Having trouble painting my Tamiya bike model
apple tango
PostPosted: 16:58 - 11 Jan 2012    Post subject: Having trouble painting my Tamiya bike model Reply with quote
This is the first model i've ever built, so like a newbie i'm having issues.
I'm trying to paint some parts using black enamel paint with a brush. It's not working properly though. When applying the paint, it looks kind of watery on the shiny plastic part.
https://s13.postimage.org/uczm957lj/11012012196.jpg
image hosting gif
Am i meant to sand the part down first with sand paper?
Or am i meant to use a primer or something?
CBR125 -> Bandit GSF600 '99 -> SV650 02
-Savage-
PostPosted: 17:05 - 11 Jan 2012    Post subject: Reply with quote
Have you mixed up the paint properly? the paints settle easily, and need mixed either by shaking, or if stood for a while they will need stirred to re suspend the pigments.
PostPosted: 17:07 - 11 Jan 2012    Post subject: Reply with quote
Have you washed the parts in warn soapy water first, the release agent they use to get them out of the mould can give some weird effects sometimes.
Also consider that you'll probably need to do a couple of thin coats rather than one thick one, even more so if you're brush painting.
apple tango
PostPosted: 17:16 - 11 Jan 2012    Post subject: Reply with quote
I didn't shake the little tin of paint first no, and it's been sat for a while so maybe that's the reason.
apple tango
PostPosted: 17:17 - 11 Jan 2012    Post subject: Reply with quote
No, i didn't know i had to do that. I'll give that a go too.
PostPosted: 18:21 - 11 Jan 2012    Post subject: Reply with quote
#33 matt black humbrol enamel is one of the best covering ones out. The #21 gloss black is much harder to work with. If I wanted gloss black I always used to use #33 then paint over it with clear gloss.
Buy a packet of cocktail sticks to stirr the paints with. They DO need to be stirred as has already been pointed out.
While you have the black out, undercoat any parts that are going to be painted with metallic paint using it too. Matt black makes an excellent undercoat for a very realistic metallic finish if you use a "drybrush" technique with the metallic colour. I used to use #11 for pretty much all metallic finishes and just drybrushed it on more or less over the black to achieve different effects.
Picture related. It's a 1:72 scale airfix model I made.
https://i48.photobucket.com/albums/f216/stinkwheel/mustang1.png
ninja_butler
PostPosted: 18:59 - 11 Jan 2012    Post subject: Reply with quote
Extra tip: Most enamel paints need to be thinned before application; build up the layers to full opacity rather than try to do it it one hit.
D O G
PostPosted: 00:28 - 12 Jan 2012    Post subject: Reply with quote
Stir it as people have said, I'll bet the stirrer comes out with a big blob of pigment on it. Stir it, then shake like a bastard, then use.
Frost
PostPosted: 02:13 - 12 Jan 2012    Post subject: Reply with quote
I always used to use Black/White/Grey undercoat before using any other colours depending on what range of colours the final thing was going to be. Metallic paint often needs stirring AND a good shaking.
Visitor Q
$25 whore
PostPosted: 09:46 - 12 Jan 2012    Post subject: Reply with quote
Spray painted base coats are also very helpful.
The last post was made 14 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 66.7 Kb
