Common V twin engines and widths?
m1tch
PostPosted: 23:37 - 12 Jan 2012    Post subject: Common V twin engines and widths? Reply with quote
Hi all,
I am just researching bike engines for a project, I was planning on getting a single cylinder dirt bike engine like a CR250, I was then thinking about V twin engines (due to the space limitations the engine can't be that wide).
I have seen the Honda VTR engines (400 - 1000) are v twin and seem to be fairly common, found a whole project VTR400 bike for £250! I am just wondering what sort of width the engine was or indeed if I can have some suggestions as to V twin engines that are common - guessing the Honda VTR engines are the most common?
Thanks in advance!
PostPosted: 23:46 - 12 Jan 2012    Post subject: Reply with quote
The most common V Twin would be a Suzuki SV650 as far as I know Honda have never made a VTR400 only 250s and 1000's
m1tch
PostPosted: 23:56 - 12 Jan 2012    Post subject: Reply with quote
Ah, I think im thinking of Honda VFRs Rolling Eyes *fails* lol can you tell im new to bikes? Sad
Hmm thats pretty good value for a complete engine:
https://www.ebay.co.uk/itm/SUZUKI-SV-650-2003-REG-COMPLETE-ENGINE-FREE-POSTAGE-/160426132350?pt=UK_Motorcycle_Parts&hash=item255a24837e
stonesie
PostPosted: 00:31 - 13 Jan 2012    Post subject: Reply with quote
Thats a 'Pointy' (MK2) engine, to get that running you would need oil and water cooling and either the rest of the fuel injection system or a set of carbs from an earlier bike (curvey - upto 2002)
m1tch
PostPosted: 08:52 - 13 Jan 2012    Post subject: Reply with quote
Vincent wrote:
Awesome Smile what is that engine like for spares etc? I might be able to find a cheap engine, but there might not be engine spares like pistons etc
I want to stay with carbs as they are easier than having to worry about fuel injection with all the wiring etc
Mikey3
PostPosted: 13:57 - 13 Jan 2012    Post subject: Reply with quote
https://www.ebay.co.uk/itm/SUZUKI-SV-650-engine-2000-spares-repair-/220927922670?pt=UK_Motorcycle_Parts&hash=item33705491ee#ht_500wt_1202
Have a look at that mate, its the 2000 spec SV650 engine, Carbs too s o you don't have the complications of Fuel Injection, might help ease the understanding.
HTH
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
weasley
PostPosted: 14:21 - 13 Jan 2012    Post subject: Reply with quote
Honda NTV?
Monster?
m1tch
PostPosted: 14:39 - 13 Jan 2012    Post subject: Reply with quote
HTH
Mike
Piston and conrod are a slight mess on that one Rolling Eyes
I am just researching what engine I should focus on, the CR250 engine is at around 50bhp and being 2 stroke is pretty simple, the carbed SV650 looks like to be around 65bhp but an extra 400cc of engine plus weight.
I will probably be looking at buying the engine next year or so, so quite some way off - due to space limitations of storing engines/bike parts at the mo, but it gives me a chance to check out all the options.
The Monster engine looks interesting as its air cooled and there won't be any fairings to get in the way of airflow on that so thats an option - I believe that the later monster engines were water cooled though?
Robby
Dirty Old Man
PostPosted: 14:46 - 13 Jan 2012    Post subject: Reply with quote
What is the project?
If its something like a go-kart, a 50-60hp engine will be seriously quick, and you'll need to have a strong chassis design with decent welding to make it work.
jamesrs250
PostPosted: 15:36 - 13 Jan 2012    Post subject: Re: Common V twin engines and widths? Reply with quote
BLUEX5 wrote:
m1tch wrote:
Hi all,
Thanks in advance!
Come on hoddie, you know sock accounts are not allowed!
Mikey3
PostPosted: 15:42 - 13 Jan 2012    Post subject: Reply with quote
That they are, but he said the cylinders and everything else are in working order, could possibly buy pistons and con rods, as well as this engine for less than the price of a fully functioning one (look to be going around £500 mostly, bar a couple, so im sure you could pick up pistons and con rods for less than £400 - would give you some mechanical experience too Smile.
But as Robby said, what exactly is the project?
It would help as to what power and weight you're looking for and would save us throwing random engines at you (metaphorically Laughing )
Mike
'04 Yamaha WR450F
PostPosted: 16:38 - 13 Jan 2012    Post subject: Reply with quote
Approximately 360mm for the crankcases and 220mm across both cylinders for the non FI model, but pretty sure all those details are the same.
