| TheSmiler |
 TheSmiler World Chat Champion
 Posted: 15:09 - 31 Dec 2011 Post subject: Remove fuel line (tips) |
Just wondering if any one has got any tips or method to get the fuel line away from the petcock. Trying to remove the carbs this is one main hurdle trying to get over.
Yes the petcock is set to off, there are no clips holding it in place, would pliers be a bad way of getting it off  ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
| yen_powell |
| Fizzer Thou |
| TheSmiler |
 Posted: 13:20 - 02 Jan 2012 Post subject: |
Thanks for the tips, however tried both of them messages and still can't get it off. ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
| woll |
 woll World Chat Champion
 Posted: 15:00 - 02 Jan 2012 Post subject: |
If there's no clips on then either of the above will work. if you can't get it off doing either of the above then you need a dose of MTFU and give it more of a tug... ____________________ Current Bike- Suzuki DRZ400 SM K6
Damaged spleen, damaged kindey, 2 popped lungs, 2 broken ribs, broken face, broken wrist and 5 back fractures... remember kids walls hurt |
| TheSmiler |
 Posted: 09:03 - 05 Jan 2012 Post subject: |
Going try again today to remove the fuel line, otherwise end up cutting it off and putting a new one on which would be a lot simpler.
Managed get it of using a method that Teflon Mike told me using hot water and my own idea of a pastry brush around the end which got it lose. Just as the heavens opened
However new question save a new thread
Is it normal for individual spark plugs to show different readings when on full choke. With not being able to run normal at the moment tested the spark plugs and they came out different one showing over rich fuel/air and the other showing malfunctioning ignition system.
Know what is causing both of them but is just thought it was weird the plugs are showing different results  ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
| Teflon-Mike |
 Posted: 12:35 - 05 Jan 2012 Post subject: |
| TheSmiler wrote: | Going try again today to remove the fuel line, otherwise end up cutting it off and putting a new one on which would be a lot simpler.
Know what is causing both of them but is just thought it was weird the plugs are showing different results  |
a Pastry Brush Were you wearing a pinny, too?
As for the spark-plugs; see your other post on cleaning carbs!
YES, on these bikes very common. The Corporal is fond of firing up on the left hand pot, first, a trait shared with a lot of CB125's.
BUT; if the choke syncronisation is to fuck, then very likely that you will get different plug colour's; left hand choke will be open as far as the cable is pulled, its directly connected. Right hand choke could be anywhere, or flapping around randomly. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| TheSmiler |
| Teflon-Mike |
 Posted: 15:59 - 05 Jan 2012 Post subject: |
For clarity, LHS is the side stand side, JUST in case you are looking from the front of the bike!
Makes perfect sense.
LHSparker is clogged because that one is running 'ritch' on choke.
RHSparker is clear because its firing 'lean' on start up, the choke not closing all the way.
I take it you are at the choke sync stage.
DONT worry too much about the RH Choke flap being a tad 'open' when the choke full on.
The flaps are notched to clear the airway boss and they don't always close fully, catching on that notch.
You only use choke on start up; and you should only be using 'full' choke birefly, if at all, and then only on very cold starts.
The 'important' bit is to make sure that the RH choke flap is fully open, when teh choke is 'off' and that it's not 'wobbling' any on the flex link flat. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| TheSmiler |
The last post was made 14 years, 38 days ago. Instead of replying here, would creating a new thread be more useful? |
