New chain & sprocket time... but what size?
Jayy
Mr. Ponzi
PostPosted: 19:13 - 08 Jan 2012    Post subject: New chain & sprocket time... but what size? Reply with quote
Chain is near the end of it's lifespan so I'm looking to get a chain and sprocket kit.
https://www.motorbikesandparts.co.uk/did-chain-sprocket-kit-for-kawasaki-zx1000cd6fzx10r-0406-p-23089.html
Seems pretty good for £116 delivered but should I go + a few teeth?
I don't take it on the track and have no intention of doing so and there's no way I will hit top end speeds on it so I'm thinking I could do with better acceleration / wheelie power.
Do you need to go + on both front and back?
PostPosted: 19:20 - 08 Jan 2012    Post subject: Reply with quote
Down on the front or up on the rear for wheelies.
Although.. standard gearing should be fine for wheelies Thinking
Jayy
Mr. Ponzi
PostPosted: 19:21 - 08 Jan 2012    Post subject: Reply with quote
Standard is perfect for wheelies but why waste having a top speed when you will never use it? Might as well put it to more use on the acceleration front. Cool
Is that one or the other or both?
PostPosted: 19:23 - 08 Jan 2012    Post subject: Reply with quote
Well going down on the front or up on the rear will sort it.
For a laugh, a friend got hold of a 47 tooth sprocket from his work, drilled to match the GS500 carrier and used that for stunting Laughing Stock is 39 I think Laughing
I would go up on rear personally. Smaller front may increase chain wear... although, by the sounds of what you want to do.. it may do that anyway Laughing
Jayy
Mr. Ponzi
PostPosted: 19:29 - 08 Jan 2012    Post subject: Reply with quote
I'm not sure what I want to do ha, I just thought it would be a good idea having a bit more acceleration. It's not really needed to be fair, it's a monster anyway.
So, putting a bigger rear sprocket on there will wear the chain even faster than normal?
Totally noob questions here but I've never done it before.
PostPosted: 19:30 - 08 Jan 2012    Post subject: Reply with quote
I was under the impression a smaller front sprocket makes the chain "turn" tighter increasing wear. A rear increase wouldn't do much damage.
PostPosted: 19:40 - 08 Jan 2012    Post subject: Reply with quote
Can you already use full throttle in first gear? If not then you already have as much thrust as you can use (and while in higher gears you might gain a bit from the lower gearing, you could probably similarly gain from using a lower gear).
Lowering gearing will also mean more revs when cruising, using more fuel.
Smaller front will increase wear a bit.
Jayy
Mr. Ponzi
PostPosted: 19:48 - 08 Jan 2012    Post subject: Reply with quote
Not sure to be honest Keith, it's been a while since I thrashed it in 1st gear with the rubbish weather.
WannaBeDude
PostPosted: 21:39 - 08 Jan 2012    Post subject: Reply with quote
Esp for Keith as he's had Mitos, i'm getting a rear alloy 38 fitted Wedsnesday, what perfomance will it change oiut of interest, think at present i have 41 - 43 .. ist gear at present is too short imo.
Thumbs Up Karma
PostPosted: 21:54 - 08 Jan 2012    Post subject: Reply with quote
Going to up your top end a bit as long as you have the power to use that.
WannaBeDude
PostPosted: 22:00 - 08 Jan 2012    Post subject: Reply with quote
Wanted 1st gear to last more than it does .. ? Confused and to cruise easier at 70 odd ..
Power is 25bhp est.
PostPosted: 22:03 - 08 Jan 2012    Post subject: Reply with quote
Is yours a 6 speed or 7 speed one? What size is the front sprocket?
Think a Freccia used a 14 tooth front with a 41 tooth rear, which is quite similar to a 13 front with a 38 rear. That is reasonably high gearing which might not suit the unfaired bike.
38 will stretch things a out a bit but with a 14 tooth front might land up with 7th (if you have a 7th gear) being fairly useless.
