How to soup up KLX250 EFI the easy way
Svendura
PostPosted: 12:19 - 04 Jan 2012    Post subject: How to soup up KLX250 EFI the easy way Reply with quote
I've got myself a brandnew Kawasaki KLX250 2009 EFI and I love it
because it's light and nimble though it could use a little more power.
I am not into loud pipes or other illegal stuff, but there is an easy
way to push a little more life into the small 250cc power plant. The
costs will be no more than 10p and it is absolutely easy done. Let me
show you how.
https://pic.endurowandern.eu/klx_tuning.jpg
The engine is limited in higher revs and doesn't rev much higher than
approximatebly 7.500 rpm. This way the max speed won't exceed
105 km/h (65 mph).
But Kawasaki provides the bike with a second and well hidden ignition
curve. Once you activate that power curve, the KLX does 130 km/h
(80 mph) and is much more fun to ride.
The power curve is activated by bridging the switch at the handlebar
next to the clutch lever. The pics should show you the details.
Step 1: find the switch.
https://pic.endurowandern.eu/Kawa-frisieren-pic1.jpg
https://pic.endurowandern.eu/Kawa-frisieren-pic2.jpg
Step 2: Remove the black flat connector.
Careful: Don't use a tong, you won't need it and might damage the
connector. Leave the small tongues alone, that I've marked with an
X. Instead there is a small latch on the underside of the connector.
Once you press it in, you can remove the plug easily.
https://pic.endurowandern.eu/Kawa-frisieren-pic3.jpg
Step 3: Make a short cable bridge of 40mm length and 1.5mm diameter
and strip of 10mm at both ends.
https://pic.endurowandern.eu/Kawa-frisieren-pic4.jpg
Step 4: Plug both ends of the cable into the black flat connector
that you've unplugged in step 2. When you need a little presure to
press it in, you've chosen the right diameter.
https://pic.endurowandern.eu/Kawa-frisieren-pic5.jpg
Step 5: Ready. Have fun.
https://pic.endurowandern.eu/Kawa-frisieren-pic7b.jpg
I've plugged the connector upside down on the small latch, so that it
doesn't flow in the wind. Whenever you want to restore original
condition, just rip the cable off and plug the connector back where it
belongs. No tools needed.
I have now ridden 13.000 km on the KLX mostly with holliday
luggage and I've not seen any side effects except having more fun.
Fuel consumption has risen a tiny wee, but no more than I am going
faster now.
Of course this works only with the fuel injected models of KLX250,
make 2009 and up.
https://www.svendura.de/pic/gruss_aus_kiel_svendura.gif
PS: Please excuse any spelling mistakes, clumsy words or poor grammar.
English is not my native language and the only one to blame is Mrs
Hardenberg, who was my english teacher at school :-)
www.svendura.de
PostPosted: 12:45 - 04 Jan 2012    Post subject: Reply with quote
Isn't that the clutch switch?
jimspeed
PostPosted: 12:46 - 04 Jan 2012    Post subject: Reply with quote
Thanks for that very interesting Thumbs Up
I would think that connector is maybe there to easily change the fuel map for poor quality fuel etc.
OH and you're English is better than most on here (including mine)
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Svendura
PostPosted: 12:57 - 04 Jan 2012    Post subject: Reply with quote
@Chris-red: Yes, exactely. I just missed the word. Thank you :-)
@Jimspeed: Possibly, but then I don't understand, why there's no hint from Kawasaki. It'd be a great feature.
(thanks for the kindness, I'll pass it on to Mrs Hardenberg :-)
www.svendura.de
PostPosted: 13:17 - 04 Jan 2012    Post subject: Reply with quote
Svendura wrote:
@Chris-red: Yes, exactely. I just missed the word. Thank you Smile
(thanks for the kindness, I'll pass it on to Mrs Hardenberg Smile
That shouldn't effect the map in any positive way I would have thought, if you want it neater you can tape the switch in at the switch end (remove the lever)
PostPosted: 14:10 - 04 Jan 2012    Post subject: Reply with quote
Well, quite.
It should be easy enough to see if the switch has an effect. Wire it up to a button then mash it when you hit the rev limiter, see if you get warp speed.
https://image.shutterstock.com/display_pic_with_logo/340897/340897,1255057987,5/stock-photo-red-turbo-button-38530150.jpg
Walloper
PostPosted: 14:38 - 04 Jan 2012    Post subject: Reply with quote
Is the clutch Switch OK?
If that switch has a defect it could be cutting the engine ignition.
I thought the Interlock only disconnects power to the ignition to prevent start-up when in gear and clutch lever released.
