wd40 good for chain cleaning?
GREENI3
PostPosted: 09:17 - 06 Jan 2012    Post subject: wd40 good for chain cleaning? Reply with quote
Do you reckon I could use wd40 to clean my chain?
I know some people say you shouldn't use it to lube the chain, but I've heard it makes a good cleaner.
MCN last week said to clean a basic chain; to wash it off with water then spray a water dis-placer over it, leave to dry then lube, so shouldn't cause any harm using wd40?
It's a 125 so only has a bog-standard chain, therefore no o-rings to damage.
Glenben92
PostPosted: 09:37 - 06 Jan 2012    Post subject: Reply with quote
Nah mate, I'd steer clear of it if I were you. Just a good scrub with a toothbrush and some parrafin or petrol and then lube and go.
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
UrbanRacer
PostPosted: 10:08 - 06 Jan 2012    Post subject: Reply with quote
WD40 would be a waste of money, if you really want to go to town on your chain then get a can of Wurth Brake and Chain cleaner. It comes out with a decent amount of pressure so most of thr time you don't even need a brush.
whitedevil
PostPosted: 12:37 - 06 Jan 2012    Post subject: Reply with quote
wd40 is fine as long as you dont soak the chain in it for a long time.
However paraffin is alot cheaper and wont swell the o rings.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
bikenut
PostPosted: 13:00 - 06 Jan 2012    Post subject: chain cleaning Reply with quote
:karma: hi dudes no o rings so try the following:
change engine oil and save for this next bit,
old saucepan and camping cooker ( your mum or wife will go frigging beserk if you do this in the kitchen so DONT ) in shed,
observing all safety issues ( fire, very hot oil etc. )
place chain in pan, add oil to cover and heat gently.
watch for water trapped in chain as it will eventually boil off ( you know what happens with hot oil and water, right!!!!)
this will soften and remove some crap. allow to cool and remove from pan,
this bits mucky, wire brush, check that every link articulates smoothly.
drain 1st oil and clean pan ( lots of crap in bottom?? )replace chain into pan and add 2nd oil, repeat process. did you see columbs of rising rust and air bubbles, air from links and rust from pins and bores.
allow to cool and make sure every roller ROLLS.
drain 2nd oil and clean pan, add 3rd oil,replace chain and repeat.
allow to cool. now every link articulates and every roller rolls smoothly, yes??
clean pan ansd now add parre3ffin, clean in p[arraffin till it comes out clean, 3 goes before cleaning parraffin stops getting dirty??
last wash in petrol and hang to dry.
clean pan add chain and cover in ep90 or 140 gear oil and heat gently.
see bubbles rising, remember last wash was with petrol which will vapourise ( potential fire risk so be carefull, but you did let chain dry completely, yes?? )
when all bubbles gone and oil not too hot ( dont let g/oil smoke as its too hot when it does ( oxidise ), allow to cool completely, remove and let drip off excess.
as long as you are carefull ( petrol, paraffin, very hot oil and a cooking stove ) all will be ok.
this is tried and trusted, oil acts as shock absorber tween links and rollers, do every oil change for good chain life. Also carry on with 2 daily chain spray grease applications, thats lube chain once every 2 days
UrbanRacer
PostPosted: 13:02 - 06 Jan 2012    Post subject: Re: chain cleaning Reply with quote
bikenut wrote:
Karma hi dudes no o rings so try the following:
Buy a new chain Laughing
ninja_butler
PostPosted: 13:42 - 06 Jan 2012    Post subject: Reply with quote
I just cleaned the chain on my bike with petrol and a cheap brush, it de-gacked it quite well.
A word of warning though; don't keep petrol indoors, even in the garage. The stink will waft it's way through the whole house.
neil.
PostPosted: 14:49 - 06 Jan 2012    Post subject: Reply with quote
And it has a low flash point, so even just the vapours could ignite with a spark...
Use paraffin, sold as Parasene (oil lamp fuel) in places like Homebase - much safer. Thumbs Up
GREENI3
PostPosted: 20:44 - 06 Jan 2012    Post subject: Reply with quote
I was considering paraffin since B & Q are selling 4 liters for £6.98, but was a bit concerned about having to keep such a high quantity of it in the garage and the way it'll probably fling off the chain when I'm scrubbing it into the chain.
Think I'll probably get it now though.
Save a load of money, when you see 500ml chain cleaners for £8 each.
bikenut
PostPosted: 21:23 - 06 Jan 2012    Post subject: buy a new chain Reply with quote
if youve the money yeah i suppose, does that mean you buy a new bike when its dirty........
Babba This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 22:35 - 06 Jan 2012    Post subject: Reply with quote
Neither will WD40, and I really wish people would stop peddling this load of cobblers.
https://www.advrider.com/forums/showthread.php?t=345397
WD40 is kerosene based and is kind to nearly everything on your bike.
