How many injuries after accidents are due to....
Lupine Lacuna
PostPosted: 16:44 - 09 Jan 2012    Post subject: How many injuries after accidents are due to.... Reply with quote
poor gear?
And by that I don't mean wearing a shell suit, I mean, say full leathers but with low quality armour, or poorly fitted leathers and or armour, etc?
What is the best thing to do to protect yourself?
I am contemplating covering myself in Forcefield armour, then in my (which I already have) Kevlar jeans and then a seperate leather jacket. Is this a good idea?
PostPosted: 16:48 - 09 Jan 2012    Post subject: Reply with quote
Suspect plenty comes down to luck as the the actual accident you have.
Think T.C has said that armour can cause injuries (from memory one was is back protectors riding up in an accident until they hit the helmet, ramming the riders head and breaking their neck).
PostPosted: 16:55 - 09 Jan 2012    Post subject: Re: How many injuries after accidents are due to.... Reply with quote
If you want to spend time and money protecting yourself, to my mind the very best thing you can do is learn not to crash.
The vast vast majority of crashes could be pretty easily avoided with some appropriate training (both fault and 'non fault'), so that's what I'd focus on first.
I've certainly had minor injuries due to ill fitting 'protection'.
Good fitting clothing is certainly a good start. And of course the best gear is the gear you actually use.
Fitted one piece leathers are going to offer the best protection.
yambabe
PostPosted: 16:55 - 09 Jan 2012    Post subject: Reply with quote
What Keith says basically.
If having more gear makes you feel safer, by all means go for it but don't fall into the trap of thinking that cos you are wearing "better" armour you are now invincible and can ride like an idiot.
It's all headology isn't it?
PostPosted: 16:56 - 09 Jan 2012    Post subject: Reply with quote
Badly fitting or poorly restrained armour is a problem because it can cause a stress point/edge where you go from the armoured to non-armoured point and encourage further injuries such as broken bones.
I have heard anecdotal accounts of a Marks and Spencer cheese sandwich having been put in the testing machine on a quiet Friday afternoon and passing the required test to gain a CE mark for motorcycle body armour. I believe this to be true and no, I don't know what sort of cheese.
As a general rule though, your gear doesn't give you as much protection as you think it does. It's all pretty good at abrasion resistance. Impacts are another thing entirely.
Trying not to fall off in the first place is the best plan. I personally would rather have no armour than poorly fitting armour which is why I took it out of my jeans.
PostPosted: 17:02 - 09 Jan 2012    Post subject: Reply with quote
This was in RiDE magazine a couple of years back when they tested a load of armour. IIRC it was a standard cheddar (grated) sandwich. The addition of pickle could have increased it's impact rating to level 2. Wink
dudders7
PostPosted: 17:03 - 09 Jan 2012    Post subject: Reply with quote
I think this would be the best safety you could get, on the expensive side but as we used to say to customers in the bike shop I worked at when they complained a helmet was to expensive the response was "how much is your or your childs neck worth?" https://www.getgeared.co.uk/HIT-AIR_GS-3_Airbag_Motorcycle_Jacket
Riding in the sun in Australia on a 04 Worked ZX10R along with a fleet of other crazy toys
PostPosted: 17:11 - 09 Jan 2012    Post subject: Reply with quote
According to government figures, well over £1m (cost of a road accident death). But despite that they won't spend £1m on giving me a helmet and leathers but would rather charge me VAT on some of the equipment.
PostPosted: 17:13 - 09 Jan 2012    Post subject: Reply with quote
I've 'oft posted about this:
https://www.johnsonleather.com/Downloadable_Articles/RideArticle_2-07.pdf
I think they chose a cheese and red cabbage sandwich to put the likes of me off that would have quaffed the cheese sandwich, invalidating it's use in a crash, 'cos it'd be "in ma bellah"!
PostPosted: 17:15 - 09 Jan 2012    Post subject: Reply with quote
Clearly not much given how virtually nobody has a five point harness fitted in their car, despite them costing less than a good quality motorcycle helmet.
P.
PostPosted: 17:20 - 09 Jan 2012    Post subject: Reply with quote
I had trainers, textile bottoms and textile jacket all with armour removed.
I had a crash yesterday and aside from the engine casing/exhausts burning through the textiles I came off relatively well.
I've crashed in leathers before and just has scuffed leathers Thumbs Up
Then again, the only time I've ever worn full gear (leather 2 piece, boots, back armour, kevlar gloves) I suffered the worst injuries I have ever had and am lucky to be alive Laughing
dudders7
PostPosted: 17:21 - 09 Jan 2012    Post subject: Reply with quote
It would be cheaper for them to provide bikers with high quality gear to help to prevent fatalities. A similar air bag system came up trumps when tested on a track.
Lupine Lacuna
PostPosted: 17:24 - 09 Jan 2012    Post subject: Reply with quote
But surely something like knee pads makes a huge difference? Imagine a slow speed spill and then hitting the knee into something. If there is nothing to absorb the impact you are seriuosly stuffed.
P.
PostPosted: 17:36 - 09 Jan 2012    Post subject: Reply with quote
My knee hit the deck followed by my tank/frame at 60ish mph.
My knee is fine. My textiles were mashed, there is a little bruise, but cant feel it Thumbs Up
PostPosted: 17:37 - 09 Jan 2012    Post subject: Reply with quote
I've fallen off mountain bikes loads of times.
