| TheSmiler |
 TheSmiler World Chat Champion
 Posted: 11:17 - 05 Jan 2012 Post subject: Cleaning carbs |
Think I've done this topic before but will it harm the carbs if I use washing up liquid to clean them (got no vinegar/baking soda and heard they can be harmful to the carbs as the vinegar is mild acid) ?
Finally got them off after wrestling with the wind, rain and hail fun day so far.
Might be a stupid question  ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
 ..... Quote Me Happy
| TheSmiler |
| tatters |
 tatters Exxon Valdez
 Posted: 11:52 - 05 Jan 2012 Post subject: |
| TheSmiler wrote: | | Joe wrote: | Carb cleaner is cheap enough and is stocked by various places so easy to find. |
I know about the carb cleaner but petrol gives me major headaches and when my uncle used it before when I was a younger It used to give me powerful migraines so stay away from it. |
Ultrasonic baths are very good at cleaning carbs, I accuired a large one thats big enough to do inline four carbs, very good results which you could never get with cleaning by hand.
I think there a few places around that do a carb cleaning service if you dont want to buy your own bath. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| TheSmiler |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 12:29 - 05 Jan 2012 Post subject: |
1/ Pics: its blowing a ruddy gale out, & for some reason I'm having a very bad 'leg' day, they just dont want to work today. So not inclined to go outside and start waving acamera around!
https://s178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/
See what pics you can find in there to help; out to be a few.
2/ Please, PLEASE tell me that you took the air-boxes off before you took the carbs off, like I showed you!
3/ As we did them in my kitchen. first time round. Warm soapy water and a toothbrush. NOTHING abrasive.
4/ Pull the float pin to release the float and let the float needle drop out. Blow through the petrol pipe inlet to clear the port, then clean the seat the needle goes in with the toothbrush; then a cotton bud. Clean the needle with the tooth-brush then some tissue.
5/ remove the idle jet; thats the small brass one at the front, with a large flat-blade screwdriver. Make sure the blade is big enough to fill the slot BOTH sides of the jet, so you dont crack the brass from the edge of the slot! Clean jet with toothbrush; blow through jet to clear. The emulsion tube is integral, & the side of teh (emulsion tube) is perforated. Clean carefully with toothbrush. Use a single bristle to poke through each of the holes. DO NOT use wire or anything harder, it can damage the jet.
6/ use I think its an 8mm spanner to hold the main-jet emulstion tube, and flat blade screwdriver to remove the main jet. Clean with toothbrush & blow through.
7/ Use 8mm spanner to unscrew main-jet emulsion tube. Clean as the idle jet.
8/ Remove the base mixture screw; again large flat blade screwdriver; MAKE SURE IT IS SQUARE IN SLOT. its a deep slot, and the brass is easily cracked. There is a spring on the screw, and the needle on the end VERY FUCKING FINE, and BRASS handle with care it can be bent or cracked REALLY REALLY easily. Clean the needle very carefuly with soapy water & cotton bud. Blow through the hole the needle screws into. Air should come out of the front and rear ports in the entry and exit of the carb.
9/ clean the carburettor body. There are two air-ways in the carb inlet, by the choke butterfly. Blow these through. There is another on the carb exit; blow that through too.
10/ Re-Assemble.
Idle air screw 'set' by screwing all the way in then back out 1 1/4 turns.
Make sure that the air-boxes are off & out of the way before trying to put the carbs back on.
Make sure that the carb mounting rubbers are not ripped, either from your endevours of that bloke that claimed to have stripped the carbs before.
Carbs ought to pop in VERY easily, one from either side, if you have the air-box out the way, and done the job properly.
DO NOT clamp them up, once fitted, leave them loose in the rubbers.
Fit the link between choke spindles. make sure that the flex link is tight on the shaft; use the end of a cable tie snipping to tighten it if loose.
with your head where the air-boxes have been removed.....
work the choke and make sure that both choke butterflies work in unison, and that the right hand butterfly is fully open when left hand is; likewise when closed. You may have to tweek the link to get them to work in unison.
If THIS isn't done, then you will NEVER get the carbs working properly; Right hand choke will often be partly 'on' when the choke is 'off' or fluttering about if there is movement on the spindle, fucking up the carburation.
Next, refit the air-box rubbers to the carbs; DO NOT CLAMP them at this stage. Then fit, the air-boxes, LOOSELY.
