How to remove stuck screws?
moppy
PostPosted: 18:08 - 11 Jan 2012    Post subject: How to remove stuck screws? Reply with quote
Decided I'd have a go at taking off some of the fairing on my ZZR6 today and having a look at the downpipes, do some general cleaning etc. It was going well for the exterior screws but as soon as I got to screws that were on the "inside" of the bike, so many of them were just seized stuck and no amount of WD40 would loosen them.
There are just generations of mud & dirt caked on to the screws & bolts, and I could not loosen it one bit. My screw driver is shit though, need to buy a new one, but is there anything else I can do to help loosen these? I would love to be able to take all the fairing off and clean it individually, make it look nice, then stick everything back on etc.
Are things like these something good to replace the old bolts with as well?
Babba This post is not being displayed because the poster is banned. Unhide this post / all posts.
The Artist
PostPosted: 18:40 - 11 Jan 2012    Post subject: Reply with quote
HEAT, more HEAT
moppy
PostPosted: 18:42 - 11 Jan 2012    Post subject: Reply with quote
But this is screws into plastic. Wouldn't hitting it with a hammer risk the plastic cracking too? And as for using heat, again, plastic melting?
PostPosted: 18:47 - 11 Jan 2012    Post subject: Reply with quote
If they're stuck, you'll have to do something to get them out.
PLUSGAS, then impact driver, then try cutting a slot and impact driver again, then drill the heads off, remove the fairing, and extract the studs with mole grips or similar.
The Artist
PostPosted: 18:48 - 11 Jan 2012    Post subject: Reply with quote
Ahh
Then cut a slot in the head and use a big flat blade screwdriver
nofear
PostPosted: 19:17 - 11 Jan 2012    Post subject: Reply with quote
Try an Easy Out set.
I had a bugger of a screw that refused to come out on my handlebars. I tried absolutely everything to get it out but it wouldn't budge.
Got one of these
https://www.axminster.co.uk/axminster-cobalt-drill-and-easy-out-set-prod462398/?src=froogle
and it came out on my first attempt. You will need to replace the screw afterwards though.
The last post was made 14 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 10.03 - MySQL Queries: 13 - Page Size: 51.84 Kb
