Exhaust studs/threads
Rncv
PostPosted: 21:21 - 07 Jan 2012    Post subject: Exhaust studs/threads Reply with quote
Hi guys,
today ive been working on the fzr and have stumbled across a problem. I took the old exhaust downpipes off because they were cut and re welded in so many different places. I brought a set stainless downpipes and a copper gasket set and set to putting it on.
So i manage to get them on and then find out that the new studs are too short so turn them out a bit to make them longer (this is where i think i went wrong). The pipes need to squash the copper gasket to seal them correct?
what happened is when i was tightening one of the studs it made a pop and then the thread inside the head was damaged. You can only gently turn a stud but when it gets any force behind it it just pops out.
Any ideas on how to fix this problem? also anyone know where to source fzr 600 3he 1991 studs/bolts? as the ones i have dont seem right.
many thanks.
Current: 01' Bandit 600, 92' Goose 350
Previous: Lots!
Babba This post is not being displayed because the poster is banned. Unhide this post / all posts.
Rncv
PostPosted: 22:06 - 07 Jan 2012    Post subject: Reply with quote
Babba wrote:
Sounds like you've stripped a few of the threads in the head.
For an effective repair you're going to need to take the head off & get the thread repaired with a Heli-Coil insert.
It sounds like you've only stripped part of the thread, you 'might' get away by sourcing the correct length studs (I prefer allen head bolts) and hope that there's enough good thread left deeper inside the head.
For someone who knows what they're doing, this is a cheap & easy fix (my engineers charge £20ish for a Heli-Coil), for someone on a discovery trip, it could end up costing you a new head?
Fml, i will see if i can source some decent bolts and give it a go.
taking the head off is going to be a massive pain in the arse, hopefully i wont have to Thumbs Up
Previous: Lots!
The last post was made 14 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 40.82 Kb