There ought to be a large loop of cable tie around the air-box ends of the carbs.
If this has been clipped or lost; then make a new one; if you still have the one I fitted, use something pointy to loose off one of the clips to open it up a bit.
Now check the choke lever on left hand carb. It is VERY close to the frame, and can 'foul' at one end of the cable travel or other. Check the movement.
NOW, with the air-box in place; the rubbers in possition, but everything 'loose', start on the right hand side; bolt down the right hand air-box. THEN fiddle the air-box rubber into situe. THEN tweek carb, in the rubbers to the verticle, keeping an eye on that choke linkage. THEN tighten up the air-box rubber clamp; before putting intial tweek on the carb mount rubber clamp. DO NOT tighten the fuck out of it; JUST to the point it grips carb.
THEN: go to the right hand side.
Check that choke arm again. with the loop of cable tie around the carb mouths, use it to draw the right hand carb 'in' to make sure that choke arm clears the frame, and pinch the carb to seat to the air-box rubber.
Tighten down the left air-box; and check the pinch cable-tie to keep it all tight.
THEN nip the clamps as right hand air-box; until they 'grip' the carbs.
Throttle slides can now be replaced, and the engine run up.
On these bikes; you HAVE to remove those air-boxes to be able to re-fit the carbs, and make sure that the choke is sync'd and avoid fucking up the carb mounting rubber. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Robby |
 Robby Dirty Old Man
| TheSmiler |
 Posted: 12:52 - 05 Jan 2012 Post subject: |
Wow mike thanks for the reply, let me cut it up a bit.
Thankyou for the link I will check through should sort me out its nice weather out apart from the random sun and hail trust .
| Teflon-Mike wrote: | 2/ Please, PLEASE tell me that you took the air-boxes off before you took the carbs off, like I showed you!
3/ As we did them in my kitchen. first time round. Warm soapy water and a toothbrush. NOTHING abrasive. |
Don't worry I pulled it all off remembered how you showed me the only problem I had were the fuel line, which manage to get of using a pastry brush and hot water got to remember that and the metal clamp that holds the carbs together, a cable tie had snapped off inside so pulled it out with pliers awkward bugger. Regarding the tooth brush I've found my brothers lying around so using that he won't mind.
5/ remove the idle jet; thats the small brass one at the front, with a large flat-blade screwdriver. Make sure the blade is big enough to fill the slot BOTH sides of the jet, so you don't crack the brass from the edge of the slot! Clean jet with toothbrush; blow through jet to clear. The emulsion tube is integral, & the side of the (emulsion tube) is perforated. Clean carefully with toothbrush. Use a single bristle to poke through each of the holes. DO NOT use wire or anything harder, it can damage the jet. |
Have already used this method to clean one carb thoroughly almost and found white stuff stuck to the inside apart from that the pilot jet was clean on that one. Taken the second apart and completely blocked like I thought so hopefully that is the culprit fingers crossed anyway.
6/ use I think its an 8mm spanner to hold the main-jet emulsion tube, and flat blade screwdriver to remove the main jet. Clean with toothbrush & blow through.
7/ Use 8mm spanner to unscrew main-jet emulsion tube. Clean as the idle jet. |
This is the one I haven't done on the carbs was leaving it till got a reply but will crack on with that now.
9/ clean the carburettor body. There are two air-ways in the carb inlet, by the choke butterfly. Blow these through. There is another on the carb exit; blow that through too. |
Have done this on the right hand carb already so that one is correct apart from the main jet get that sorted after I get the stinging petrol out of my day old cut.
10/ Re-Assemble.
Make sure that the carb mounting rubbers are not ripped, either from your endevours of that bloke that claimed to have stripped the carbs before. |
Checked them when getting the carbs off there is nothing wrong with them, so he is a swindler as we both thought.
There ought to be a large loop of cable tie around the air-box ends of the carbs. |
Will make sure I use this as a manual only because without knowing at least a little engineering you are basically screwed with a Haynes manual.
On these bikes; you HAVE to remove those air-boxes to be able to re-fit the carbs, and make sure that the choke is sync'd and avoid fucking up the carb mounting rubber. |
Thank you for the excessive reply will use it as a backup to save me time searching on the internet, will most probably send a private message if anything goes majorly wrong  ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
The last post was made 14 years, 38 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 74.73 Kb
