Other mods with new exhaust
shippy
PostPosted: 17:19 - 10 Jan 2012    Post subject: Other mods with new exhaust Reply with quote
i have a derbi senda x-race 50 and i have been looking at the tecnigas enox exhaust system for it.
i have been told that if change the exhaust i will also need to make the main jet size bigger or it will cause the engine to bog?
will i need to change anything or can i just do a straight swap?
thanks
at106
PostPosted: 18:10 - 10 Jan 2012    Post subject: Reply with quote
If you change the exhaust to a performance exhaust you HAVE to upjet by around 5% otherwise the engine will run lean and then seize.
shippy
PostPosted: 17:29 - 11 Jan 2012    Post subject: Reply with quote
could i not just get the fuel/air ratio adjusted?
PostPosted: 17:33 - 11 Jan 2012    Post subject: Reply with quote
Upjetting will adjust the air fuel ratio.
HD
PostPosted: 17:37 - 11 Jan 2012    Post subject: Reply with quote
It's not a massive job, don't get scared. All you have to do is loosen the jubilee clip holding the carb onto the reed block then twist the carb to face you. Then take out the two screws in the float bowl (it is good to drain the carb first else fuel gets everywhere) and take the bowl off. Make sure it doesn't touch any parts of your dirty engine. Put it to one side. Now unscrew the middle jet, it will be the biggest one right in the centre. Take it out and put your new, bigger jet in. Now pop the float bowl back on, kick it over like 10 times and it should start fine.
Beware though, it can take some fine tuning to get it to run right.
at106
PostPosted: 17:39 - 11 Jan 2012    Post subject: Reply with quote
As Big_Ham said that's what upjetting does. However if you mean adjusting the air mixture screw then no. The air mixture screw only alters the air mixture below about 1/4 throttle.
SpannerMonkey
PostPosted: 19:50 - 11 Jan 2012    Post subject: Reply with quote
It's really not a hard job. On my tomos I had to change jets 7 times (Cause I'd made so many mods) and by the end of it, I could do a jet change in about 2 minutes.
But trust me, if you dont heed the warning about upjetting, you may as well put your bike in a scrappie. So many friends of mine have destroyed bikes by not upjetting... and only one has gotten away with it. It doesnt take days for it to happen either, it can happen the first time the engine is ran with the exhaust on if you havent upjetted
My bike? A YX140 powered one-off Monkey Bike, something a little different!
The last post was made 14 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.48 Sec - Server Load: 8.56 - MySQL Queries: 13 - Page Size: 52.57 Kb
