How to disassemble a ball joint
killa
Won't Shut Up
PostPosted: 11:52 - 14 Jan 2012    Post subject: How to disassemble a ball joint Reply with quote
I'm trying to get this apart.
https://i1190.photobucket.com/albums/z451/SV_KB/DSC_0986.jpg
Whats the best method of getting the ball joint apart?
I don't have a specialised tool.
Damon
PostPosted: 12:07 - 14 Jan 2012    Post subject: Reply with quote
Underneath the rubber sleeve there will be a clip. Undo that clip and the ball will drop out.
HTH Thumbs Up
killa
Won't Shut Up
PostPosted: 13:22 - 14 Jan 2012    Post subject: Reply with quote
HTH Thumbs Up
Are you sure?
I've pulled the rubber sleeve back, look underneath and it just looks like it's been popped in, if you know what i mean.
sickpup
Old Timer
PostPosted: 14:35 - 14 Jan 2012    Post subject: Reply with quote
A Suzuki gear change lever I believe. The ball joints on those don't come apart by choice, they fall apart.
Walloper
PostPosted: 15:57 - 14 Jan 2012    Post subject: Reply with quote
As Sickers says those are 'sealed-for-life' non-serviceable parts.
Cheap to replace just undo the nut from the threaded bolt-esq part on the other end of the ball, undo the locking nut and remove the socket part from the rod.
I had a BMW R1200GS that used to eat those ends where the gear shift linkage went under the frame into the gearbox. Bad/Shite engineering.
sickpup
Old Timer
PostPosted: 17:37 - 14 Jan 2012    Post subject: Reply with quote
On the Suzuki the ball is riveted in place as part of the lever.
Walloper
PostPosted: 20:57 - 14 Jan 2012    Post subject: Reply with quote
Tricky little Bastahd...
Well get the 6mm HSS drill and drill the twaaat out. Laughing
killa
Won't Shut Up
PostPosted: 10:28 - 16 Jan 2012    Post subject: Reply with quote
Thanks guys Thumbs Up
The last post was made 14 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 61.66 Kb
