Buying a new caliper or fix it ?
EXC-Rider
PostPosted: 13:29 - 11 Jan 2012    Post subject: Buying a new caliper or fix it ? Reply with quote
my front break caliper on my CRF450 is im guessing the pistons seized and i and still push the bike forward with the break fully applied, i know its not the pads as they are almost new.
if i was to fix it i have no idea what i would be doing so would be shooting in the dark when i take it apart and that breaks are quite important
also it leaks oil a slight bit so there prob need some work to it i guess.
owned bikes: DR50, Thumpsta 110 , Honda CR85, Speedfight 100, Yamaha XT125X, Honda CRF450, Honda Hornet '07
current bikes: KTM EXC525 AKA the wheelie machine
A friend in need is a friend indeed but a friend with weed is better!
PostPosted: 13:41 - 11 Jan 2012    Post subject: Reply with quote
Buying a new one won't help. The 'oil' it is leaking is brake fluid, it needs pressure for the calliper to work. It needs a rebuild an re-bleeding.
You sound completely mechanically inept, so take it to a garage. It shouldn't cost more than £20 for the seals £5 for the fluid and an hours labour £60? from a dealer. If you take it to a private local garage it probably will set you back £50-60 total.
EXC-Rider
PostPosted: 13:46 - 11 Jan 2012    Post subject: Reply with quote
I would take it to a garage but i kinda wanna learn how to fix it my self for the future. And i know it was break fluid leaking and last time i bled them it work fine just happened after it sat in the shed for the winter.
and im only young so still learning how to repair most stuff. Very Happy
Apexes
PostPosted: 13:48 - 11 Jan 2012    Post subject: Reply with quote
Calipers are fairly simple, have a browse on youtube for video's - that's how i've learnt most of my maintenance
Current Ride: 2011 Kawasaki Z750
PostPosted: 13:51 - 11 Jan 2012    Post subject: Reply with quote
If you can pull the brake lever hard, feel pressure in the system and still move the bike the caliper is either VERY seized (in which case it would have pretty much no effect), or more likely it has seized badly on the pins it slides on (suspect it is a twin piston sliding caliper). If so getting it to slide on those pins again will be the difficult bit.
PostPosted: 13:53 - 11 Jan 2012    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=33116
Start there.
Fizzer Thou
PostPosted: 14:55 - 11 Jan 2012    Post subject: Reply with quote
PM sent
Always have a 'Plan B'
EXC-Rider
PostPosted: 15:08 - 11 Jan 2012    Post subject: Reply with quote
Thumbs Up Karma
The last post was made 14 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 57.66 Kb