It
Doesn't
Swell
O-Rings
(Interestingly according to the above, PJ1 chain lube swells the O-rings more. Wink )
PostPosted: 23:00 - 06 Jan 2012    Post subject: Reply with quote
Babba wrote:
I've done some semi-scientific experiments myself & can confirm that WD40 has absolutely no physical effect whatsoever on the 'O' rings Tsubaki use.
It does something much, much worser.
It washes out the grease that the 'O' ring is sealing in & because the 'O' ring is there you cannot get new grease to flow back in.
DO NOT use WD40 on an 'O' or 'X' ring chain folks, it defeats the purpose.
How can it wash the grease out anymore than spraying a chain clean into the chain?
ninja_butler
PostPosted: 23:05 - 06 Jan 2012    Post subject: Reply with quote
This is starting to get complicated. I've read that petrol causes o rings (the rubber rings in some chains) to swell, but WD-40 does not.
Does anyone know what the correct procedure is for cleaning a bike chain? I just don't know any more! Question
PostPosted: 23:08 - 06 Jan 2012    Post subject: Reply with quote
Petrol does cause O Rings to expand yes, don't clean chains with it.
WD40 is kerosene, NOT petrol based and thus doesn't cause the O rings to swell.
I clean my chains with diesel/white spirit and it never caused me a problem in 6 years (yet). Wink
I'd used WD40, probably spray it onto a rag first to avoid overspray onto the rear brake disk. Wipe on, scrub, wipe off, lube. Bosh.
whitedevil
PostPosted: 00:12 - 07 Jan 2012    Post subject: Reply with quote
It
Doesn't
Swell
O-Rings
Did you even read the info in the link?
If you had you would have seen that wd-40 isnt based on kerosene, it does swell and weaken rubber. It also acts as a penetrator and will creep passed o rings if given the chance.
I'll try and find the guide i read a few years ago.
The Tot
PostPosted: 00:23 - 07 Jan 2012    Post subject: Reply with quote
I use white spirit or paraffin on mine.
I'm making the assumption that the chains are made out of nitrile rubber. Being that I work as a materials engineer, we did some experiments with various rubber compounds and solvents to see which are deleterious to the seals - we're talking O-ring seals here, but not for chains, more like nuclear reactor/plant related components.
Either way, we dug up a compatibility chart to see if it's compatible.
With a rough gestimation regarding the composition of WD40 (they won't list all the ingredients - it could be "other %" that might be detrimental, but here's what the facts say.
Arrow 51% Stoddard solvent (i.e., mineral spirits: primarily hexane, somewhat similar to kerosene)
Arrow 25% Liquefied petroleum gas (presumably as a propellant; carbon dioxide is now used instead to reduce WD-40's considerable flammability)
Arrow 15+% Mineral oil (light lubricating oil)
Arrow 10-% Inert ingredients
Elastomers with Good Compatibility:
Buna-N (Nitrile)
Chemraz
Epichlorohydrin
Fluorocarbon
Fluorosilicone
Kalrez
Nitrile, hydrogenated
Polyacrylate
Teflon
Theory says that it's OK but empirical evidence suggests otherwise. The only way for us to tell is to do a soak test. Get a link, pack it with grease and insert O-Ring. Leave submersed in WD40 film and see what happens.
Could it be that it's the propellant in the aerosol that degrades the rubber?
Never argue with autism
PostPosted: 19:23 - 07 Jan 2012    Post subject: Reply with quote
I did read the info, did you?
The link I've posted makes no mention of it swelling, nor weakening the rubber.
https://i52.photobucket.com/albums/g23/klm4755/o_ring/oringexcel.jpg
janner_10
PostPosted: 20:22 - 07 Jan 2012    Post subject: Re: chain cleaning Reply with quote
WTF?? I scrub with petrol and a gunk brush and apply engine oil, 10 minute job every week or two. This is just farting about for the sake of it.
bikenut
PostPosted: 21:58 - 08 Jan 2012    Post subject: chains Reply with quote
wow dudes great info on o ring chains, but the guys got a non o ring chain..........this is how i do it, it may be classes as fartin about, quite frnakly im a borin old fart and i dont give a toss, its how i do it so there, make your own minds up, if a jobs worth doin............
PostPosted: 22:14 - 08 Jan 2012    Post subject: Re: chains Reply with quote
But fuck removing my chain.. would buy a new one rather than split it and rejoin it.
PostPosted: 22:20 - 08 Jan 2012    Post subject: Re: chains Reply with quote
I assume he's referring to chains with split links more commonly found on lower powered bikes.
anthony_r6
PostPosted: 22:21 - 08 Jan 2012    Post subject: Reply with quote
So... WD40...
Good, or No?
The last post was made 14 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.31 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 139.45 Kb
