely road grime. Sand is a component of tar Macadam so it finds it's way onto anything used on the road.
Baked on tar/engine oil is the most difficult to remove but I use petrol and a toothbrush/parts cleaner brush to do these bits firstly before the other compounds.
Warning:
It sounds like it was owned by some sort of Pre-historic humanoid before so you will make somewhere very dirty cleaning off the accumulation of shite.
The secret is to repair your oil leaks, keep the bike clean and use a protectant like AC50 or Scottoiler 365 between washes and after dirty rides.
Acemastr
PostPosted: 00:12 - 03 Jan 2012    Post subject: Reply with quote
You'll generally find the pressure washers you see people spraying over car engine bays are paraffin, that will get rid of all the crap and won't hurt the engine, not entirely sure what it will do to plastic though
2016 Toyota Tacoma Limited
james1988
PostPosted: 01:28 - 03 Jan 2012    Post subject: Reply with quote
Last time I washed the bike I used Autoglym Motorcycle Degreaser. It comes in an aerosol can and it gives a pretty good blast. Leave it to dwell for a few minutes while you make a brew and wash it off. I found it was quite good. It removed most of the crap that was baked on but left a little although I strongly suspect another blast with it when I wash the bike next will clean it completely.
James
wilz1234
PostPosted: 02:11 - 03 Jan 2012    Post subject: Reply with quote
Go to tool station, spend about £2-3 quid on a can of carb cleaner, and spray it on, then wash off
MarkJ
PostPosted: 16:55 - 04 Jan 2012    Post subject: Reply with quote
Thanks all, I've got some Cillit Bang lying around so going to give that a go, if that doesn't work will try all the others Thumbs Up
pits
PostPosted: 17:28 - 04 Jan 2012    Post subject: Reply with quote
Yes a bloody good idea, cover your bike in acid Thumbs Up Rolling Eyes I am sure your engine, fairings and anything else the sulfamic acid and phosphoric acid hit it,
Cillit Bang Power Cleaner Grime & Lime should not be used on any acid sensitive material, such as marble or enamel, aluminium, copper, stone, zinc-plated metals, kitchen worktops, linoleum, varnished, waxed or oiled wood floors, rubber, textiles or carpets.
Buy this https://www.ebay.co.uk/itm/Engine-Degreaser-25-lts-safe-eco-friendly-water-based-/280786737496?pt=UK_Car_Accessories_Car_Care_Cleaning&hash=item4160319958
put it in a spray bottle, spray on engine, clean with soft brushes, pressure wash off.
I am also not afraid to pressure wash an engine, I have never had a problem, includes pressuring washing my Ducati and my Aprilia, just avoid bearings etc.
But don't cover your bike in frigging acid/Cillit Bang Rolling Eyes Rolling Eyes Rolling Eyes
MarkJ
PostPosted: 20:03 - 04 Jan 2012    Post subject: Reply with quote
Good job I don't have the Grime and Lime Cillit Bang then Rolling Eyes Rolling Eyes Rolling Eyes
PostPosted: 22:51 - 04 Jan 2012    Post subject: Reply with quote
Blast away. Between getting drenched in the pouring rain and attacked by road salt through winter there's not much worse you can do.
I use watered-down TFR to blast it over with my paraffin gun then let it soak for 10 or 15 minutes then hit it with the jetwash.
The last post was made 14 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 75.93 Kb
