YBR 125 06/07 Carb Break Down (Gear Box?)
Mehty
PostPosted: 19:15 - 06 Jan 2012    Post subject: YBR 125 06/07 Carb Break Down (Gear Box?) Reply with quote
Hey all, Need some help!
For a little while now my YBR has been slipping into neutral from second, or every now and then showing its in neutral when in fact being in first, but i just put that down to me doing something wrong.
Today riding home from work, I came of a mini round about in second, up a slight hill and changed into third. There was a clunky grinding noise from around my left foot so i tried to drop back down a gear. The gear leaver felt very loose, but clicked into neutral than into first, so i started to release the clutch and give it some revs but all I got was a horrible grinding noise when I released the clutch enough for it to usually deliver power. I managed to wheel the bastard up the hill home and had another look.
I can get it into neutral, and it idles fine. Drop it into first, start to release the clutch and I get the grinding noise, flip it up into what I think is second and it does the same.
I think it could be the gear box? I would feel confident doing work on the bike but really need it going quickly and cheaply (an impossible feat, I know!)
2007 YBR 125 (sold), 2011 ER6-N (sold), LHD 1999 GSX750F (sold), ???Sad???
PostPosted: 19:23 - 06 Jan 2012    Post subject: Reply with quote
Check your cable adjustment first. Make sure its actually working as it should.
You might want to be more assertive when changing gears and really whack it into gear. I sometimes change too lightly and it drops out Thumbs Up
Mehty
PostPosted: 21:05 - 06 Jan 2012    Post subject: Reply with quote
I had a quick look at the clutch cable tightening it doesn't seem to do anything.
Just got off the phone to a mate and he said check the front sprocket where it attaches to the drive shaft?
also, just remembered that some times when.changing gear there would be a crunchy slap, sounded like the chain was hitting a cover, checked the back sprocket and.chain but that seemed fine as well,
thanks for your help in advance
l
Mehty
PostPosted: 16:05 - 08 Jan 2012    Post subject: Reply with quote
I went back and had another look yesterday morning, The chain wasn't on the back sprocket, so i took the chain guard and the front sprocket cover off to have a look. One of the teeth had snapped, and most of them are bent. I bought and fitted a new front/back sprocket, chain and clutch cable.
The bike will run, i can get it into first gear and the front sprocket will move - the clutch wont do ANYTHING though. If i hold it in (or move the clip where the cable attaches) literally nothing happens, the sprocket keeps moving.
I have some mates who can look at it next weekend, but obviously if anyone can give me some advice/help that'd be great.
Thanks
PostPosted: 17:01 - 08 Jan 2012    Post subject: Reply with quote
Too far for me to travel, just had accident also so cant be heading down Laughing
YBRs eating their sprockets seems regular now.
The adjustment for a new cable will be far different from your old clutch cable.
Set up your clutch properly, you should back off all the adjustment at the lever so there is 0 pressure there at all.
On your clutch end, you should have an adjuster that requires spanners, you may also have under a cover another adjuster that will need to be adjusted properly.
I hate them and cant do them Laughing Hence another BCF user showing me.
Best bet, PM neil. he has maintained a YBR from new I think...
Mehty
PostPosted: 17:26 - 08 Jan 2012    Post subject: Reply with quote
Where you saying there's actually adjustments where the cable attaches to the top of the engine? As i have tried moving that with my hand and it does nothing either Sad
Codemonkey
PostPosted: 18:11 - 08 Jan 2012    Post subject: Reply with quote
Thanks
Have you tried actually sitting on the bike with new chain fitted and both wheels on the ground ? It could be just the clutch dragging a bit. With no load on the transmission when in gear (ie, with the bike on its centre stand or without the chain fitted), there's probably enough drag on the clutch to spin up the front sprocket and rear wheel if the chain is fitted. You normally notice this as a slight forward jolt when you select first.
Test Passed 10/05/2011 Current bike: XJ6-N
Mehty
PostPosted: 18:25 - 08 Jan 2012    Post subject: Reply with quote
I have had the bike off the stand, dropped it into first, started to rev and let out the clutch and nothing. There is no bite point or feel on the clutch (even where it connects to the engine) Iv also noticed that when its in first, you can move the bike as if it was in neutral. In first or second, the sprockets spin, very slowly and uncontrollably.
neil.
