Malossi Boost bottle
binge
Emo Kiddy
PostPosted: 15:51 - 18 Sep 2004    Post subject: Malossi Boost bottle Reply with quote
Just out of interest. Does anybody know how the boost bottles work for the scooters? Im not too interested in getting one because my scooter is quick enough as it is. But i was just interested how they work. On a website is says that you have to fir it onto your inlet manifold, but i dont see how they work???
TheShaggyDA
Repost Police
PostPosted: 16:44 - 18 Sep 2004    Post subject: Reply with quote
Translated by google from German :-
By the influence of the gas oscillations on the inlet procedure not only the filling of the crankshaft housing, but also the gemischzusammensetzung change with the number of revolutions. If the number of revolutions falls with opened carburetor cross section under the number of revolutions, at which the best filling is reached, then mixture from the crankshaft housing flows back into the intake. The flowing back mixture is enriched again there now with fuel (it becomes fatter). An elegant solution of this problem represents the installation of a simple swinging area. The swinging area is connected by a pipe with the intake. If the piston continues to close the einlassschlitz during the downward movement ever, or which diaphragm tongues brake by the sinking difference of pressure the gas flow ever more strongly, the running back wave has to flow now the possibility into the connecting tube and diminish the flow energy. Thus the influence of the running back wave on the carburetor decreases. Practice shows that the gemischzusammensetzung almost remains over the entire speed range equal, only at very low numbers of revolutions drops it somewhat. The effective range can be varied however over a changed length of the connecting tube. The use of a swinging chamber makes a leaner mixture attitude possible and leads to a measurably smaller consumption in the middle and lower speed range result: a swinging chamber brings a better filling of the crankshaft housing, with continuous gemischzusammensetzung over almost the entire speed range. In addition gasoline consumption is lower in the lower and middle speed range. SCK TIP: Straight one with that very long sucking in of you times of the long rockshaft, which for the PX is available can without the assembly of a Boost Bottle of the carburetors is hardly cleanly co-ordinated (valid only for rotary valve price increase). A constant fat, particularly in the sliding enterprise, ruin any layer of run culture. The Boost Bottle eliminates this problem almost completely. For large volume engines the Polini Boost Bottle, since this exhibits a sufficiently large chamber volume is recommended, in order to compensate the resulting mass of gas. The length of the suction hose from the intake to the Boost Bottle determines the number of revolutions with that the chamber supporting works. We recommend with o.g. To leave case (long rockshaft, 28-30mm carburetor) the hose in its original length.
Sounds like it acts as a capacitor for the fuel/air mix, smoothing out delivery when shutting off/reopening the throttle.
steve09
PostPosted: 18:03 - 18 Sep 2004    Post subject: Reply with quote
basacilly thts all it dose.
i had one on my Go-ped.
they fit up tio about 70cc all they do is as you shut off throattle instead of letting the fuel and air mix go to waste it gose back up to the bottle and then when u open throattl again you get a quicker response.
saves abit of fuel and other than tht dose nothing..
really good on geared 50ccs though when ur changeing gears alot helps keep ya going hehe.. for wht they are there not worth it and there a bitch to set up.
you have to have the bottle at a certain hight from the manifold facing a certain angle lot of hassle..
cheers
steve
tatters
Exxon Valdez
PostPosted: 20:42 - 18 Sep 2004    Post subject: Reply with quote
seen one on a RD350, single can with two pipes at each end going to the carb, when the throttle was shut off the wasted fuel air mixture would go to the can intesed of going out the exhaust so next time the throttle was opened there would be a "boost" of midrange acceration
steve09
PostPosted: 21:02 - 18 Sep 2004    Post subject: Reply with quote
sorry i didnt relise you could get them for bigger than 70cc..
i surpose it worked alot better on a 350?
The last post was made 21 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 45.58 Kb
