Plastic polish!
Blackwolf
Burgerfist
PostPosted: 13:02 - 08 Jan 2012    Post subject: Plastic polish! Reply with quote
When I binned my T, the clear plasctic cover piece on the clocks got scratched. wondering what i can use (if possible) to polish out the scratches?
T-cut?
Cheers!
BW
Dazbo666
PostPosted: 13:07 - 08 Jan 2012    Post subject: Reply with quote
Try a search for "Xerapol" and/or "Plexus"
I've not used it myself, but heard good things about Xerapol
edit : Xerapol website
...or "lmgtfy"
Word of the day : DILLIGAF
Nope.
PostPosted: 14:12 - 08 Jan 2012    Post subject: Reply with quote
https://www.mig-welding.co.uk/forum/showthread.php?t=8113
Yes, You can!
DrDonnyBrago
PostPosted: 20:08 - 08 Jan 2012    Post subject: Re: Plastic polish! Reply with quote
I polished out some deep scuffs on the corner of my screen after a lowside.
I went at it with finer and finer grades of sandpaper, from about 200 grit all the way down to 1500 grit wet and dry, makes it very smooth but hazy. To get rid of the haze I used autosol metal polish, then used T cut, then finally conventional car polish. It is as smooth as the rest of the screen. I did the other side to match, you wouldn't be able to tell it had been scuffed up.
All done by hand with rags etc, would have been quicker with a dremel polishing head or similar but I couldn't be arsed to push my bike near to a plug socket.
Walloper
PostPosted: 20:32 - 08 Jan 2012    Post subject: Reply with quote
The problem with scratches is that you need to remove loads of surrounding material to get the scratch out.
In other words you do not polish out the scratch but polish out all the material around it.
Xerapol works but takes for ever as it is a very very fine polish. Maybe even almost optical grade.
I would use Rubbing Compound then T Cut then Xerapol.
Test on a bit of similar plastic for effects.
Some compounds are soaked up by certain plastics especially when you raise the temperature so you could stain or cloud the lens you are trying to fix.
Blackwolf
Burgerfist
PostPosted: 23:23 - 08 Jan 2012    Post subject: Reply with quote
I may just get some more acrylic/perspex and make anoter one to glue in..
funmonkee
PostPosted: 01:50 - 09 Jan 2012    Post subject: Reply with quote
I was going to say put a sticker over it!
I'd try T-cut first Thumbs Up Halfords usually have a shed load of scratch removing products. But try T-cut first... Asda were doing a sale on it recently for £1 a tube Karma And get some of the soft dusters at the same time Thumbs Up
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
FirebladeRuss
PostPosted: 14:39 - 09 Jan 2012    Post subject: Reply with quote
Any mild cutting compound for car paintwork will be fine.
Twitter is for people who can't STFU even when they're by themselves
The last post was made 14 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 2.98 - MySQL Queries: 13 - Page Size: 56.86 Kb