The initial impact is the same or sometimes higher.
It's the height that hurts. So you can lowside a bike from a corner and be fine because you're on the floor already pretty much. Highside a bike at lowish speed and you're coming down from a decent height.
Of course tumbling after a low side is going to cause problems however.
If you meant your knee hitting something else - you're probably as likely to hit an un-armoured section.
PostPosted: 17:42 - 09 Jan 2012    Post subject: Reply with quote
So imagine hitting your knee off a kerb at 20mph and hitting your knee off a kerb at 20mph with a Marks and Spencer Cheese sandwich between you and the kerb.
It doesn't make a whole lot of difference. Does make SOME difference but not all that much. There is only so much energy a 6mm thick piece of foam can realistically absorb.
PostPosted: 17:43 - 09 Jan 2012    Post subject: Reply with quote
Whatever speed you crash at, you fall from about the same height with a similar impact to the ground (except for a high side).
The nasty impacts are from what you hit while sliding along the ground, whether that is a curb or a car coming the other way.
Knee armour might help if your knee slides into the curb. Depending on the armour if might also transfer the impact force to whatever the edge of the armour is resting on. Might also mean having bulkier gear resulting in the knee being more likely to catch and twist. Suspect most of the time the knee impact wouldn't really matter compared to what else hit the curb (and I hate to think of the effects on your pelvis if you slid into a curb in a kneeling position).
Very few things are always going to help and never cause other problems.
PostPosted: 17:45 - 09 Jan 2012    Post subject: Reply with quote
Lovely sales tactic!
But most definitely a case for if you really value your and your childs neck, make sure you have the skills not to crash.
PostPosted: 17:50 - 09 Jan 2012    Post subject: Re: How many injuries after accidents are due to.... Reply with quote
I agree, but you'd be hard pressed to find someone more wedded to their pipe and slippers than me, and yet I've face planted on black ice. I'm damn glad that I was wearing knee, hip, and elbow inserts and a full face helmet.
And I do have a Hit Air vest, I just wasn't wearing it at the time (I mean, what was going to happen on a 1 mile trip?). Doh! Gear doesn't do you any good hanging up on the garage wall, so only buy what you're going to wear.
PostPosted: 18:03 - 09 Jan 2012    Post subject: Re: How many injuries after accidents are due to.... Reply with quote
Pipe and slippers, it would seem, doesn't make you good at noticing black ice Wink.
keggyhander
PostPosted: 18:42 - 09 Jan 2012    Post subject: Re: How many injuries after accidents are due to.... Reply with quote
Nor does it give him the good sense to take the car instead on a black-ice-likely morning.
bikertomm
PostPosted: 18:49 - 09 Jan 2012    Post subject: Reply with quote
In response to OP, probably very little.
PostPosted: 19:10 - 09 Jan 2012    Post subject: Reply with quote
I recently have had a crash.
I was wearing elbow armour, armoured gloves and a cordura jacket. I broke my wrist badly. I smashed it into 5 pieces.
I was wearing jeans... I didn't injure my legs.
I was wearing non flex sole boots with armour and tough leather uppers. I broke my foot in three places. The boot was undamaged.
The conclusion you can draw from this is... its all down to the luck of the draw anyway. I could go out tomorrow wearing Crowtree leathers, an Arai, full Knox protection including chest and back, and some Daytona boots, and I could crash and die. Or I could go out tomorrow with a piss pot lid, a paddock jacket, jeans and trainers, and I could crash and bruise my knee.
There are more factors in an accident than just protection. Karma
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
LordShaftesbu...
PostPosted: 19:21 - 09 Jan 2012    Post subject: Reply with quote
When I had my off I was wearing no leg protection. The only part of my body that was injured was my legs, specifically a broken kneecap and severe abrasion injury on that knee. If I'd had my textile trousers on, my kneecap would probably not have fractured and I definitely wouldn't have had the open wound. It was the open wound which meant I needed to go into theatre, and it was the surgery which left me with no sensation in the skin over that knee.
I always wear my padded trousers now.
Shaft
PostPosted: 19:29 - 09 Jan 2012    Post subject: Reply with quote
I've never worn armour and never felt the need to, the closest I've come to it was when I had my leathers made; they had a double layer of material and some padding in strategic areas, but I never put them to the test, so I can't comment on whether it makes a difference.
Having said that, I do watch speedway, where broken bones are an occupational hazard; during the season, a week hardly goes by without at least one rider breaking something.
They abandoned leathers some years ago, preferring the lighter weight and easier movement offered by kevlar based suits, but armour is mandatory; elbows, knees, hips, shoulders and back, with some riders now using neck braces.
Average speeds are in the order of 50mph and probably 95+% of injuries are caused by impacts, either with the ground, the safety fence, or another rider(s).
Most common injuries are broken hands, ankles, collarbones and legs/thighs, pretty much all the bits that aren't protected by armour, and that's the same set of injuries that were common before armour was invented.
The only conclusion I can draw is, armour seems a bit of a waste of time, because it protects the bits that don't seem to come off badly in impact accidents; might save you a few bruises at low speeds, but anything over, say, 20mph it's still a lottery.
The last post was made 14 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.01 - MySQL Queries: 13 - Page Size: 139.3 Kb
