When adjusting the chain
Muscle Bike Rider
PostPosted: 20:48 - 07 Jan 2012    Post subject: When adjusting the chain Reply with quote
If you are say 1 to 5mm difference when adjusting the chain will it make much difference?, I normally do it a quarter turn each side at a time but its never going to be the ecaxt same amount to the mm so how much leeway is acceptable?
Ta folks.
Previously Known As A5tra_G
Old Bikes :2010 Kawasaki ER6 F & 2000 Honda VTR Firestorm
Current Bike : XJR1300
Frost
PostPosted: 21:01 - 07 Jan 2012    Post subject: Reply with quote
You can get away with a surprising amount. It won't be good for your chain and sprockets or the bike's handling though. Measure how much of the chain adjuster pokes out, either with a ruler or digital calliper. Adjust the side with the sprocket on first then do the other one to match.
Babba This post is not being displayed because the poster is banned. Unhide this post / all posts.
Walloper
PostPosted: 00:41 - 08 Jan 2012    Post subject: Reply with quote
You don't need a straight edge to check wheel/frame alignment.
Adjust the chain to the specified sag. Rotate and check at several positions.
Take a long piece of string.
Tie it to a wheel rear spoke.
Pull the string around the back of the tyre (at a height just below any bodywork that sticks out) and all the way to the front wheel to about the same height.
Pull the string taught then move the end in to the front wheel until it just touches.
There should be a gap at the back of the front wheel.
Record this gap.
Do the same with the string on the other side.
Compare the gap with the other side and adjust the rear wheel to suit.
Easier to do on centre stand or a paddock stand.
PostPosted: 01:04 - 08 Jan 2012    Post subject: Reply with quote
Must get myself some aluminium straight-edges.
Until then as suggested I used the string method. Only needed to do it the once. The difference between the 2 adjusters on the 250 were out by 4mm IIRC(jotted down in manual)
https://i104.photobucket.com/albums/m174/howlingterror_2006/WA004.jpg
https://i104.photobucket.com/albums/m174/howlingterror_2006/WA016.jpg
https://i104.photobucket.com/albums/m174/howlingterror_2006/WA011-1.jpg
https://i104.photobucket.com/albums/m174/howlingterror_2006/WA003.jpg
Muscle Bike Rider
PostPosted: 01:40 - 08 Jan 2012    Post subject: Reply with quote
Cheers guys, mine are out by about 1.5mm so think I'll invest in a digital caliper to get it spot on, didn't think that small a difference would be damaging.
WannaBeDude
PostPosted: 02:00 - 08 Jan 2012    Post subject: Reply with quote
I'm buying a next to NO adjustment chain, Idea Rolling Eyes Embarassed
The last post was made 14 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.2 - MySQL Queries: 13 - Page Size: 53.01 Kb