PostPosted: 18:33 - 08 Jan 2012    Post subject: Reply with quote
Sounds like it could be a lot of things - can you take some photos of both sprockets and the chain as they are? Have you measured the slack in the chain? Drained the engine oil? Any metal fragments there? The words 'clunky grinding noise' make me think your gearbox might have eaten itself, which means a difficult, possibly expensive repair or new engine.
Other possibility is that the splines on the output shaft that the front sprocket sits on have worn, or it might be the splines on the sprocket itself (which would be better) - can you get the front sprocket off and show us what both look like? With the front sprocket on, can you turn it by hand and if you can, does the output shaft stay still?
Mehty
PostPosted: 19:11 - 08 Jan 2012    Post subject: Reply with quote
I have fitted a new rear and front sprocket and chain, The chain is the correct length. The front sprocket sit on the drive shaft fine and the splines are all good. I can spin the sprocket the shaft spins with it. The engine is no longer clunking or grinding either. When I put the bike into first the drive shaft starts spinning the sprocket/chain slowly, using the clutch does not make any difference (either the leaver, or where the cable attaches to the engine.
I have some (not very good) pictures of the old front sprocket (one of the teeth had snapped, and some of the others are bent)
https://i114.photobucket.com/albums/n248/pl3ppp/IMAG0007.jpg
https://i114.photobucket.com/albums/n248/pl3ppp/IMAG0012.jpg
I haven't drained the engine oil yet, could give that a go if i have any time in light tomorrow.
Thanks for your help Thumbs Up Karma
neil.
PostPosted: 19:20 - 08 Jan 2012    Post subject: Reply with quote
Next thing to try is adjusting your clutch - if it is that, then there is nowhere near enough slack in the cable. You don't need to tighten the cable - you need to loosen it! As well as the adjuster at the lever end, further down the cable there's a locknut and adjuster, near to where the cable meets the engine. First thing to do is 'reset' the adjustment at the lever - wind it all the way in, then go for the locknut adjuster further down, when you have a bit of flop (free play) in the lever before it gets harder to pull in, you're there. You want to aim for about 1cm of floppy travel at the end of the lever, the 'ball' part, before you feel actual resistance in the cable itself.
Mehty
PostPosted: 20:55 - 08 Jan 2012    Post subject: Reply with quote
I set the clutch cable up as described and it worked! Needs a little fine adjusting, but its working Very Happy Actually feels smother than before (must have been quite an old iris chain/sprockets on there)
Thank you all for your help, If your ever down 'er sometime after march there will be some drinks waitin' Wink Karma
There is a gap of 4 years, 45 days between these two posts...
aallcock123
PostPosted: 13:35 - 22 Feb 2016    Post subject: Reply with quote
Hello, I'll admit I'm really new to working on my own bike but owning a YBR myself I can say that I had a similar problem with false neutrals, gear slipping and general annoying crap when I didn't have my chain adjusted properly.
Have you checked it isn't too loose or tight?
Aron
Evil Hans
PostPosted: 13:53 - 22 Feb 2016    Post subject: Reply with quote
Aron
Jesus H Christ ... he fixed it four fucking years ago.
aallcock123
PostPosted: 14:43 - 22 Feb 2016    Post subject: Reply with quote
[quote="Evil Hans"][quote="aallcock123"]Hello, I'll admit I'm really new to working on my own bike but owning a YBR myself I can say that I had a similar problem with false neutrals, gear slipping and general annoying crap when I didn't have my chain adjusted properly.
Aron[/quote]
Jesus H Christ ... he fixed it four fucking years ago.[/quote]
Oh fucking hell didn't even look at the date haha
Evil Hans
PostPosted: 15:13 - 22 Feb 2016    Post subject: Reply with quote
No... or the bit at the end where he said he'd adjusted it and it was now working.
Poor obs. You'll end up Potato. Wink
The last post was made 10 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 94.8 Kb
