Car Query - surge and slow
yambabe
PostPosted: 12:48 - 04 Jan 2012    Post subject: Car Query - surge and slow Reply with quote
My car is being a pain at the moment.
Just before Xmas I took it in as it kept dropping onto 3 cylinders randomly when the engine was hot. The gameboy thingy diagnosed a knackered injector so that got replaced. Didn't fix it. Sad It went back and had a new coil pack, and now it's not dropping a cylinder any more.
However, at constant revs it's still noticeably slowing then surging. Confused I'm wondering if perhaps when the new injector was fitted it needed some sort of tweak to make it inject the right amount of fuel and at the moment it's maybe out of synch with the others - is this possible?
Note that when it does this the revs do not change at all, the car just feels suddenly like it has more power then less power, and it's not all the time just randomly.
It also has a rough spot at approx 1000 revs where it doesn't want to tick over and judders which again suggests to me that the fueling might not be correct.
Any suggestions?
The car is a 2001 Peugeot 206cc btw, 2-litre engine, 68000 miles......
Walloper
PostPosted: 13:04 - 04 Jan 2012    Post subject: Reply with quote
Was it a Peugeot dealer who 'fixed' it last time?
I'd speak to them 1st.
Maybe it's just a loose wire...
Fizzer Thou
PostPosted: 15:33 - 04 Jan 2012    Post subject: Reply with quote
Injectors can be cleaned.Find someone with a machine like these people
https://www.injectorcleaning.co.uk/
then shove some injector cleaning fluid through the system after changing the in-line fuel filter if it has not been done within the cars mileage.
Always have a 'Plan B'
PostPosted: 15:52 - 04 Jan 2012    Post subject: Reply with quote
Possible the injectors are now way out (ie, 1 fresh and 3 very dirty ones) and confusing things. The amount of fuel is taken as pretty much directly related to how long the injector is triggered. Wouldn't expect the injector alone to cause such an issue, but might result in the mixture being a bit strange and confusing the feedback from the lambda probe. But at (say) 1800rpm each injector is firing 15 times every second so it
However I would expect the lambda probe on its own to be more likely to cause such a problem as its output will (and is expected) to vary.
cb1rocket
PostPosted: 21:48 - 04 Jan 2012    Post subject: Reply with quote
I would also get the car under an exhaust test, just to see if the lamba sensor is actually working. If the fuel map ie the ECU map is sending silly fuel/air ratios then it will fail the MoT as well. Its worth checking all the wires to the sensors including the injectors.
When do you start to notice it? From cold or after a certain distance when engine is warm? Has the rest of the car been kept up to date with service, esp. engine related matters
FirebladeRuss
PostPosted: 13:25 - 05 Jan 2012    Post subject: Reply with quote
I'm surprised they 'diagnosed' a faulty injector to be honest, as in my experience misfiring on a cylinder is usually a coil pack dying.
Who did the work and do you know if they have proper diagnostic equipment to interrogate the system or not?
First port of call, before disconnecting the MAF or anythign would be to have a proper diagnostic run on the car. If you unplug things first, then the diagnostic will pull up a load of recorded faults and won't help the garage (or you) in trying to pinpoint the actual problem.
The problem could be cause by any number of things to be honest, one of which may well be a faulty MAF - although I would be swaying more towards a cam or crank sensor failing myself, as if the revs are constant, a slight change in timing (as determined by the cam and crank sensors) will give you a slight loss in power.
As someone mentioned earlier, if you could post up a bit more info it might help a little more in getting sensible suggestions. For example, has the car been starting exactly the same, is it noticeable under hard acceleration more than gentle, or does it just feel like it's loosing/regaining power when your acceleator pedal position doesn't change?
Either way, someone with a diagnostics machine will be able to tell you. for that car I would imagine it's a standard OBD2 setup, and you can buy handheld code readers for not much, if you're that way inclined.
Twitter is for people who can't STFU even when they're by themselves
FirebladeRuss
Sorry, double post
bikenut
PostPosted: 14:34 - 05 Jan 2012    Post subject: tests Reply with quote
have you done a compression test?
dannymassive
PostPosted: 17:15 - 05 Jan 2012    Post subject: Reply with quote
I had a sililar problem with a Citroen that I had a few years back. Turned out to be the temperature sensor. As it was faulty it was telling the ECU that the car was cold so the ECU then adjusted the fueling to accomodate which resulted in the car running rough as rocks. It eventually got worse and the car would cut out at junctions - then would fail to start again until it had cooled down a bit (note, the car wasn't overheating but the temp sender was telling the ECU to give more fuel as the engine wasn't warm yet - even though it was warm!)
Previous Ride's - '01 Aprilia SR125 (Sold) '08 HONDA CBF600n (Sold) '96 CB500 (Sold) '01 FZS 1000 (Sold) '06 CB1300SA (Sold) '07 CB600F Hornet (Sold) - '93 Suzuki Savage LS400 (Sold) '98 Honda VTR1000 Firestorm (Sold) '05 CB600F Hornet (Sold) '01 FZS1000 Fazer (Sold) 2016 Harley Davidson Street Bob SE (Sold) '02 Kawasaki ZX9R (Sold) '98 CB600F Hornet (Sold) '04 Suzuki Bandit 1200s (Sold) '13 Yamaha FZ1-N
Tiff
PostPosted: 18:49 - 05 Jan 2012    Post subject: Reply with quote
Quite common on Peugeots, and could cause the problem, but I'd go for the Lambda or EGR valve sticking- can you get readings from the MOT emissions tester? If there has been unburnt fuel going down the exhaust due to a bad coil it could have contaminated the Lambda or cat.
