| blahheed |
 blahheed Trackday Trickster
| TQ |
 TQ Trackday Trickster
| blahheed |
| Ichy |
 Ichy World Chat Champion
| yen_powell |
 yen_powell World Chat Champion
| kitty kat |
 kitty kat World Chat Champion
| stinkwheel |
 Posted: 17:05 - 03 Jan 2012 Post subject: |
Is it wireless?
If so, turn the whole lot off for a minute. Take the batteries out of the sender. Turn it back on. Stand next to the receiver and put the batteries back into the sender.
Fucking wireless thingy on mine is the bane of my life. I'm having it taken out and replaced with a normal one with a wireless thermostat and a manual override.
Are any of the radiators hot? If some of them are hot and not others, it's probably not the valve. If they are all cold, it's probably the valve.
Is it a combi boiler? How's the pressure? Does it need more water in the heating system? There should be a pressure guage on the boiler somewhere. There usually wants to be about 1 bar (or more) in the heating system. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Al |
 Al World Chat Champion
 Posted: 19:35 - 03 Jan 2012 Post subject: |
If the upstairs rads and hot water are getting hot just not the downstairs I'd check the pump first. Also if the upstairs/downstairs rads are controlled as separate zones check that the motorized valve for downstairs is operating correctly. ____________________ Yamaha FZR400RR 3tj
My Instagram Thingy |
| Ariel Badger |
 Ariel Badger Super Spammer
| blahheed |
 Posted: 21:42 - 03 Jan 2012 Post subject: |
https://i226.photobucket.com/albums/dd26/szbiker/th_Picture224.jpg
its a normal boiler with a hot water tank system.
thermostat is normal electric type
the down stairs radiators eventually came on.
but the whole system is making a right noise when its running.
sounds like air in the system?
the pump shown in the photo(blue circle) this has 3 settings and its on the 3rd one, sounds like air is in it |
| kitty kat |
| blahheed |
| weasley |
 weasley World Chat Champion
| blahheed |
| Ichy |
 Posted: 22:30 - 03 Jan 2012 Post subject: |
Turn off the heating on the controller or set the thermostat to zero. Leave it for a minute and then put your hand on the pump, it may be hot! Turn on the heating. Can you feel the pump working?
When ypu checked that the valve was working did you touch all three pipes to check they were getting hot?
Have you tried bleeding one of the upstairs radiators? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| kitty kat |
| Al |
 Posted: 22:38 - 03 Jan 2012 Post subject: |
The pump looks pretty old and if its also noisy I'd check that its not simply the pump that's given up (hot rads upstairs, cold rads downstairs is a classic symptom, google it)
The large brass flat head screw on the front of the pump is an air bleed screw so you could try undoing it a 1/2 turn to make sure air isn't stuck in the pump. The screw also comes out and you can put a screwdriver inside the pump to make sure the impeller turns freely. Make sure the pump is off when you do this and you will get a small amount of water coming out so have a towel or container underneath. ____________________ Yamaha FZR400RR 3tj
| blahheed |
| kitty kat |
| blahheed |
| G |
 G The Voice of Reason
 Posted: 17:16 - 04 Jan 2012 Post subject: |
Had a similar issue here, though the other way around (no hot water in taps, but central heating worked fine).
Each circuit had it's own electronic valve which was controlled from the main central heating controller. I did test it to quite as much detail as I could have, but it seemed that this valve was busted (it was possible it was an electrical fault further up, but switching it on/off did provide a current to it as expected.)
In this case the valve was closed with a spring and opened by the electric motor, so I just took the springs off to leave it open all the time as it was on all the time anyway - if it was my house, I'd have replaced it, but as it's not I merely informed the owner of the house it needed doing.
I partly worked it out by feeling which pipes were hot and which weren't (after trying a hell of a lot of other things, it should be added). It seemed that up until that point, the pipe was reasonably hot, but after it wasn't. It helped that there was a T a little below it I suspect. |
| Skudd |
 Skudd Super Spammer
| kitty kat |
The last post was made 14 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
