How to approach this double mini roundabout?
Fifteen15
PostPosted: 21:02 - 15 Jan 2012    Post subject: How to approach this double mini roundabout? Reply with quote
Because everyone else is doing it, I want a go too Cool A few weeks ago I almost got smashed into by an M&S lorry. I don't know who was to blame, probably me though as I'm relatively new to the roads.
It was rush hour and I was waiting to enter the double mini roundabout. In order for it to be clear, I needed to wait for a vehicle to turn right towards the green arrow to block the cars on my right from going. I saw an M&S lorry coming, signalling right so I thought good, I can go now. He then proceeded to carry on going right into a U turn seconds after I set off. I had to twist the throttle right back to get away from him hitting me.
https://img715.imageshack.us/img715/7739/doubleroundabout.png
Who was to blame? And how do I avoid getting hit when people decide to do U turns on this particular double roundabout?
"Pain is weakness leaving the body, and blood makes the grass grow faster...but I'll wear my gear anyway"
PostPosted: 21:16 - 15 Jan 2012    Post subject: Reply with quote
You treat the two roundabouts as separate and indicate/maneuver accordingly.
As far as the incident - he indicated properly and you assumed he was going straight on when he wasn't. He could have been more courteous but otherwise acted properly and the onus is on you to be sure that he was taking the route you thought he was. It's a valuable lesson for you that I'm sure you won;t forget in a hurry.
I have a double mini roundabout near my house and that has happened a few times out there. One lady lost control when it happened and went through the front of the butchers.
iooi
PostPosted: 21:20 - 15 Jan 2012    Post subject: Reply with quote
You.....
He was on the roundabout indicating right, and you pulled out in front of him Embarassed
Does not matter if its a single/double/treble roundabout...... You give way to the right.
This is one reason I hate indicating on a roundabout.... If there are none, you don't move till you are 100% sure where they are going.
Also a lorry will need a lot more room to do a turn like that.
Babba This post is not being displayed because the poster is banned. Unhide this post / all posts.
Glenben92
PostPosted: 21:41 - 15 Jan 2012    Post subject: Reply with quote
You were technically in the wrong, but it's a bastard of a situation because he was right to indicate even if he was going straight on (better than having someone from that top junction pull out on him) and you should assume that he WILL be crossing your path (always assume this until you're sure it's not the case) but I'd likely have done the same thing because you could sit there all bloody day. It could probably be set out better but you were technically in the wrong mate, just mark it up as experience and it'll be an experience that'll probably save your life one day. Don't think of it as making a mistake, think of it as learning how to not make a mistake.
On a lighter note, never presume that you're in the wrong because you're new to the roads. In many instances new drivers, having not had a chance to pick up bad habits and still having the highway code/training fresh in their heads are capable of making better decisions than people who are driving on "auto-pilot". I know I'd trust 90% of new bikers before I'd trust a seasoned cager.
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Frog
PostPosted: 00:04 - 16 Jan 2012    Post subject: Reply with quote
Glenben92 wrote:
You were technically in the wrong, but ... just mark it up as experience and it'll be an experience that'll probably save your life one day. Don't think of it as making a mistake, think of it as learning how to not make a mistake.
This, but remember that theres a difference between legally right, and 'going to save your life' right.
Legally, you were in the wrong. Your logic was sound, in that he was 99.9% going to be going right, but actually, you need to look at what they are doing, not what they are indicating they will do.
Although he was was indicating directly, people frequently won't. You should look for changes in speed / direction. This indicates what they are actually going to do, which is frequently totally different to what they are actually indicating.
Sounds like you now know the colour of adrenaline Shocked
CBT 23/09/10 - Theory 19/03/11 - Mod1 19/04/11 - Mod2 06/05/11
Bikes: CBF125 (sold 30/10/10-25/09/12) - CB400 24/06/11 (broken) Sad - ER6-f 25/09/2012 Very Happy
defblade
PostPosted: 00:37 - 16 Jan 2012    Post subject: Reply with quote
Never
ever
trust an indicator.
Wait till you see they're actually doing what they say they're doing. Don't feel pressured by anyone behind you to pull out at risky moments, either. There's far too many times when someone doesn't realise they're giving a misleading signal (or even that it's on at all).
Anyhow, in this case, I'll bet the lorry was much further to the left of the road than required for a right hand turn and this could have been a clue that he was doing a U turn (lorries need space!). On a similar note, never ride up the inside of a lorry that's pulled out to the centre line... he's about to turn left and crush you.
So long as you don't get killed, this stuff will start to make (a 6th) sense... you're on the right track already by thinking about it and asking... we all make mistakes sometimes and those who admit they might have done something better in that situation (not really a question of "fault" or "blame" especially when it's bike vs lorry - better means avoiding the accident even if at possible cost of macho points) will end up the safest.
anthony_r6
PostPosted: 09:24 - 16 Jan 2012    Post subject: Reply with quote
U-Turning on those small roundabouts needs to be illegal. It's stupidly dangerous.
parkmoy
PostPosted: 10:16 - 16 Jan 2012    Post subject: Reply with quote
The lorry was signalling correctly. If he was going to turn towards the green arrow he would ideally have signalled a LEFT turn as he was level with the exit immediately prior. I say ideally because he may well have had too much on and too little time to do so.
Whilst you should never trust indicators, a left signal would have given you a clue that he might be intending to turn into your road. As it was the right signal indicated the opposite intention.
PostPosted: 10:30 - 16 Jan 2012    Post subject: Reply with quote
The dangerous bit is people not anticipating it.
In cases where I have done I always make sure my actions are slow and purposeful (there's one road in Reading where I always ended up doing it due to the bit you have to pull out and park having a mini central reservartion.
It looks like it's nothing to with the 'double' in this case, merely that this roundabout has a lot more space.
For a truck to do a u-turn, it has to pull out a fair way, so should be manoeuvring noticeably differently to a gentle turn to the right.
Motorcyclists expect other road users to recognise their idiosyncratic ways, yet so often don't learn about how other road users act (the classic is going inside a long vehicle on a roundabout.)
iooi
PostPosted: 18:10 - 16 Jan 2012    Post subject: Reply with quote
WTF........
This is a MOTORBIKE forum.... Riders have been known to go round and round and not come off for a few laps.....
The last post was made 14 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 75.07 Kb
