nbr: car advice - oil leak
dextersaurus
PostPosted: 12:25 - 08 Jan 2012    Post subject: nbr: car advice - oil leak Reply with quote
Hi guys.
So I've got an oil leak in my car, coming from just behind the sump. Its not been too bad but when I got up this morning there was a decent patch of oil on the ground, and the underside of the sump and gearbox are covered in oil.
So, what's the best thing to do about it? Its not really a disposable car as its got low milage and still got a lot of life in it...
I'm guessing I could ask my mate (who owns a garage) to pull the engine and re-do the sump gasket? Any idea how much this would cost normally? Hell probably charge me for parts and next to no labour, but its just if worst comes to worst, and I'm needing to get its 75k service stamped in the book.
Car is a 1.6 citroen xsara vtr.
Cheers.
Dunc
PostPosted: 12:36 - 08 Jan 2012    Post subject: Reply with quote
Depends on the particular car (and I don't know that car). On some taking off the sump is an easy job, while on others it might be difficult as the gearbox casing is in the way.
If a simple type then you could probably do it on the drive in a couple of hours with little effort (time taken because you need to be clean, will be working on the ground and they sometimes have a hell of a lot of small bolts rather than a couple of large ones.
tatfan
PostPosted: 21:55 - 08 Jan 2012    Post subject: Reply with quote
If it's leaking quite a bit over night, put a bucket or something similar under the car, where it drips. In the morning, pour leaked oil into engine. Therefore, no oil loss. Laughing Wink
mrtEE
PostPosted: 22:04 - 08 Jan 2012    Post subject: Reply with quote
Sign up on here:
https://www.cxoc.net/index.php
They are a friendly and helpful bunch Thumbs Up
PostPosted: 22:21 - 08 Jan 2012    Post subject: Reply with quote
I'd value a 75K Xsara as scrap plus a bag of crisps[1], before you go ahead and spend any money on it.
[1] From a supermarket branded multipack.
dextersaurus
PostPosted: 22:23 - 08 Jan 2012    Post subject: Reply with quote
It's not a load of money i'll be spending anyway. it's had a load of work done, FSH with it. 's all good. i've gotta make it last another year and a half.
pits
PostPosted: 23:41 - 08 Jan 2012    Post subject: Reply with quote
use a funnel system to catch the oil and then put it back in the engine
Poseidon
PostPosted: 23:54 - 08 Jan 2012    Post subject: Reply with quote
I'm with roger on this one. I was at a motor auction the other night and saw a xsara 2.0HDI on a 51plate with 90k on the clocks and long MOT (september next year IIRC) go through. Sold for £260. Sounded superb, started no bother, no smoke or rattles, no fluids left underneath (despite it having been stood there for at least 24hours). It was sent from a main dealer (who most probably took it in px) so no real reason to suspect it was a private individual trying to unload a pup.
The only reason why I didn't buy it was because I'm waiting on a chunk of money coming in next week, which I'll be using to buy something like the 2004 C-max with FSH, under 60k on the clocks and nearly a years MOT I saw go through, sold at a sniff under £1400
1977 Honda CG125
Shaft
PostPosted: 01:30 - 09 Jan 2012    Post subject: Reply with quote
If you're happy with the rest of the car and you're only paying parts, plus a drink for the guy doing it, get it done.
It won't be an engine out job, the worst way it's dropping the subframe a bit and I'm pretty certain you can do the sump gasket on those with everything in situ.
Gasket will be 30 quid max (might even be a tube of sealant) then whatever you see fit to give your mechanic, should come to no more than a ton.
I'm Mr Bangernomics, but I wouldn't scrap an otherwise good car for that.
dextersaurus
PostPosted: 17:11 - 09 Jan 2012    Post subject: Reply with quote
xsara isn't a desirable car. i'd have something nicer if the insurance was cheaper, but for my 20 year old self with 0 no claims, this will do till i can rack them up.
Dunc
jimspeed
PostPosted: 22:20 - 09 Jan 2012    Post subject: Reply with quote
It would be unusual for the sump gasket to leak that badly suddenly and also when parked the oil level would be below the gasket level.
If its a steel sump you may find that its rusted thru (yea sounds daft but seen loads) or ot could be being pumped out thru a leaking seal like on the oil filter, either way you need to get it cleaned up and find where its coming from as once it gets into the front suspension rubbers it will quickly kill them.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Robby
Dirty Old Man
PostPosted: 22:48 - 09 Jan 2012    Post subject: Reply with quote
Jimspeed is correct here. It's fairly unusual for a sump gasket that has never been disturbed to start leaking. They are a shaped rubber gasket usually, so substantial, and the constant exposure to warm oil stops them from drying out and cracking as rubber can.
More likely, in my experience, is a sump plug or oil filter that has worked slightly loose.
Degrease the area, check the sump plug and oil filter are screwed in, then start up and see where it's leaking from. If you fully degrease and clean the area (a ballache, I know) you can dust with talcum powder to find a leak easily.
dextersaurus
PostPosted: 23:57 - 09 Jan 2012    Post subject: Reply with quote
Cheers guys.
Gasket was just a rough guess as it seems to be in that area.
We'll get the car up on the 2 post and have a look-see underneath...
Hopefully it's something simple like the oil filter as that'll be getting changed anyway.
Dunc
The last post was made 14 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 81.59 Kb
