Rear wheel alignment; string method - you're joking !
dansidi
PostPosted: 16:16 - 15 Jan 2012    Post subject: Rear wheel alignment; string method - you're joking ! Reply with quote
Right.
I've been attempting to do the rear wheel alignment using the 'string along the length of the bike' method. It's impossible.
There are so many variables that can screw up the measurement that I'm convinced this method is useless. From the tread on the rear wheel being different on left and right sides forcing the string out one side more than the other, to the sting pressing against the centre stand or front disk, or any number of objects, to the front wheel needing to be excatly straight. The bike needs to be exactly level, the string perfectly straight without and kinks or twists. It just cannot work precisely enough to be worthwhile.
In fact, I'll bet (0.5p) than NOT A SINGLE ONE OF YOU on here reading this actually uses this method to align your rear wheel. I bet EVERYONE takes their bike to a shop to have this done. Yes, EVERYONE !!!
calm... calm.....
Also, I have one link on my chain which is utterly jammed solid. I can just about straighten it using a hammer but it will not loosen. Is it time for a new chain & sprocket set? None of the components seem worn out, just that one link.
Thanks for your advice.
current bike to first bike: SV650s K3, YBR125, Vespa GT125, Vespa ET4-125, Suzuki CS-50 (!!)
Mod 1 passed 02-11-2012
Mod 2 passed 05-12-2-12
PostPosted: 16:27 - 15 Jan 2012    Post subject: Re: Rear wheel alignment; string method - you're joking ! Reply with quote
Nope, although I do use a scaffold pole and not a piece of string.
Once it is in line I just make sure I turn the same number of flats on the chain adjusters to keep the wheel in line.
DrDonnyBrago
PostPosted: 16:39 - 15 Jan 2012    Post subject: Re: Rear wheel alignment; string method - you're joking ! Reply with quote
I have used the string method before, was fiddly but worked ok. A straight edge such as scaffold pole or length of angle iron is simpler though.
You only need to do it once. I ground new notches onto the chain adjusters on both sides and use these when adjusting the chain and therefore the wheel alignment, measuring the distance between back of swingarm and notch with with a vernier caliper Laughing (original markings are notoriously inaccurate).
Once the alignment is set you just need a way of keeping it the same on both sides when you adjust (i.e. new, accurate marker notches, count turns, count threads etc etc).
As for your stuck link, working them back and forth whilst covered in oil can help but only as a temporary measure, your chain is basically shagged and needs replacing.
anthony_r6
PostPosted: 16:45 - 15 Jan 2012    Post subject: Reply with quote
I've just dropped my bike in for it's MOT yesterday. Only thing I couldn't do was the rear wheel alignment. It was far to fiddly for me and I couldn't be assed with the hassle, told the garage to do it for me.
Ericck
PostPosted: 17:58 - 15 Jan 2012    Post subject: Reply with quote
Just made a right pigs ear of the chain adjustment on my bandit.
The adjuster plate was bent and after taking it off to straighten, couldn't remember what I done to the adjuster bolts so now fear wheel is misaligned.
Someone recommended the string method but it looks complicated,
think I'll just take my bike to a mechanic and know better next time.
Current Bike: 2004 Suzuki Bandit 600S
Previous Bikes: Yamaha FS1E, Mobylette Moped Thingy, Suzuki GS125, Kawasaki Zephyr 550, Kawasaki Zephyr 750, Kawasaki ER500, Suzuki Bandit 600, Honda CBR600F, Triumph Street Triple 675, Suzuki V Strom 650, Suzuki Bandit 1200, Suzuki SV650N, Honda CB500F.
Ichy
PostPosted: 18:28 - 15 Jan 2012    Post subject: Re: Rear wheel alignment; string method - you're joking ! Reply with quote
dansidi wrote:
Right.
I can't say that I have ever seen that before.
I prefer to measure from the swingarm pivot to the spindle. Works for me.
pits
PostPosted: 18:54 - 15 Jan 2012    Post subject: Reply with quote
My bike as little marks on the swing arm, align either side to both things, job done.....I hope?
Bendy
Mrs Sensible
PostPosted: 18:57 - 15 Jan 2012    Post subject: Reply with quote
I've never checked (or asked anyone else to check) wheel alignment in my entire life.
Babba This post is not being displayed because the poster is banned. Unhide this post / all posts.
Suntan Sid
PostPosted: 19:22 - 15 Jan 2012    Post subject: Reply with quote
Neither have I.
PostPosted: 19:52 - 15 Jan 2012    Post subject: Reply with quote
I did it with string. I usually use it as a check when I think the alignment marks might be a bit off. I don't think I've ever soley used string, and I've only done it when I think the handling is a bit sus or when I've replaced the entire swinging arm on a bike.
I didn't have any problem with it TBH. I just made a piece of wood the same width as the rear wheel to help the front bit of the alignment.
dansidi
PostPosted: 20:37 - 15 Jan 2012    Post subject: Re: Rear wheel alignment; string method - you're joking ! Reply with quote
Marki wrote:
dansidi wrote:
Right.
I guess it helps if your rear tyre is thicker than the string you're using. Have you seen what tyres they give you with a YBR ? Bleedin' razor blades, I tell ya !
PostPosted: 20:56 - 15 Jan 2012    Post subject: Re: Rear wheel alignment; string method - you're joking ! Reply with quote
Do that.
