| carterkay1212 |
 carterkay1212 L Plate Warrior
| P.addy |
 P.addy Red Rocket
| dangerousdave |
 dangerousdave Traffic Copper
| jez125 |
 jez125 Nova Slayer
 Posted: 23:33 - 09 Jan 2012 Post subject: hi |
hi i had the same problem with my rs 125
is it overheating? as mine used to cut out after doing a mile or so and wouldn't start until it had cooled down, due to thermostat was knackered so there wasn't a constant flow cooling down the engine.
Also take the carb off clean the jets and clean air box out also filter from fuel tank
after doing this not had a problem since hope you get it fixed  |
| dangerousdave |
 Posted: 00:12 - 10 Jan 2012 Post subject: Re: hi |
Won't be overheating due to a faulty thermostat as the DR125 is air-cooled so doesn't have a thermostat.
If it's overheating, the spark plug electrode will be white when removed, so that can be checked pretty easily.
Has the bike still got an air-filter ? Removing the air-filter can make these overheat due to the fuel mixture becoming too lean.
As others have said, check the engine oil is the correct level in the sight glass, and top up if necessary.
Cleaning out the carb is a good idea too, can be done quite easily by undoing the drain screw, which will flush out any debris immediately at the bottom of the float bowl. For a more thorough clean, remove the carb and unscrew the float bowl and give it a good clean up. Inside the carb are brass jets which the fuel flows through. If there is any muck in the bottom of the carb then this can block these jets and stop the engine. They can be blown out until clear. If you have found alot of muck in the bottom of the carb then buy a fuel filter for a quid which will keep everything running sweet. ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
The last post was made 14 years, 176 days ago. Instead of replying here, would creating a new thread be more useful? |