1996 Kawasaki GPZ1100s,1996 VFR750,1980 BMW R80,1982 Kwak Z250B,1992 ZZR1100C,1996 BMW K1100LT,1994 Kwak ZZR600E,1993 BMW R1100RS,1992 ZZR 600D,1988 BMW K100LT,1998 Aprilia Pegaso 650,1994 Suzuki RF900,1991 Yamaha XJ600, 1988 Honda Dominator,1992 Kwak KMX125,1987 Yamaha RD50MX,1984 Honda MBX50.1984 Honda Superdream 125
Robby
Dirty Old Man
PostPosted: 19:04 - 05 Jan 2012    Post subject: Reply with quote
Lots of doom and gloom suggestions in this thread.
Whenever I have had a car surging it has been down to a dirty/sticking air bypass valve (next to or or on the throttle body) or a dirty throttle butterfly (particularly on fly by wire cars).
The fix on the last fiat the woman owned was to clean the throttle body, then rev the engine up to 5000 rpm 5 times to reset it. Did the job.
yambabe
PostPosted: 22:43 - 05 Jan 2012    Post subject: Reply with quote
OK, thanks for the input so far, given me some stuff to look at now and to ask if/when I take it back in.
Here's some more info.
The garage that worked on it is one that I've used for many years, know them well (well enough that they don't normally charge me for labour and I get my MOTs for half price) and they do have the correct diagnostic equipment as far as I know although they are not a Peugeot specialist.
The cars starts fine. The problem only kicks in when the engine has warmed up a bit, usually start to notice it after about 2 miles of driving at sub-30 with lots of start-stops (my commute).
Not noticeable under acceleration, it's when I'm bobbing along at constant revs that I notice it. The pedal doesnt move under my foot, I am nowhere near the clutch or brake pedals and the rev counter doesn't move, the car just speeds up and slows down - not a lot, but enough to be noticeable.
The OH is going to give it the once-over this weekend for anything obvious lke the sticky bits Robby suggested, if no joy I'll take it back to the garage Monday and ask if they can do a diagnostic on it again I think.
yambabe
PostPosted: 22:44 - 05 Jan 2012    Post subject: Reply with quote
Bloody double post Rolling Eyes sorry!
yambabe
PostPosted: 22:47 - 05 Jan 2012    Post subject: Reply with quote
OH is also saying it might be an air leak - opinions?
Fizzer Thou
PostPosted: 22:55 - 05 Jan 2012    Post subject: Reply with quote
This is a problem that I have come across on a number of cars that I have worked on of late,including my own car.I had some carb cleaner and after removing the inlet rubber from the air filter housing found that there was quite a bit of varnish from fuel mist around the butterfly valve.Once cleaned and wiped over it was surprisng how much better the response was.
I then checked this on a number of friends cars (I am not a car mechanic and do not want to be) and found similar states.I also found that crankcase ventilation pipes were clogged on some cars.With cars used for short commutes this came out as emulsified oil.On my car it was more like solidified carbon.
Fizzer Thou
PostPosted: 22:58 - 05 Jan 2012    Post subject: Reply with quote
Spray some WD40 or Easi-Start around the inlet manifold if this is suspected.If the revs rise then that is where the inlet leak might be.
Shaft
PostPosted: 23:56 - 05 Jan 2012    Post subject: Reply with quote
Vincent wrote:
Possible, but more of a bike problem due to the fact a bike inlet manifold is rubber and a car one is made of steel.
Crank sensor as mentioned above is another thing worth looking at.
Except that everything feeding air to that manifold is either plastic or rubber.
Modern cars are so sensitive to air leaks, the slightest split (which can open up when you apply heat) can cause all sorts of random running faults.
As this symptom appears to be related to heat and constant throttle openings, I would initially be confining my suspects to sensors that use temperature as a parameter for defining fuel delivery, further, I would be pointing my finger at the Lambda probe (although another suspect could be a Cat that's close to blocking).
Ultimately, only a good diagnostic system will give you the answer, unless the garage has a selection of known good sensors laying about and is prepared to play a game of swapsies.
Walloper
PostPosted: 04:31 - 06 Jan 2012    Post subject: Reply with quote
I had a BMW 525 that would almost die when pulling away after slowing for junctions. BMW could find no fault on the computer?
I asked if they took the fucking car out on the road, No we plugged it into our computer. Wankers...
A non franchise BMW mechanic 'fixed' it after he told me to buy a new rubber for the inlet manifold. He said this without looking at the car.
I bought the rubber and fitted it myself. Problem? What problem.
The rubber elbow goes between the air filter and the air sensor but had a connection to the crankcase ventilation device which had a crack in the connection.
The ECM measures total volume of air but the crack was leaking pressure so the sensor was 'feeling' erratic conditions (at low RPM Low Flow High Load) due to the crack.
bikenut
PostPosted: 11:18 - 06 Jan 2012    Post subject: not running properly Reply with quote
do a compression test to rule out that problem ( tight valve clearance becoming 0 whern hot, misfire??any recent overheating p[roblems??do compression test to rule that p[roblem out?
The last post was made 14 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 119.18 Kb