Or use the Mk 1 Eyeball. Of course, my Mk 1 Eyeball is a laser.
https://1.bp.blogspot.com/_TLhYHt6WJfw/SwAzVEFuqSI/AAAAAAAANYo/kGOKxyHoidc/s400/picard_as_borg.jpg
mysterious_rider
PostPosted: 21:00 - 15 Jan 2012    Post subject: Reply with quote
Just use something that is long and straight. A thick wooden ruler or something tends to do the trick for me.
Just slam in on the sprocket a few inches on (dont have it on the edge or it will throw the angle out) and just make sure it lines up with the front sprocket.
Sorted....
pits
PostPosted: 21:27 - 15 Jan 2012    Post subject: Reply with quote
Babba wrote:
You hope in vain. The marks are notoriously innacurate & really shouldn't be relied on to judge the wheel alignment.
Do a Google on motorcycle wheel alignment & you'll have lots to read up on. I prefer to use straight edges rather than string & if you do it right, you'll see just how far out your marks really can be.
Well, so far I haven't had any issues, nor my mates, nor anyone who has checked my bike, so this reading melarky you go on about sounds like a lot of effort for little gain, sounds like far too much effort.
HD
PostPosted: 22:08 - 15 Jan 2012    Post subject: Reply with quote
I just whack them all the way forward then wind them evenly out. Can't be that far out and never had any adverse handling effects, its not exactly motogp is it Laughing
dansidi
PostPosted: 22:22 - 15 Jan 2012    Post subject: Reply with quote
Well, here is how I did it in the end:
Vernier callipers to measure the distance between the very end of the swingarm and the inner surface of the chain adjuster.
As long as there is not too much crud built up on the inside surface of the chain adjuster I think it should work.
I took the bike out for a test and survived and it felt OK too so I guess doing the adjustment that way gives a reasonable approximation. Obviously doing the measurement so close to the axle is not ideal - being out by just 0.5mm could be crucial.
Many thanks for all the suggestions I will need to this this all again soon when I replace my gammy chain.
All this hassle because of one dodgy link in my chain.
Do they sell scaffolding poles on ebay...?
PostPosted: 22:32 - 15 Jan 2012    Post subject: Reply with quote
Would expect in production the distance to the very end of the swinging arm is a pretty non critical dimension, and one I wouldn't expect to be accurate.
dansidi
PostPosted: 22:45 - 15 Jan 2012    Post subject: Reply with quote
Urk !!! You're right.
Thanks for the heads up. I will be hyper alert the next few times I ride.
Thanks again.
Walloper
PostPosted: 00:14 - 16 Jan 2012    Post subject: Reply with quote
String is easy enough.
The string has to come from the RH side wall of the back wheel from the rear Point 'A' past the RH sidewall of the back wheel at the front Point 'B'.
Then you 'project' the straight line that 'makes' along to the same area at the front wheel.
Move the end of the string away (towards the RH) from the front wheel. This should make the only part of the string touching the bike Point 'A' at the back.
Move the string toward the bike (towards the LH) and watch as the string touches the second point at point 'B'.
Measure the gap between the string and Point 'C' (back side wall of front wheel) and Point 'D' (front side wall of front wheel).
This is measurement 1 and 12
Go to the other side of the bike and do the same thing to get measurement 3 and 4.
If there is a difference when you subtract measurement 1 and 2 from measurement 3 and 4.
Or if you can't get your head around the geometry go to a bike shop.
dansidi
PostPosted: 08:46 - 16 Jan 2012    Post subject: Reply with quote
Ah yes, but what if:
The string is not perfectly straight.
The bike is not perfectly level.
The front wheel is not perfectly straight.
The string is pressing against the centre stand (or other item).
The tread on the back wheel is unevenly pushing the string out away from the back wheel.
I understand what needs to be done, but I think it's not possible to do it with sufficient accuracy, given the many possible variables.
I could not be confident of ANY of the things I listed. It cannot be done !
PostPosted: 08:50 - 16 Jan 2012    Post subject: Re: Rear wheel alignment; string method - you're joking ! Reply with quote
I did once make a DIY laser alignment system, but otherwise used string when I've been bothered.
Also used string on the car, which also worked well enough.
Don't see why the bike needs to be level. Of course the front wheel needs to be straight, same when 'the garage does it'. I use kink-free string.
On the car, it certainly was useful. On the bike, I've never seen a big difference in handling even when the rear wheel is out a bit.
dansidi
PostPosted: 09:07 - 16 Jan 2012    Post subject: Reply with quote
Well, after a 10 mile commute this morning I am confident that either I got the wheel aligned exactly right using the vernier callipers or it doesn't make too much difference if the wheel is out by a little bit.
The only problem this morning was the freezing morning air and the thick frost on the roads. The back wheel skidded while I was leaning on a mini-roundabout. Nasty one.
neil.
PostPosted: 10:12 - 16 Jan 2012    Post subject: Reply with quote
Meanwhile in the real world - a bit of misalignment on a YBR won't really matter. I never ever had any issues with handling or weird tyre wear in all the time I owned a YBR - 3 years and just shy of 40'000 miles of riding it. Always used the swingarm markings, never failed an MOT. I did once make a mistake and offset one side by one notch longer than the other (would have been about 5mm). Noticed no effect on handling in the few hundred miles I rode with it like that. I'd imagine it would have to be REALLY out of alignment to make a noticeable difference on these bikes, and by that time I think you'd visually see that the wheel was pointing the wrong way.
The last post was made 14 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 137.17 Kb