WannaBeDude
PostPosted: 22:16 - 08 Jan 2012    Post subject: Reply with quote
My planet / raptor naked was ' geared ' for exceleration, afaik / just counted and looks to be 43 rear. Standard 14 front.
So going from 43 to 38 on a 6 speed gearbox.
The new rear is 38 and alloy, with LTT pure tyres one size bigger.
What this actually will do for me is : please tell me Smile
At present i get indicated 90 mph .. with 17 stone on her.
In b4 best performance increase, lose some fucking weight fatty !.. was verging on 19 stone last summer. Thumbs Up Karma
PostPosted: 22:26 - 08 Jan 2012    Post subject: Reply with quote
This is a thrust graph comparing the gearing between a 43 tooth (red) and a 38 tooth rear sprocket (blue). Used a Mito 6 speed power graph for it.
https://www.bikegraph.co.uk/TorqueThrustGraphMulti.php?x_max=1200&y_max=539&Id1=48&FrontSprocket1=14&RearSprocket1=43&Id2=48&FrontSprocket2=14&RearSprocket2=38&drag=yes&cd=3.94
The higher gearing would give a theoretical top speed of about 108mph, although not a hope in hell it would reach that. On your current gearing if you are managing a true 90mph then you are well past peak power and torque (although 90mph indicated is probably rather less true top speed).
WannaBeDude
PostPosted: 23:11 - 08 Jan 2012    Post subject: Reply with quote
Thanks ...
I got upto on a straight with a flyscreen 97/8 mph ... then ditched the clocks and flyscreen and get about 85 mph tops.
I don't understand that graph, or above peak power, will 1st gear be longer and how much roughly less exceleration will there be overall.
Also the lighter tyres and sprocket should help a little, tyres are 0.9 kg less weight than standard. Confused Karma
Hairy Ben
PostPosted: 23:23 - 08 Jan 2012    Post subject: Reply with quote
Wise words well worth remembering..
Dropping a few teeth can transform a motorcycle, but it can also dramatically reduce its usability at a steady seventy tonking down the motorway. Sad
...and thus true enlightenment is achieved.
I think, therefore I am... I ride a BMW, therefore I smell of wee...
WannaBeDude
PostPosted: 23:27 - 08 Jan 2012    Post subject: Reply with quote
Cool, that's the opposite of what i'd like, although i hoon like mad for a few miles,i also love cruising in the summer at around 50 mph open face shorts and tshirt for max protection. Cool
PostPosted: 00:32 - 09 Jan 2012    Post subject: Reply with quote
The lines on the graph are thrust (in pounds - effectively torque x gearing). Higher they are the more umph you have. Along the bottom is speed.
The thrust lines are for each gear, so the one on the left highest up is first gear. Gearing gives you more thrust for the same revs, but less speed.
Where the thrust line stops is where you have run out of revs.
The dotted line is a guess at aerodynamic drag (although probably too high for a small 125). The difference between that line and the thrust in a gear is how much thrust you have to accelerate you (if the thrust is below the dotted line then you do not have enough thrust to overcome wind resistance).
The lighter tyres, etc, will make remarkably little difference. Might affect acceleration a tiny bit but will make no real difference to top speed.
WannaBeDude
PostPosted: 01:02 - 09 Jan 2012    Post subject: Reply with quote
Thanks for your time K, i understand it now, proof will be Wednesday afternoon, just a test really, as got sprocket for 20 quid, getting whole new high end sprocket and chain later on in the year.
Running from 43 to now 38, once tested will give me a real idea of what i want to run, be it 38 - 42 .. thanks again. Karma Thumbs Up
WannaBeDude
PostPosted: 20:44 - 13 Jan 2012    Post subject: Reply with quote
Loving the difference from 43 to 38 ... better cruising mpg, usable 1st gear.
Tyres run in and main jet upto 130, plug chop WOT nearly there ..
Thanks .. Thumbs Up
The last post was made 14 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 108.79 Kb