New con rods means new new crank, which is generally expensive and hassle.
m1tch
PostPosted: 18:29 - 13 Jan 2012    Post subject: Reply with quote
Thanks for the specs, I will go and check how much space there is, the engine is indeed for a kart, the reason why I am going to try and fit it in the OEM mounting area and looking for a V twin is due to the fact you need to extend the frame to fit the larger inline 4s like on this Gixxerkart:
https://www.youtube.com/watch?v=_nQW0jsqv4Y
Or do some serious modding like on this 1000cc nitrous kart
https://www.youtube.com/watch?v=G7Q8t7XJ5hY
Much safer than trying to fit an inline 4 engine in the OEM position:
https://www.youtube.com/watch?v=ls5dN2PiTuk&feature=related
Robby
Dirty Old Man
PostPosted: 18:43 - 13 Jan 2012    Post subject: Reply with quote
A few more things to consider then.
The sump will need some playing with. In bikes, the bike leans when it corners, keeping the oil in the bottom of the sump. In a kart, the engine is always upright so the oil can slosh away from the pickup during longer corners. No oil = knackered engine. Deeper, baffled sump with a longer pickup is useful.
You also don't want to be playing with the orientation of the engine - if you lay it forwards/backwards/sideways without sorting out the oiling then you will have a problem.
Have a look at the Honda XL600R. It's a 600cc single, making about 35hp, would be quite good in a cart. Dry sump with an oil tank too, which sorts out the oiling.
Don't bother just buying an engine, buy an MOT failure bikes so you see it running, and have the carbs, electrics and wiring, and exhaust.
m1tch
PostPosted: 18:55 - 13 Jan 2012    Post subject: Reply with quote
Im planning on getting a running bike/mot failure/cat B write off, seen a few around, will see if its worth going 4 stroke due to the reduction in power and increase in weight, the CR250 engine is 250cc and is around 50bhp, its nice to know that there are still large singles though, didn't know they made singles that large.
Found some photos from a superkart forum on mounting an inline 4 engine, driving position isn't the best
https://www.ekartingnews.com/viewtopic.php?p=426754&sid=db9383199c0386e2fcf51db8459c4a46
Issue being is that I can't make the current chassis wider firstly due to the lack of welding skill - although I have a few mates who can weld, and secondly I need to be able to transport the kart, fits fine in the back of my Volvo, probably wouldn't if I had to extend the frame out to the side etc
Found a VFR400 project bike:
https://www.pistonheads.com/sales/3546439.htm
Guess thats the sort of thing im looking for?
Robby
Dirty Old Man
PostPosted: 19:00 - 13 Jan 2012    Post subject: Reply with quote
A VFR400 is exactly what you don't want. An NC24 in particular, because they are the worst bike in the world.
It's a V4, 400cc, 55hp bike. Absolute bastard to work on. To wide for what you want to do, and peaky power delivery.
I would take a broad torque spread over peaky power delivery any day of the week in a kart, I want the back to break traction in a gradual and controllable way. This is also the reason I would avoid 2-strokes.
How are you going to work out the clutch and gears?
m1tch
PostPosted: 19:07 - 13 Jan 2012    Post subject: Reply with quote
Thats exactly why I am asking questions about engines Very Happy thanks for the info I will avoid lol
The shifter karts have a handle to the right hand side to shift the gears (as if you would with your foot) the clutch is a seperate handle/lever/paddle on the left that is only used to set off:
You can see the shifter on the right:
https://www.youtube.com/watch?v=h1ggVfktdSo&feature=related
You can also see the size of the twin cylinder 250cc engine fitted to the superkarts that produce around 90bhp Smile
PostPosted: 19:18 - 13 Jan 2012    Post subject: Reply with quote
Endruo 2 strokes are some of the flatest power deliveries available in bike engines - 'bout the only way to get flatter is a 2 stroke trials Smile.
2 stroke motocross lumps do tend to be a lot peakier however.
m1tch
PostPosted: 19:52 - 13 Jan 2012    Post subject: Reply with quote
For power delivery im ok with all the power up top, because I won't be allowed on normal kart tracks I will be drag racing it at Santa Pod, so I will only need to go up the full rev range once, then I will be shifting all at the top end, infact if all the power was up top it would mean less power going to the wheels at launch meaning I can get some grip, then the power band kicks in.
m1tch
PostPosted: 21:17 - 13 Jan 2012    Post subject: Reply with quote
Vincent wrote:
How about a Suzuki RGv250 lump then - still a V2. I can remember the 2 stroke Zip Karts from the '70s they were great fun and bleeding fast Cool
Thats an interesting engine, apparently the same as the Aprilla RS250 - am I correct that its a V2 2 stroke?
The last post was made 14 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 136.3 Kb
