Power valve housing - leak
WannaBeDude
PostPosted: 21:01 - 13 Jan 2012    Post subject: Power valve housing - leak Reply with quote
Could i be leaking air in, through this, as all other angles have now been covered ... Rolling Eyes Karma
Lynxx
PostPosted: 19:24 - 15 Jan 2012    Post subject: Reply with quote
What bike is it ???
most 2 strokes with a power valve, if they were leaking air you would hear a significant increase in exhaust noise. IF you think its leaking, take the cover off and get some gasket material (not the liquid stuff) or a cereal box and make a new gasket.
if your going to use gasket paper or cereal box, take the cover off, clean it, then put your finger in the power valve area and get some black sticky stuff on it.. then wipe it on the sealing area of the power valve cover, after you have applied a thin layer all over set the power valve cover onto the cardboard and press down for a second.. pull it away and you have a template, all you need to do now is cut it out with a razor blade.
hope this helps.
Current: 1992 Suzuki GSF400V - 1984 Honda MTX200 (SOLD) - 1975 Honda Xl350 (SOLD) - 1993 Honda CB250 (SOLD)
WannaBeDude
PostPosted: 21:20 - 15 Jan 2012    Post subject: Reply with quote
2T 125 .. i'm gona get a athena gasket, i have exhaust paste if that helps. It's just the last area i could be letting air in and possibly the cause of lean running. Thumbs Up
The last post was made 14 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 35.98 Kb