If the bike is in gear the engine will not start until the clutch lever is pulled to disengage the clutch.
A bad switch could limit RPM if it makes-breaks at higher RPM due to engine vibration etc.
Irn-Bru
PostPosted: 15:04 - 04 Jan 2012    Post subject: Reply with quote
I remember on my old Yamaha DTR125 you had to earth a wire somewhere near the headlight. The result of that was 85mph top end, up from 65 and much better acceleration. That said, the DTR is a carb'd 2-smoker but similar solution except they limited the power valve from opening - which resulting in ruining the little torque the poor engine had. If you changed gears really early a disability scooter could easily over take you.
Svendura
@Rogerborg: nice switch. I'd like to install it on my bike!
@Walloper: There is a second ignition curve that can be activated by bridging the clutch switch. I know of several KLX owners who already tuned their bikes this way. It works. No defective switch involved.
But you are right: Now it is possible to start the engine while in gear. But why should anybody do such a stupid thing...? :-)
www.svendura.de
Walloper
PostPosted: 15:11 - 04 Jan 2012    Post subject: Reply with quote
But you are right: Now it is possible to start the engine while in gear. But why should anybody do such a stupid thing...? Smile
Why would one indeed??
Embarassed Embarassed
Very Happy
Svendura
PostPosted: 16:04 - 04 Jan 2012    Post subject: Reply with quote
I was just kidding, of course there is a certain danger in it, if it is possible to start a bike with a gear engaged. So it was helpfull from you to mention it Thanks again.
www.svendura.de
PostPosted: 16:05 - 04 Jan 2012    Post subject: Reply with quote
Because it's quicker than putting it into neutral whenever you start or stop.
Walloper
PostPosted: 21:04 - 04 Jan 2012    Post subject: Reply with quote
I was kidding too.
I have started in gear, moved off with the side stand down, stopped without pulling the clutch in, thought it was in neutral and it was in 1 or 2 and cetera.
Smile
Tango675
PostPosted: 14:21 - 01 Feb 2012    Post subject: Reply with quote
Ok.
I think I know how this works.
The KLX250 is limited in 5 and 6th to about 7,000 rpm. This i can guess is to stop you going to quick. The redline is at 10,500 rpm and the bike does feel more spritely in lower gears.
I would guess that this fools the ECU into thinking that the clutch is engaged, removing the rev limiter and allowing the engine to reach its peak power.
I have seen other mods that do simalar things, basicly fool the ECU into thinking the bike is not in 5 or 6th.
With most solutions the ECU notices that the speedo (speed sensor) shows that the bike is going to fast and brings on the Fuel Injection light.
NB: The ECU uses a combination of Revs and speed to calculate the gear the bike is in.
The best solution I have heard is a replacement ECU that does not have the limiter built in and can accept cusom maps (for exausts, airbox mods etc) though the maps that it comes supplied with are for hotter countries and can causes starting problems in the colder UK climate.
Somebody give that windup merchant a torque wrench..
PostPosted: 15:51 - 01 Feb 2012    Post subject: Reply with quote
And how does the cost of that compare to 1.5" of wire? Smile
tahrey
PostPosted: 13:09 - 02 Feb 2012    Post subject: Reply with quote
Or a switch you can get from maplin for 50p (plus some sticky dots to hold it in place) and flick on/off as you go into 5th/4th gear?
Tango675
PostPosted: 16:54 - 04 Feb 2012    Post subject: Reply with quote
Think they went for £250 on ebay.... so not favorably Rolling Eyes .
Though when you consider the Power Commander etc does not work on the bike, if you plan to make modifications to the bike it would be worth it...
lllN30lll
PostPosted: 17:05 - 04 Feb 2012    Post subject: Reply with quote
https://www.powercommander.com/powercommander/powercommanders.aspx?mk=27&mdl=266&yr=2010&pc=17-023&mk-n=Kawasaki&mdl-n=KLX250S%20%28European%20Only%29&pc-ver=PCV&add-mdlyrid=17-023&add-mdlyrid2=17-023&fullstr=17-023
There is a gap of 3 years, 55 days between these two posts...
honda15i
PostPosted: 07:23 - 31 Mar 2015    Post subject: Reply with quote
On ebay I found this german tuning:
https://www.ebay.co.uk/itm/Leistung-Tuning-Kawasaki-KLX250-KLX-neu-/180907884064?
Has anybody tried that?
I'm wondering if it worth to try i.e. will it add more HP after enabling second curve (clutch) and bypassing O0 sensor.
Regards,
Arthur
The last post was made 11 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.43 - MySQL Queries: 13 - Page Size: 112.42 Kb
